[GRASS-SVN] r63309 - grass/trunk/scripts/v.db.join
svn_grass at osgeo.org
Mon Dec 1 02:49:05 PST 2014
Author: hellik
Date: 2014-12-01 02:49:05 -0800 (Mon, 01 Dec 2014)
New Revision: 63309
grass/trunk/scripts/v.db.join/v.db.join.py
v.db.join: fix for new option syntax
Modified: grass/trunk/scripts/v.db.join/v.db.join.py
--- grass/trunk/scripts/v.db.join/v.db.join.py 2014-12-01 07:47:06 UTC (rev 63308)
+++ grass/trunk/scripts/v.db.join/v.db.join.py 2014-12-01 10:49:05 UTC (rev 63309)
@@ -66,10 +66,10 @@
map = options['map']
layer = options['layer']
column = options['column']
- otable = options['otable']
- ocolumn = options['ocolumn']
- if options['scolumns']:
- scolumns = options['scolumns'].split(',')
+ otable = options['other_table']
+ ocolumn = options['other_column']
+ if options['subset_columns']:
+ scolumns = options['subset_columns'].split(',')
else:
scolumns = None
