[GRASS-SVN] r63375 - grass-addons/grass7/vector/v.kriging
Fri Dec 5 06:38:18 PST 2014
Author: martinl
Date: 2014-12-05 06:38:18 -0800 (Fri, 05 Dec 2014)
New Revision: 63375
   grass-addons/grass7/vector/v.kriging/main.cpp
v.kriging: fix compilation (please do testing before you commit anything to SVN)
Modified: grass-addons/grass7/vector/v.kriging/main.cpp
--- grass-addons/grass7/vector/v.kriging/main.cpp	2014-12-05 14:34:33 UTC (rev 63374)
+++ grass-addons/grass7/vector/v.kriging/main.cpp	2014-12-05 14:38:18 UTC (rev 63375)
@@ -49,18 +49,10 @@
   module = G_define_module();
   G_add_keyword(_("raster"));
   G_add_keyword(_("3D raster"));
-<<<<<<< .mine
   G_add_keyword(_("ordinary kriging - for 2D and 3D data"));
   module->description =
     _("Interpolates 2D or 3D raster based on input values located on 2D or 3D point vector layer (method ordinary kriging extended to 3D).");
-  G_add_keyword(_("ordinary kriging"));
-  module->label =
-    _("Interpolates 2D or 3D raster map based on input values located on 2D or 3D vector point map.");
-  module->description = _("Method ordinary kriging extended to 3D.");
->>>>>>> .r62698
   // Setting options
   opt.input = G_define_standard_option(G_OPT_V_INPUT); // Vector input layer
   opt.input->label = _("Name of input vector points map");
