[GRASS-SVN] r61744 - grass/trunk/vector/v.distance
svn_grass at osgeo.org
Mon Aug 25 22:47:28 PDT 2014
Author: neteler
Date: 2014-08-25 22:47:28 -0700 (Mon, 25 Aug 2014)
New Revision: 61744
grass/trunk/vector/v.distance/v.distance.html
v.distance manual: more examples
Modified: grass/trunk/vector/v.distance/v.distance.html
--- grass/trunk/vector/v.distance/v.distance.html 2014-08-26 05:46:35 UTC (rev 61743)
+++ grass/trunk/vector/v.distance/v.distance.html 2014-08-26 05:47:28 UTC (rev 61744)
@@ -101,6 +101,7 @@
points from a vector map as input instead of stdin. A new vector map
with query points has to be created before the map can be analysed.
<p>
Create query map (if not present):
<div class="code"><pre>
@@ -159,15 +160,47 @@
v.univar vdistance_vectors column=length
</pre></div>
+<h3>Print distance between points</h3>
+Example for a Latitude-longitude location (EPSG 4326):
+<div class="code"><pre>
+# points along the equator
+echo "0|-61|1" | v.in.ascii output=pnt1 input=-
+echo "0|-58|1" | v.in.ascii output=pnt2 input=-
+# here, distances is in degree units
+v.distance from=pnt1 to=pnt2 upload=dist col=distance -p --q
+from_cat|distance
+1|3
+</pre></div>
<h3>Print distance matrix</h3>
+Note: Matrix-style output is enabled only for flag <em>-a</em> and one
+given upload option.
+<p>
+Spearfish sample data location:
v.distance -pa from=archsites to=archsites upload=dist col=dist
</pre></div>
-Note: Matrix-like output is enabled only for flag <b>-a</b> and one
-given upload option.
+<p>
+North Carolina sample data location:
+v.distance -pa from=hospitals to=hospitals upload=dist \
+ col=dist separator=comma
+from_cat to_cat dist
+ 1 2 3 4 5 ...
+1 0 7489.10 339112.17 70900.39 70406.23 ...
+2 7489.10 0 345749.12 76025.46 75538.87 ...
+3 339112.17 345749.12 0 274153.19 274558.98 ...
+4 70900.39 76025.46 274153.19 0 501.11 ...
+5 70406.23 75538.87 274558.98 501.11 0 ...
+</pre></div>
<h2>SEE ALSO</h2>
<em>
@@ -177,7 +210,7 @@
</em>
-<h2>AUTHOR</h2>
+<h2>AUTHORS</h2>
Janne Soimasuo 1994, University of Joensuu, Faculty of Forestry, Finland<br>
Cmd line coordinates support: Markus Neteler, ITC-irst, Trento, Italy<br>
