[GRASS-SVN] r61776 - in grass/branches/releasebranch_7_0/raster: r.in.lidar r.in.xyz
svn_grass at osgeo.org
Fri Aug 29 16:16:59 PDT 2014
Author: hamish
Date: 2014-08-29 16:16:59 -0700 (Fri, 29 Aug 2014)
New Revision: 61776
grass/branches/releasebranch_7_0/raster/r.in.lidar/main.c
grass/branches/releasebranch_7_0/raster/r.in.xyz/main.c
cut back clicker update frequency to a more human observable value (merge from trunk)
Modified: grass/branches/releasebranch_7_0/raster/r.in.lidar/main.c
--- grass/branches/releasebranch_7_0/raster/r.in.lidar/main.c 2014-08-29 23:15:41 UTC (rev 61775)
+++ grass/branches/releasebranch_7_0/raster/r.in.lidar/main.c 2014-08-29 23:16:59 UTC (rev 61776)
@@ -749,7 +749,7 @@
line++;
counter++;
- if (counter == 10000) { /* speed */
+ if (counter == 100000) { /* speed */
if (line < estimated_lines)
G_percent(line, estimated_lines, 3);
counter = 0;
Modified: grass/branches/releasebranch_7_0/raster/r.in.xyz/main.c
--- grass/branches/releasebranch_7_0/raster/r.in.xyz/main.c 2014-08-29 23:15:41 UTC (rev 61775)
+++ grass/branches/releasebranch_7_0/raster/r.in.xyz/main.c 2014-08-29 23:16:59 UTC (rev 61776)
@@ -661,7 +661,7 @@
while (0 != G_getl2(buff, BUFFSIZE - 1, in_fp)) {
line++;
- if (line % 10000 == 0) { /* mod for speed */
+ if (line % 100000 == 0) { /* mod for speed */
if (!can_seek)
G_clicker();
else if (line < estimated_lines)
@@ -749,7 +749,7 @@
arr_row = (int)((pass_north - y) / region.ns_res);
arr_col = (int)((x - region.west) / region.ew_res);
- /* G_debug(5, "arr_row: %d arr_col: %d", arr_row, arr_col); */
+ /* G_debug(5, "arr_row: %d arr_col: %d", arr_row, arr_col); */
/* The range should be [0,cols-1]. We use (int) to round down,
but if the point exactly on eastern edge arr_col will be /just/
