[GRASS-SVN] r63345 - in grass/trunk: general/g.dirseps general/g.filename general/g.findetc general/g.findfile general/g.gisenv general/g.gui general/g.parser general/g.tempfile general/g.version gui/wxpython/animation gui/wxpython/dbmgr gui/wxpython/gcp gui/wxpython/gmodeler gui/wxpython/iclass gui/wxpython/mapswipe gui/wxpython/psmap gui/wxpython/rlisetup gui/wxpython/timeline gui/wxpython/tplot gui/wxpython/vdigit imagery/i.cca imagery/i.landsat.acca imagery/i.pca raster/r.clump raster/r.neighbors raster/r.patch raster/r.sim/r.sim.sediment raster/r.sim/r.sim.water raster/r.slope.aspect raster/r.usler raster3d/r3.neighbors scripts/db.in.ogr scripts/db.out.ogr temporal/t.info temporal/t.merge temporal/t.rast.accdetect temporal/t.rast.accumulate temporal/t.rast.aggregate temporal/t.rast.aggregate.ds temporal/t.rast.algebra temporal/t.rast.colors temporal/t.rast.export temporal/t.rast.extract temporal/t.rast.gapfill temporal/t.rast.import temporal/t.rast.mapcalc temporal/t.rast.n eighbors temporal/t.rast.out.vtk temporal/t.rast.series temporal/t.rast.to.rast3 temporal/t.rast3d.algebra temporal/t.rast3d.extract temporal/t.rast3d.list temporal/t.rast3d.mapcalc temporal/t.rast3d.univar temporal/t.remove temporal/t.rename temporal/t.select temporal/t.snap temporal/t.support temporal/t.vect.algebra temporal/t.vect.export temporal/t.vect.extract temporal/t.vect.import temporal/t.vect.observe.strds temporal/t.vect.univar temporal/t.vect.what.strds vector/v.clean vector/v.db.select vector/v.lrs/v.lrs.create vector/v.lrs/v.lrs.label vector/v.lrs/v.lrs.segment vector/v.lrs/v.lrs.where vector/v.net.alloc vector/v.out.dxf
svn_grass at osgeo.org
Wed Dec 3 00:31:27 PST 2014
Author: neteler
Date: 2014-12-03 00:31:27 -0800 (Wed, 03 Dec 2014)
New Revision: 63345
grass/trunk/general/g.dirseps/main.c
grass/trunk/general/g.filename/main.c
grass/trunk/general/g.findetc/main.c
grass/trunk/general/g.findfile/main.c
grass/trunk/general/g.gisenv/main.c
grass/trunk/general/g.gui/main.c
grass/trunk/general/g.parser/g.parser.html
grass/trunk/general/g.tempfile/main.c
grass/trunk/general/g.version/main.c
grass/trunk/gui/wxpython/animation/g.gui.animation.py
grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py
grass/trunk/gui/wxpython/gcp/g.gui.gcp.py
grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py
grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
grass/trunk/gui/wxpython/psmap/g.gui.psmap.py
grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
grass/trunk/gui/wxpython/timeline/g.gui.timeline.py
grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
grass/trunk/imagery/i.cca/i.cca.html
grass/trunk/imagery/i.cca/main.c
grass/trunk/imagery/i.landsat.acca/main.c
grass/trunk/imagery/i.pca/main.c
grass/trunk/raster/r.clump/main.c
grass/trunk/raster/r.neighbors/main.c
grass/trunk/raster/r.patch/main.c
grass/trunk/raster/r.sim/r.sim.sediment/main.c
grass/trunk/raster/r.sim/r.sim.water/main.c
grass/trunk/raster/r.slope.aspect/main.c
grass/trunk/raster/r.usler/main.c
grass/trunk/raster3d/r3.neighbors/main.c
grass/trunk/scripts/db.in.ogr/db.in.ogr.py
grass/trunk/scripts/db.out.ogr/db.out.ogr.py
grass/trunk/temporal/t.info/t.info.py
grass/trunk/temporal/t.merge/t.merge.py
grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py
grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py
grass/trunk/temporal/t.rast.colors/t.rast.colors.py
grass/trunk/temporal/t.rast.export/t.rast.export.py
grass/trunk/temporal/t.rast.extract/t.rast.extract.py
grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
grass/trunk/temporal/t.rast.import/t.rast.import.py
grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
grass/trunk/temporal/t.rast.series/t.rast.series.py
grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
grass/trunk/temporal/t.rast3d.algebra/t.rast3d.algebra.py
grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py
grass/trunk/temporal/t.remove/t.remove.py
grass/trunk/temporal/t.rename/t.rename.py
grass/trunk/temporal/t.select/t.select.py
grass/trunk/temporal/t.snap/t.snap.py
grass/trunk/temporal/t.support/t.support.py
grass/trunk/temporal/t.vect.algebra/t.vect.algebra.py
grass/trunk/temporal/t.vect.export/t.vect.export.py
grass/trunk/temporal/t.vect.extract/t.vect.extract.py
grass/trunk/temporal/t.vect.import/t.vect.import.py
grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
grass/trunk/temporal/t.vect.univar/t.vect.univar.py
grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
grass/trunk/vector/v.clean/main.c
grass/trunk/vector/v.db.select/main.c
grass/trunk/vector/v.lrs/v.lrs.create/main.c
grass/trunk/vector/v.lrs/v.lrs.label/main.c
grass/trunk/vector/v.lrs/v.lrs.segment/main.c
grass/trunk/vector/v.lrs/v.lrs.where/main.c
grass/trunk/vector/v.net.alloc/main.c
grass/trunk/vector/v.out.dxf/main.c
manual: keywords cleanup
Modified: grass/trunk/general/g.dirseps/main.c
--- grass/trunk/general/g.dirseps/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/general/g.dirseps/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -33,6 +33,7 @@
module = G_define_module();
G_add_keyword(_("general"));
G_add_keyword(_("map management"));
+ G_add_keyword(_("scripts"));
module->label =
_("Internal GRASS utility for converting directory separator characters.");
module->description =
Modified: grass/trunk/general/g.filename/main.c
--- grass/trunk/general/g.filename/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/general/g.filename/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -38,6 +38,7 @@
module->description = _("Prints GRASS data base file names.");
/* Define the different options */
Modified: grass/trunk/general/g.findetc/main.c
--- grass/trunk/general/g.findetc/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/general/g.findetc/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -27,6 +27,7 @@
module->description = "Searches for GRASS support files.";
G_gisinit(argv[0]);
Modified: grass/trunk/general/g.findfile/main.c
--- grass/trunk/general/g.findfile/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/general/g.findfile/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -37,6 +37,7 @@
_("Searches for GRASS data base files "
"and sets variables for the shell.");
Modified: grass/trunk/general/g.gisenv/main.c
--- grass/trunk/general/g.gisenv/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/general/g.gisenv/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -43,6 +43,7 @@
G_add_keyword(_("settings"));
G_add_keyword(_("variables"));
module->label =
_("Outputs and modifies the user's current GRASS variable settings.");
module->description = _("Prints all defined GRASS variables if no option is given.");
Modified: grass/trunk/general/g.gui/main.c
--- grass/trunk/general/g.gui/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/general/g.gui/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -35,8 +35,8 @@
- G_add_keyword(_("gui"));
G_add_keyword(_("user interface"));
+ G_add_keyword(_("GUI"));
module->label =
_("Launches a GRASS graphical user interface (GUI) session.");
module->description = _("And updates default user interface settings.");
Modified: grass/trunk/general/g.parser/g.parser.html
--- grass/trunk/general/g.parser/g.parser.html 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/general/g.parser/g.parser.html 2014-12-03 08:31:27 UTC (rev 63345)
@@ -1,6 +1,9 @@
<!-- meta page name: g.parser -->
<!-- meta page name description: Provides full parser support for GRASS scripts. -->
+<h2>KEYWORDS</h2>
+<a href="general.html">general</a>, <a href="topic_support.html">support</a>, <a href="keywords.html#scripts">scripts</a>
<h2>SYNOPSIS</h2>
<b>g.parser --help</b><br>
<b>g.parser</b> [-<b>s</b>] [-<b>t</b>] [-<b>n</b>] <em>filename</em> [<em>argument</em>,...]
Modified: grass/trunk/general/g.tempfile/main.c
--- grass/trunk/general/g.tempfile/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/general/g.tempfile/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -37,7 +37,7 @@
G_add_keyword(_("support"));
module->description = _("Creates a temporary file and prints it's file name.");
pid = G_define_option();
Modified: grass/trunk/general/g.version/main.c
--- grass/trunk/general/g.version/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/general/g.version/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -61,7 +61,7 @@
module->label = _("Displays GRASS version info.");
- module->description = _("Optionally also print build or copyright information.");
+ module->description = _("Optionally also prints build or copyright information.");
copyright = G_define_flag();
copyright->key = 'c';
Modified: grass/trunk/gui/wxpython/animation/g.gui.animation.py
--- grass/trunk/gui/wxpython/animation/g.gui.animation.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/gui/wxpython/animation/g.gui.animation.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -22,8 +22,10 @@
#%module
#% description: Tool for animating a series of raster and vector maps or a space time raster or vector dataset.
#% keywords: general
+#% keywords: user interface
#% keywords: GUI
#% keywords: display
+#% keywords: animation
#%end
#%option G_OPT_R_INPUTS
#% key: raster
Modified: grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py
--- grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/gui/wxpython/dbmgr/g.gui.dbmgr.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -21,6 +21,7 @@
#%module
#% description: Launches graphical attribute table manager.
#% keywords: GUI
#% keywords: attribute table
#% keywords: database
Modified: grass/trunk/gui/wxpython/gcp/g.gui.gcp.py
--- grass/trunk/gui/wxpython/gcp/g.gui.gcp.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/gui/wxpython/gcp/g.gui.gcp.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -22,6 +22,7 @@
#%module
#% description: Georectifies a map and allows to manage Ground Control Points.
#% keywords: GUI
#% keywords: georectification
#% keywords: GCP
Modified: grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py
--- grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/gui/wxpython/gmodeler/g.gui.gmodeler.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -22,6 +22,7 @@
#% label: Graphical Modeler.
#% description: Allows to interactively create, edit and manage models.
#% keywords: GUI
#% keywords: graphical modeler
#% keywords: workflow
Modified: grass/trunk/gui/wxpython/iclass/g.gui.iclass.py
--- grass/trunk/gui/wxpython/iclass/g.gui.iclass.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/gui/wxpython/iclass/g.gui.iclass.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -23,6 +23,7 @@
#% label: Tool for supervised classification of imagery data.
#% description: Generates spectral signatures for an image by allowing the user to outline regions of interest.
#% keywords: GUI
#% keywords: classification
#% keywords: supervised classification
Modified: grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py
--- grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/gui/wxpython/mapswipe/g.gui.mapswipe.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -22,6 +22,7 @@
#%module
#% description: Interactively compares two maps by swiping a visibility bar.
#% keywords: GUI
#%end
Modified: grass/trunk/gui/wxpython/psmap/g.gui.psmap.py
--- grass/trunk/gui/wxpython/psmap/g.gui.psmap.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/gui/wxpython/psmap/g.gui.psmap.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -21,6 +21,7 @@
#%module
#% description: Tool for creating hardcopy map outputs.
#% keywords: GUI
#% keywords: printing
#%end
Modified: grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py
--- grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/gui/wxpython/rlisetup/g.gui.rlisetup.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -21,6 +21,7 @@
#%module
#% description: Configuration tool for r.li modules.
#% keywords: GUI
#% keywords: raster
#% keywords: landscape structure analysis
Modified: grass/trunk/gui/wxpython/timeline/g.gui.timeline.py
--- grass/trunk/gui/wxpython/timeline/g.gui.timeline.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/gui/wxpython/timeline/g.gui.timeline.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -22,6 +22,7 @@
#%module
#% description: Allows to compare temporal datasets by displaying their temporal extents in a plot.
#% keywords: GUI
#% keywords: temporal
#%end
Modified: grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
--- grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -23,6 +23,7 @@
#%module
#% description: Allows the user to see in a plot the values of one or more temporal datasets for a queried point defined by a coordinate pair.
#% keywords: GUI
#%end
Modified: grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py
--- grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/gui/wxpython/vdigit/g.gui.vdigit.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -21,10 +21,11 @@
#%module
#% description: Interactive editing and digitization of vector maps.
#% keywords: GUI
#% keywords: vector
#% keywords: editing
-#% keywords: digitization
+#% keywords: digitizer
#%end
#%flag
#% key: c
Modified: grass/trunk/imagery/i.cca/i.cca.html
--- grass/trunk/imagery/i.cca/i.cca.html 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/imagery/i.cca/i.cca.html 2014-12-03 08:31:27 UTC (rev 63345)
@@ -58,15 +58,18 @@
<h2>SEE ALSO</h2>
+<em>
+<a href="g.gui.iclass.html">g.gui.iclass</a>,
+<a href="i.pca.html">i.pca</a>,
+<a href="r.covar.html">r.covar</a>,
+<a href="r.mapcalc.html">r.mapcalc</a>
+</em>
+<h2>REFERENCES</h2>
Schowengerdt, Robert A. <b>Techniques for Image Processing and
Classification in Remote Sensing</b>, Academic Press, 1983.
-<p>
-<em><a href="g.gui.iclass.html">g.gui.iclass</a></em>
-<em><a href="i.pca.html">i.pca</a></em><br>
-<em><a href="r.covar.html">r.covar</a></em><br>
-<em><a href="r.mapcalc.html">r.mapcalc</a></em>
<h2>AUTHORS</h2>
David Satnik, GIS Laboratory,
Modified: grass/trunk/imagery/i.cca/main.c
--- grass/trunk/imagery/i.cca/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/imagery/i.cca/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -84,6 +84,7 @@
G_add_keyword(_("imagery"));
G_add_keyword(_("statistics"));
G_add_keyword("CCA");
+ G_add_keyword(_("canonical components analysis");
_("Canonical components analysis (CCA) "
"program for image processing.");
Modified: grass/trunk/imagery/i.landsat.acca/main.c
--- grass/trunk/imagery/i.landsat.acca/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/imagery/i.landsat.acca/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -105,6 +105,7 @@
G_add_keyword(_("Landsat"));
G_add_keyword("ACCA");
+ G_add_keyword(_("cloud detection"));
band_prefix = G_define_standard_option(G_OPT_R_BASENAME_INPUT);
band_prefix->label = _("Base name of input raster bands");
Modified: grass/trunk/imagery/i.pca/main.c
--- grass/trunk/imagery/i.pca/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/imagery/i.pca/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -72,6 +72,7 @@
G_add_keyword(_("transformation"));
G_add_keyword(_("PCA"));
+ G_add_keyword(_("principal components analysis");
module->description = _("Principal components analysis (PCA) "
"for image processing.");
module->overwrite = 1;
Modified: grass/trunk/raster/r.clump/main.c
--- grass/trunk/raster/r.clump/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/raster/r.clump/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -51,6 +51,7 @@
G_add_keyword(_("raster"));
G_add_keyword(_("reclass"));
+ G_add_keyword(_("clumps"));
_("Recategorizes data in a raster map by grouping cells "
"that form physically discrete areas into unique categories.");
Modified: grass/trunk/raster/r.neighbors/main.c
--- grass/trunk/raster/r.neighbors/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/raster/r.neighbors/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -168,6 +168,8 @@
G_add_keyword(_("algebra"));
G_add_keyword(_("aggregation"));
+ G_add_keyword(_("neighbor"));
+ G_add_keyword(_("focal statistics"));
G_add_keyword(_("filter"));
_("Makes each cell category value a "
Modified: grass/trunk/raster/r.patch/main.c
--- grass/trunk/raster/r.patch/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/raster/r.patch/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -56,6 +56,7 @@
G_add_keyword(_("geometry"));
+ G_add_keyword(_("mosaicking"));
_("Creates a composite raster map layer by using "
"known category values from one (or more) map layer(s) "
Modified: grass/trunk/raster/r.sim/r.sim.sediment/main.c
--- grass/trunk/raster/r.sim/r.sim.sediment/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/raster/r.sim/r.sim.sediment/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -108,6 +108,7 @@
G_add_keyword(_("hydrology"));
+ G_add_keyword(_("soil"));
G_add_keyword(_("sediment flow"));
G_add_keyword(_("erosion"));
G_add_keyword(_("deposition"));
Modified: grass/trunk/raster/r.sim/r.sim.water/main.c
--- grass/trunk/raster/r.sim/r.sim.water/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/raster/r.sim/r.sim.water/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -108,6 +108,9 @@
+ G_add_keyword(_("flow"));
+ G_add_keyword(_("overland flow"));
_("Overland flow hydrologic simulation using "
"path sampling method (SIMWE).");
Modified: grass/trunk/raster/r.slope.aspect/main.c
--- grass/trunk/raster/r.slope.aspect/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/raster/r.slope.aspect/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -150,6 +150,9 @@
G_add_keyword(_("terrain"));
+ G_add_keyword(_("aspect"));
+ G_add_keyword(_("slope"));
+ G_add_keyword(_("curvature"));
module->label = _("Generates raster maps of slope, aspect, curvatures and "
"partial derivatives from an elevation raster map.");
module->description = _("Aspect is calculated counterclockwise from east.");
Modified: grass/trunk/raster/r.usler/main.c
--- grass/trunk/raster/r.usler/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/raster/r.usler/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -52,6 +52,7 @@
G_add_keyword(_("rainfall"));
module->description = _("Computes USLE R factor, Rainfall erosivity index.");
Modified: grass/trunk/raster3d/r3.neighbors/main.c
--- grass/trunk/raster3d/r3.neighbors/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/raster3d/r3.neighbors/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -206,10 +206,13 @@
G_add_keyword(_("raster3d"));
+ G_add_keyword(_("algebra"));
+ G_add_keyword(_("statistics"));
+ G_add_keyword(_("aggregation"));
- G_add_keyword(_("aggregation"));
- G_add_keyword(_("statistics"));
_("Makes each voxel value a "
"function of the values assigned to the voxels "
Modified: grass/trunk/scripts/db.in.ogr/db.in.ogr.py
--- grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/scripts/db.in.ogr/db.in.ogr.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# AUTHOR(S): Markus Neteler
# PURPOSE: imports attribute tables in various formats
# Converted to Python by Glynn Clements
-# COPYRIGHT: (C) 2007, 2008 by Markus Neteler and the GRASS Development Team
+# COPYRIGHT: (C) 2007-2014 by Markus Neteler and the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -15,9 +15,10 @@
#%Module
-#% description: Imports attribute tables in various formats.
-#% keywords: database
-#% keywords: attribute table
+#% description: Imports attribute tables in various formats.
+#% keywords: database
+#% keywords: import
+#% keywords: attribute table
#%End
#%option G_OPT_F_BIN_INPUT
Modified: grass/trunk/scripts/db.out.ogr/db.out.ogr.py
--- grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/scripts/db.out.ogr/db.out.ogr.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -17,8 +17,8 @@
#%module
#% description: Exports attribute tables into various formats.
+#% keywords: export
-#% keywords: export
#%end
#%option G_OPT_V_INPUT
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.info/t.info.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -18,6 +18,7 @@
#% description: Lists information about space time datasets and maps.
#% keywords: metadata
+#% keywords: extent
#%end
#%option G_OPT_STDS_INPUT
Modified: grass/trunk/temporal/t.merge/t.merge.py
--- grass/trunk/temporal/t.merge/t.merge.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.merge/t.merge.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# AUTHOR(S): Soeren Gebbert
# PURPOSE: Merge several space time datasets into a single one
-# COPYRIGHT: (C) 2011 by the GRASS Development Team
+# COPYRIGHT: (C) 2011-2014 by the GRASS Development Team
# License (version 2). Read the file COPYING that comes with GRASS
Modified: grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py
--- grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.accdetect/t.rast.accdetect.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -18,6 +18,7 @@
#% description: Detects accumulation patterns in temporally accumulated space time raster datasets created by t.rast.accumulate.
#% keywords: accumulation
+#% keywords: raster
#%end
#%option G_OPT_STRDS_INPUT
Modified: grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py
--- grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.accumulate/t.rast.accumulate.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -18,6 +18,7 @@
#% description: Computes cyclic accumulations of a space time raster dataset.
#%end
Modified: grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py
--- grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.aggregate/t.rast.aggregate.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Temporally aggregates the maps of a space time raster dataset by a user defined granularity.
@@ -18,6 +18,7 @@
#% description: Aggregates temporally the maps of a space time raster dataset by a user defined granularity.
#% keywords: aggregation
#%end
Modified: grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py
--- grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.aggregate.ds/t.rast.aggregate.ds.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset
@@ -18,6 +18,7 @@
#% description: Aggregates data of an existing space time raster dataset using the time intervals of a second space time dataset.
#%end
Modified: grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py
--- grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.algebra/t.rast.algebra.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -20,6 +20,7 @@
#% description: Apply temporal and spatial operations on space time raster datasets using temporal raster algebra.
#% keywords: algebra
#%end
#%option
Modified: grass/trunk/temporal/t.rast.colors/t.rast.colors.py
--- grass/trunk/temporal/t.rast.colors/t.rast.colors.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.colors/t.rast.colors.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Creates/modifies the color table associated with each raster map of the space time raster dataset.
@@ -18,6 +18,7 @@
#% description: Creates/modifies the color table associated with each raster map of the space time raster dataset.
#% keywords: color table
#%end
Modified: grass/trunk/temporal/t.rast.export/t.rast.export.py
--- grass/trunk/temporal/t.rast.export/t.rast.export.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.export/t.rast.export.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Export a space time raster dataset
@@ -18,6 +18,7 @@
#% description: Exports space time raster dataset.
#% keywords: export
#%end
Modified: grass/trunk/temporal/t.rast.extract/t.rast.extract.py
--- grass/trunk/temporal/t.rast.extract/t.rast.extract.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.extract/t.rast.extract.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Extract a subset of a space time raster dataset
@@ -18,6 +18,7 @@
#% description: Extracts a subset of a space time raster datasets.
#% keywords: extract
#%end
Modified: grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py
--- grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.gapfill/t.rast.gapfill.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -18,6 +18,7 @@
#% description: Replaces gaps in a space time raster dataset with interpolated raster maps.
#% keywords: interpolation
#%end
Modified: grass/trunk/temporal/t.rast.import/t.rast.import.py
--- grass/trunk/temporal/t.rast.import/t.rast.import.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.import/t.rast.import.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -18,6 +18,7 @@
#% description: Imports space time raster dataset.
#% keywords: import
#%end
#%option G_OPT_F_INPUT
Modified: grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py
--- grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.mapcalc/t.rast.mapcalc.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -18,6 +18,7 @@
#% description: Performs spatio-temporal mapcalc expressions on temporally sampled maps of space time raster datasets.
#%end
#%option G_OPT_STRDS_INPUTS
Modified: grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py
--- grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.neighbors/t.rast.neighbors.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -19,6 +19,7 @@
#% description: Performs a neighborhood analysis for each map in a space time raster dataset.
#%end
Modified: grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py
--- grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.out.vtk/t.rast.out.vtk.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Export space time raster dataset as VTK time series
Modified: grass/trunk/temporal/t.rast.series/t.rast.series.py
--- grass/trunk/temporal/t.rast.series/t.rast.series.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.series/t.rast.series.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -7,7 +7,7 @@
# PURPOSE: Perform different aggregation algorithms from r.series on all or a
# selected subset of raster maps in a space time raster dataset
@@ -19,6 +19,7 @@
#% description: Performs different aggregation algorithms from r.series on all or a subset of raster maps in a space time raster dataset.
#% keywords: series
#%end
Modified: grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py
--- grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast.to.rast3/t.rast.to.rast3.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -18,7 +18,9 @@
#% description: Converts a space time raster dataset into a 3D raster map.
#% keywords: conversion
#% keywords: raster3d
+#% keywords: voxel
#%end
Modified: grass/trunk/temporal/t.rast3d.algebra/t.rast3d.algebra.py
--- grass/trunk/temporal/t.rast3d.algebra/t.rast3d.algebra.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast3d.algebra/t.rast3d.algebra.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -20,6 +20,8 @@
#% description: Apply temporal and spatial operations on space time 3D raster datasets using temporal 3D raster algebra.
+#% keywords: raster3d
+#% keywords: voxel
#%end
#%option
Modified: grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py
--- grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast3d.extract/t.rast3d.extract.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -18,6 +18,8 @@
#% description: Extracts a subset of a space time 3D raster dataset.
+#% keywords: voxel
#%end
#%option G_OPT_STR3DS_INPUT
Modified: grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py
--- grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast3d.list/t.rast3d.list.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -18,8 +18,9 @@
#% description: Lists registered maps of a space time raster3d dataset.
#% keywords: map management
+#% keywords: list
-#% keywords: list
+#% keywords: voxel
#%end
Modified: grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py
--- grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast3d.mapcalc/t.rast3d.mapcalc.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -18,6 +18,8 @@
#% description: Performs r3.mapcalc expressions on maps of sampled space time 3D raster datasets.
+#% keywords: voxel
#%end
#%option G_OPT_STR3DS_INPUTS
Modified: grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py
--- grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rast3d.univar/t.rast3d.univar.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -19,7 +19,8 @@
#% description: Calculates univariate statistics from the non-null cells for each registered 3D raster map of a space time 3D raster dataset.
#% keywords: statistics
-#% keywords: raster
+#% keywords: voxel
#%end
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.remove/t.remove.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Remove space time datasets from the temporal database
Modified: grass/trunk/temporal/t.rename/t.rename.py
--- grass/trunk/temporal/t.rename/t.rename.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.rename/t.rename.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Renames a space time dataset
Modified: grass/trunk/temporal/t.select/t.select.py
--- grass/trunk/temporal/t.select/t.select.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.select/t.select.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -7,7 +7,7 @@
# PURPOSE: Select maps from space time datasets by topological relationships to
# other space time datasets using temporal algebra.
Modified: grass/trunk/temporal/t.snap/t.snap.py
--- grass/trunk/temporal/t.snap/t.snap.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.snap/t.snap.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -17,7 +17,7 @@
#%module
#% description: Snaps temporally the maps of a space time dataset.
-#% keywords: snap
+#% keywords: snapping
#%end
Modified: grass/trunk/temporal/t.support/t.support.py
--- grass/trunk/temporal/t.support/t.support.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.support/t.support.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Modify the metadata of a space time dataset
Modified: grass/trunk/temporal/t.vect.algebra/t.vect.algebra.py
--- grass/trunk/temporal/t.vect.algebra/t.vect.algebra.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.vect.algebra/t.vect.algebra.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -20,6 +20,7 @@
#% description: Apply temporal and spatial oeprations on space time vector datasets using temporal vector algebra.
+#% keywords: vector
#%end
#%option
Modified: grass/trunk/temporal/t.vect.export/t.vect.export.py
--- grass/trunk/temporal/t.vect.export/t.vect.export.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.vect.export/t.vect.export.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Export a space time vector dataset.as GRASS specific archive file
@@ -18,6 +18,7 @@
#% description: Exports a space time vector dataset as GRASS GIS specific archive file.
#% keywords: export
#%end
#%option G_OPT_STVDS_INPUT
Modified: grass/trunk/temporal/t.vect.extract/t.vect.extract.py
--- grass/trunk/temporal/t.vect.extract/t.vect.extract.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.vect.extract/t.vect.extract.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Extract a subset of a space time vector dataset
@@ -18,6 +18,7 @@
#% description: Extracts a subset of a space time vector dataset.
#%end
Modified: grass/trunk/temporal/t.vect.import/t.vect.import.py
--- grass/trunk/temporal/t.vect.import/t.vect.import.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.vect.import/t.vect.import.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -18,6 +18,7 @@
#% description: Imports a space time vector dataset from a GRASS GIS specific archive file.
#% keywords: import
#%end
Modified: grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py
--- grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.vect.observe.strds/t.vect.observe.strds.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Observe specific locations in a space time raster dataset over a period of time using vector points
@@ -18,6 +18,7 @@
#% description: Observes specific locations in a space time raster dataset over a period of time using vector points.
#% keywords: sampling
#%end
Modified: grass/trunk/temporal/t.vect.univar/t.vect.univar.py
--- grass/trunk/temporal/t.vect.univar/t.vect.univar.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.vect.univar/t.vect.univar.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Calculates univariate statistics of attributes for each registered vector map of a space time vector dataset
Modified: grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py
--- grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/temporal/t.vect.what.strds/t.vect.what.strds.py 2014-12-03 08:31:27 UTC (rev 63345)
@@ -6,7 +6,7 @@
# PURPOSE: Store raster map values at spatial and temporal positions of vector points as vector attributes.
@@ -18,6 +18,7 @@
#% description: Stores raster map values at spatial and temporal positions of vector points as vector attributes.
#%end
Modified: grass/trunk/vector/v.clean/main.c
--- grass/trunk/vector/v.clean/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/vector/v.clean/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -51,6 +51,7 @@
G_add_keyword(_("vector"));
G_add_keyword(_("topology"));
+ G_add_keyword(_("snapping"));
module->description = _("Toolset for cleaning topology of vector map.");
opt.in = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/v.db.select/main.c
--- grass/trunk/vector/v.db.select/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/vector/v.db.select/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -53,6 +53,7 @@
G_add_keyword(_("attribute table"));
G_add_keyword(_("database"));
+ G_add_keyword(_("SQL"));
module->description = _("Prints vector map attributes.");
map_opt = G_define_standard_option(G_OPT_V_MAP);
Modified: grass/trunk/vector/v.lrs/v.lrs.create/main.c
--- grass/trunk/vector/v.lrs/v.lrs.create/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/vector/v.lrs/v.lrs.create/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -120,7 +120,7 @@
G_add_keyword(_("Linear Reference System"));
- G_add_keyword(_("networking"));
+ G_add_keyword(_("network"));
module->description = _("Creates a linear reference system.");
in_lines_opt = G_define_standard_option(G_OPT_V_INPUT);
Modified: grass/trunk/vector/v.lrs/v.lrs.label/main.c
--- grass/trunk/vector/v.lrs/v.lrs.label/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/vector/v.lrs/v.lrs.label/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -101,7 +101,7 @@
module->description = _("Creates stationing from input lines, "
"and linear reference system.");
Modified: grass/trunk/vector/v.lrs/v.lrs.segment/main.c
--- grass/trunk/vector/v.lrs/v.lrs.segment/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/vector/v.lrs/v.lrs.segment/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -70,7 +70,7 @@
_("Creates points/segments from input lines, linear reference "
"system and positions read from stdin or a file.");
Modified: grass/trunk/vector/v.lrs/v.lrs.where/main.c
--- grass/trunk/vector/v.lrs/v.lrs.where/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/vector/v.lrs/v.lrs.where/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -56,7 +56,7 @@
_("Finds line id and real km+offset for given points in vector map "
"using linear reference system.");
Modified: grass/trunk/vector/v.net.alloc/main.c
--- grass/trunk/vector/v.net.alloc/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/vector/v.net.alloc/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -63,7 +63,7 @@
- G_add_keyword(_("allocation"));
+ G_add_keyword(_("cost allocation"));
module->label =
_("Allocates subnets for nearest centers (direction from center).");
Modified: grass/trunk/vector/v.out.dxf/main.c
--- grass/trunk/vector/v.out.dxf/main.c 2014-12-03 03:33:26 UTC (rev 63344)
+++ grass/trunk/vector/v.out.dxf/main.c 2014-12-03 08:31:27 UTC (rev 63345)
@@ -55,6 +55,7 @@
G_add_keyword(_("export"));
+ G_add_keyword(_("DXF"));
_("Exports vector map to DXF file format.");
