[GRASS-SVN] r63316 - in grass/branches/releasebranch_7_0: . scripts/d.correlate scripts/d.rast.leg scripts/d.vect.thematic
Mon Dec 1 08:52:33 PST 2014
Author: neteler
Date: 2014-12-01 08:52:33 -0800 (Mon, 01 Dec 2014)
New Revision: 63316
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/scripts/d.correlate/d.correlate.py
   grass/branches/releasebranch_7_0/scripts/d.rast.leg/d.rast.leg.py
   grass/branches/releasebranch_7_0/scripts/d.vect.thematic/d.vect.thematic.py
backport of r63315
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,
 63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63302
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,
 63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63302,63315
Modified: grass/branches/releasebranch_7_0/scripts/d.correlate/d.correlate.py
--- grass/branches/releasebranch_7_0/scripts/d.correlate/d.correlate.py	2014-12-01 16:43:44 UTC (rev 63315)
+++ grass/branches/releasebranch_7_0/scripts/d.correlate/d.correlate.py	2014-12-01 16:52:33 UTC (rev 63316)
@@ -32,11 +32,6 @@
 from grass.script import core as grass
 def main():
-    env = grass.gisenv()
-    mon = env.get('MONITOR', None)
-    if not mon:
-        grass.fatal(_("No graphics device selected. Use d.mon to select graphics device."))
     layers = options['map'].split(',')
     if len(layers) < 2:
Modified: grass/branches/releasebranch_7_0/scripts/d.rast.leg/d.rast.leg.py
--- grass/branches/releasebranch_7_0/scripts/d.rast.leg/d.rast.leg.py	2014-12-01 16:43:44 UTC (rev 63315)
+++ grass/branches/releasebranch_7_0/scripts/d.rast.leg/d.rast.leg.py	2014-12-01 16:52:33 UTC (rev 63316)
@@ -81,11 +81,6 @@
     os.environ['GRASS_RENDER_FRAME'] = s
 def main():
-    if not mon:
     map = options['map']
     nlines = options['lines']
     rast = options['raster']
Modified: grass/branches/releasebranch_7_0/scripts/d.vect.thematic/d.vect.thematic.py
--- grass/branches/releasebranch_7_0/scripts/d.vect.thematic/d.vect.thematic.py	2014-12-01 16:43:44 UTC (rev 63315)
+++ grass/branches/releasebranch_7_0/scripts/d.vect.thematic/d.vect.thematic.py	2014-12-01 16:52:33 UTC (rev 63316)
@@ -231,11 +231,6 @@
 def main():
     global tmp_graph, tmp_group, tmp_psmap, tmp_psleg, tmp_gisleg
-    if not mon:
     breakpoints = options['breakpoints']
     colorscheme = options['colorscheme']
     column = options['column']
