[GRASS-SVN] r63387 - grass/branches/releasebranch_7_0/lib/python/script
svn_grass at osgeo.org
Fri Dec 5 11:00:24 PST 2014
Author: neteler
Date: 2014-12-05 11:00:24 -0800 (Fri, 05 Dec 2014)
New Revision: 63387
grass/branches/releasebranch_7_0/lib/python/script/core.py
libpython make_command(): say in msg which module call needs an update (trunk, r63385)
Modified: grass/branches/releasebranch_7_0/lib/python/script/core.py
--- grass/branches/releasebranch_7_0/lib/python/script/core.py 2014-12-05 18:51:33 UTC (rev 63386)
+++ grass/branches/releasebranch_7_0/lib/python/script/core.py 2014-12-05 19:00:24 UTC (rev 63387)
@@ -280,11 +280,11 @@
if val != None:
if opt.startswith('_'):
opt = opt[1:]
- warning(_("To run the module add underscore at the end"
+ warning(_("To run the module <%s> add underscore at the end"
" of the option <%s> to avoid conflict with Python"
" keywords. Underscore at the beginning is"
" depreciated in GRASS GIS 7.0 and will be removed"
- " in version 7.1.") % opt)
+ " in version 7.1.") % (prog, opt))
elif opt.endswith('_'):
opt = opt[:-1]
args.append("%s=%s" % (opt, _make_val(val)))
