[GRASS-SVN] r61759 - in grass/trunk: include lib/temporal/lib
svn_grass at osgeo.org
Wed Aug 27 12:42:26 PDT 2014
Author: huhabla
Date: 2014-08-27 12:42:26 -0700 (Wed, 27 Aug 2014)
New Revision: 61759
grass/trunk/include/temporal.h
grass/trunk/lib/temporal/lib/connect.c
temporal C-library: New functions to receive the temporal database driver and name from different mapsets in a location. Needed for handling distributed temporal databases.
Modified: grass/trunk/include/temporal.h
--- grass/trunk/include/temporal.h 2014-08-27 14:14:20 UTC (rev 61758)
+++ grass/trunk/include/temporal.h 2014-08-27 19:42:26 UTC (rev 61759)
@@ -16,6 +16,8 @@
char *tgis_get_default_database_name(void);
char *tgis_get_driver_name(void);
char *tgis_get_database_name(void);
+char *tgis_get_mapset_driver_name(const char*);
+char *tgis_get_mapset_database_name(const char*);
int tgis_set_default_connection(void);
Modified: grass/trunk/lib/temporal/lib/connect.c
--- grass/trunk/lib/temporal/lib/connect.c 2014-08-27 14:14:20 UTC (rev 61758)
+++ grass/trunk/lib/temporal/lib/connect.c 2014-08-27 19:42:26 UTC (rev 61759)
@@ -13,6 +13,7 @@
Joel Jones (CERL/UIUC) and Radim Blazek
#include <grass/temporal.h>
+#include <grass/glocale.h>
* \brief Get TGIS driver name
@@ -82,3 +83,78 @@
return DB_OK;
+#define DRIVER_NAME 0
+#define DATABASE_NAME 1
+static char *get_mapset_connection_name(const char *mapset, int contype)
+ const char *val = NULL;
+ char *ret_val = NULL;
+ const char *orig_mapset;
+ int ret;
+ orig_mapset = G__getenv("MAPSET");
+ ret = G__mapset_permissions2(G__getenv("GISDBASE"), G__getenv("LOCATION_NAME"), mapset);
+ switch (ret) {
+ case 0:
+ G_fatal_error(_("You don't have permission to access the mapset <%s>"),
+ mapset);
+ break;
+ case -1:
+ G_fatal_error(_("Mapset <%s> does not exist."),
+ mapset);
+ break;
+ default:
+ break;
+ G_setenv("MAPSET", mapset);
+ if(contype == DATABASE_NAME) {
+ if ((val = G__getenv2("TGISDB_DATABASE", G_VAR_MAPSET)))
+ ret_val = G_store(val);
+ } else if(contype == DRIVER_NAME) {
+ if ((val = G__getenv2("TGISDB_DRIVER", G_VAR_MAPSET)))
+ G_setenv("MAPSET", orig_mapset);
+ return ret_val;
+ * \brief Get TGIS driver name from a specific mapset
+ * This function will call G_fatal_error() in case the mapset does not exists
+ * or it is not allowed to access the mapset.
+ * \param mapset The name of the mapset to receive the driver name from
+ * \return pointer to TGIS driver name
+ * \return NULL if not set
+char *tgis_get_mapset_driver_name(const char *mapset)
+ return get_mapset_connection_name(mapset, DRIVER_NAME);
+ * \brief Get TGIS database name
+ * \return pointer to TGIS database name
+char *tgis_get_mapset_database_name(const char *mapset)
+ return get_mapset_connection_name(mapset, DATABASE_NAME);
