[GRASS-SVN] r63311 - grass/branches/releasebranch_7_0/scripts/v.db.join
svn_grass at osgeo.org
Mon Dec 1 03:15:46 PST 2014
Author: hellik
Date: 2014-12-01 03:15:45 -0800 (Mon, 01 Dec 2014)
New Revision: 63311
grass/branches/releasebranch_7_0/scripts/v.db.join/v.db.join.py
v.db.join: fix for new option syntax (merge from trunk r63309)
Modified: grass/branches/releasebranch_7_0/scripts/v.db.join/v.db.join.py
--- grass/branches/releasebranch_7_0/scripts/v.db.join/v.db.join.py 2014-12-01 10:56:17 UTC (rev 63310)
+++ grass/branches/releasebranch_7_0/scripts/v.db.join/v.db.join.py 2014-12-01 11:15:45 UTC (rev 63311)
@@ -66,10 +66,10 @@
map = options['map']
layer = options['layer']
column = options['column']
- otable = options['otable']
- ocolumn = options['ocolumn']
- if options['scolumns']:
- scolumns = options['scolumns'].split(',')
+ otable = options['other_table']
+ ocolumn = options['other_column']
+ if options['subset_columns']:
+ scolumns = options['subset_columns'].split(',')
else:
scolumns = None
