[GRASS-SVN] r63331 - in grass/branches/releasebranch_7_0: . gui/wxpython gui/wxpython/gui_core
Tue Dec 2 09:31:48 PST 2014
Author: neteler
Date: 2014-12-02 09:31:48 -0800 (Tue, 02 Dec 2014)
New Revision: 63331
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/gui/wxpython/gis_set.py
   grass/branches/releasebranch_7_0/gui/wxpython/gui_core/dialogs.py
   grass/branches/releasebranch_7_0/gui/wxpython/gui_core/gselect.py
wxGUI: update for renamed dsn parameter (trunk, r63330)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,
 63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63302,63315,63319
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,63089,
 63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63302,63315,63319,63330
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gis_set.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gis_set.py	2014-12-02 17:30:02 UTC (rev 63330)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gis_set.py	2014-12-02 17:31:48 UTC (rev 63331)
@@ -513,14 +513,14 @@
         RunCommand('db.connect', flags='c')
         mapName = os.path.splitext(os.path.basename(filePath))[0]
-        vectors = RunCommand('v.in.ogr', dsn = filePath, flags = 'l',
+        vectors = RunCommand('v.in.ogr', input = filePath, flags = 'l',
                              read = True)
         wx.BeginBusyCursor()
         wx.Yield()
         if mapName in vectors:
             # vector detected
-            returncode, error = RunCommand('v.in.ogr', dsn = filePath, output = mapName,
+            returncode, error = RunCommand('v.in.ogr', input = filePath, output = mapName,
                                            getErrorMsg = True)
         else:
             returncode, error = RunCommand('r.in.gdal', input = filePath, output = mapName,
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/dialogs.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/dialogs.py	2014-12-02 17:30:02 UTC (rev 63330)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/dialogs.py	2014-12-02 17:31:48 UTC (rev 63331)
@@ -412,7 +412,7 @@
                                    parent = parent,
                                    read = True,
                                    flags = 'l',
-                                   dsn = vExternalOut['dsn']).splitlines()
+                                   input = vExternalOut['dsn']).splitlines()
     overwrite = False
     if not UserSettings.Get(group = 'cmd', key = 'overwrite', subkey = 'enabled') and \
@@ -446,7 +446,7 @@
         RunCommand('v.external',
                    overwrite = overwrite,
                    parent = parent,
-                   dsn = vExternalOut['dsn'],
+                   input = vExternalOut['dsn'],
                    layer = outmap)
     # create attribute table
@@ -1891,12 +1891,12 @@
                     layer = layer.replace('.' + ext, '')
                 if self.link:
                     cmd = ['v.external',
-                           'dsn=%s' % dsn,
+                           'input=%s' % dsn,
                            'output=%s' % output,
                            'layer=%s' % layer]
                 else:
                     cmd = ['v.in.ogr',
-                           'dsn=%s' % dsn,
+                           'input=%s' % dsn,
                            'layer=%s' % layer,
                            'output=%s' % output]
             else: # gdal
@@ -2041,7 +2041,7 @@
             RunCommand('v.external.out',
                        parent = self,
-                       dsn = dsn, format = frmt,
+                       output = dsn, format = frmt,
                        options = options)
         self.Close()
Modified: grass/branches/releasebranch_7_0/gui/wxpython/gui_core/gselect.py
--- grass/branches/releasebranch_7_0/gui/wxpython/gui_core/gselect.py	2014-12-02 17:30:02 UTC (rev 63330)
+++ grass/branches/releasebranch_7_0/gui/wxpython/gui_core/gselect.py	2014-12-02 17:31:48 UTC (rev 63331)
@@ -861,7 +861,7 @@
                              read = True,
                              quiet = True,
                              flags = 'l',
-                             dsn = dsn)
+                             input = dsn)
             if ret:
                 layers = ret.splitlines()
@@ -1921,7 +1921,7 @@
                              quiet = True,
                              read = True,
                              flags = 't',
-                             dsn = dsn)
+                             input = dsn)
             if not ret:
                 self.reloadDataRequired.emit(data=None)
                 return
