[GRASS-SVN] r63390 - in grass-addons/grass7/imagery: . i.theilsen
svn_grass at osgeo.org
Fri Dec 5 21:59:31 PST 2014
Author: ychemin
Date: 2014-12-05 21:59:31 -0800 (Fri, 05 Dec 2014)
New Revision: 63390
Added:
grass-addons/grass7/imagery/i.theilsen/
grass-addons/grass7/imagery/i.theilsen/Makefile
grass-addons/grass7/imagery/i.theilsen/i.theilsen.html
grass-addons/grass7/imagery/i.theilsen/main.c
grass-addons/grass7/imagery/Makefile
Added Theil-Sen spectral/temporal trend estimator
Modified: grass-addons/grass7/imagery/Makefile
--- grass-addons/grass7/imagery/Makefile 2014-12-05 21:15:19 UTC (rev 63389)
+++ grass-addons/grass7/imagery/Makefile 2014-12-06 05:59:31 UTC (rev 63390)
@@ -20,6 +20,7 @@
i.segment.gsoc \
i.segment.hierarchical \
i.spec.unmix \
+ i.theilsen \
i.vi.mpi \
i.wavelet
Added: grass-addons/grass7/imagery/i.theilsen/Makefile
--- grass-addons/grass7/imagery/i.theilsen/Makefile (rev 0)
+++ grass-addons/grass7/imagery/i.theilsen/Makefile 2014-12-06 05:59:31 UTC (rev 63390)
@@ -0,0 +1,11 @@
+MODULE_TOPDIR = ../..
+PGM = i.theilsen
+LIBES = $(IMAGERYLIB) $(RASTERLIB) $(GISLIB)
+DEPENDENCIES = $(IMAGERYDEP) $(RASTERDEP) $(GISDEP)
+include $(MODULE_TOPDIR)/include/Make/Module.make
+default: cmd
Added: grass-addons/grass7/imagery/i.theilsen/i.theilsen.html
--- grass-addons/grass7/imagery/i.theilsen/i.theilsen.html (rev 0)
+++ grass-addons/grass7/imagery/i.theilsen/i.theilsen.html 2014-12-06 05:59:31 UTC (rev 63390)
@@ -0,0 +1,20 @@
+<h2>DESCRIPTION</h2>
+<em>i.theilsen</em>
+A method for robust linear regression.
+Output is the median slope from all pairs slopes.
+It is known for its resistance to outliers.
+<h2>NOTES</h2>
+<H2>REFERENCES</H2>
+https://en.wikipedia.org/wiki/Theil-Sen_estimator
+<h2>AUTHORS</h2>
+Yann Chemin, IWMI, Sri Lanka.
+<p><i>Last changed: $Date: 2014-12-05 15:06:47 +0530 (Friday, 05 Dec 2014) $</i>
Added: grass-addons/grass7/imagery/i.theilsen/main.c
--- grass-addons/grass7/imagery/i.theilsen/main.c (rev 0)
+++ grass-addons/grass7/imagery/i.theilsen/main.c 2014-12-06 05:59:31 UTC (rev 63390)
@@ -0,0 +1,256 @@
+ * MODULE: i.theilsen
+ * AUTHOR(S): Yann Chemin - yann.chemin at gmail.com
+ * PURPOSE: Calculate spectral/temporal Theil-Sen estimator
+ * https://en.wikipedia.org/wiki/Theil-Sen_estimator
+ * COPYRIGHT: (C) 2014 by the GRASS Development Team
+ * This program is free software under the GNU Lesser General Public
+ * License. Read the file COPYING that comes with GRASS for details.
+#include <stdio.h>
+#include <stdlib.h>
+#include <grass/imagery.h>
+#include <grass/glocale.h>
+/* Separate function for opening maps (see after main function) */
+char *group;
+char *subgroup;
+struct Ref ref;
+DCELL **cell;
+int *cellfd;
+int open_files(void);
+int main(int argc, char *argv[])
+ int nrows, ncols;
+ int row, col;
+ struct GModule *module;
+ struct Option *grp, *sgrp, *out0, *out1;
+ struct History history; /*metadata */
+ struct Colors colors; /*Color rules */
+ int outfd0, outfd1;
+ int nfiles=0, count=0, n=0, n0=0, n1=0, n0n1=0;
+ DCELL *signal;/*spectral/temporal signal*/
+ DCELL *sorted;/*spectral/temporal sorted slope*/
+ DCELL **slope;/*Theil-Sen slope matrix*/
+ float max=0.0;/*value total max for colour palette */
+ float min=0.0;/*value total min for colour palette */
+ float mk_max=0.0;/*Mann-Kendall total max for colour palette */
+ float mk_min=0.0;/*Mann-Kendall total min for colour palette */
+ float temp=0.0;/*swapping temp value*/
+ DCELL *outrast0, *outrast1;
+ CELL val1, val2;
+ G_gisinit(argv[0]);
+ module = G_define_module();
+ G_add_keyword(_("imagery"));
+ G_add_keyword(_("Theil-Sen"));
+ G_add_keyword(_("Estimator"));
+ G_add_keyword(_("Mann-Kendall"));
+ module->description = _("Computes Theil-Sen estimator from spectrum.");
+ /* Define the different options */
+ grp = G_define_standard_option(G_OPT_I_GROUP);
+ grp->description = _("Name of imagery group");
+ sgrp = G_define_standard_option(G_OPT_I_SUBGROUP);
+ sgrp->description = _("Name of imagery subgroup");
+ out0 = G_define_standard_option(G_OPT_R_OUTPUT);
+ out0->description = _("Name of Theil-Sen slope map");
+ out1 = G_define_standard_option(G_OPT_R_OUTPUT);
+ out1->description = _("Name of Mann-Kendall test map");
+ if (G_parser(argc, argv)) exit(EXIT_FAILURE);
+ nrows = Rast_window_rows();
+ ncols = Rast_window_cols();
+ /* Allocate output buffer, use input map data_type */
+ outrast0 = Rast_allocate_buf(DCELL_TYPE);
+ outrast1 = Rast_allocate_buf(DCELL_TYPE);
+ /* Create New raster files */
+ outfd0 = Rast_open_new(out0->answer,DCELL_TYPE);
+ outfd1 = Rast_open_new(out1->answer,DCELL_TYPE);
+ /* Open input files */
+ nfiles = open_files();
+ /* Allocate spectral pixel memory */
+ signal = (DCELL *) G_malloc(nfiles * sizeof(DCELL));
+ /* Allocate Theil-Sen Slope Matrix */
+ slope = (DCELL **) G_malloc(nfiles*nfiles*sizeof(DCELL));
+ /* Allocate 1D Theil-Sen Slope sorting array */
+ sorted = (DCELL *) G_malloc(nfiles*nfiles*sizeof(DCELL));
+ /* Process pixels */
+ count = 0;
+ for (row=0; row<nrows; row++) {
+ G_percent(row, nrows, 2);
+ for (n=0; n<nfiles; n++)
+ Rast_get_d_row(cellfd[n], cell[n], row);
+ for (col=0; col<ncols; col++) {
+ count++;
+ signal[n] = cell[n][col];
+ /* Combinatorics of all in all pairs slopes */
+ /* x-axis is spectral/temporal dim., index n is its value */
+ /* y-axis is from cell[n] */
+ /* Duplicate n index as matrix axis */
+ n0=0;
+ n1=0;
+ for (n0=0; n0<n; n0++){
+ for (n1=0; n1<n; n1++){
+ /* Compute outside of diagonal */
+ if(n0!=n1)
+ slope[n0][n1]=(cell[n1]-cell[n0])/(n1-n0);
+ /* Sorting all slopes computed */
+ n0n1=0;
+ /* Reduce dimensionality */
+ if(n0!=n1){
+ sorted[n0n1]=slope[n0][n1];
+ n0n1++;
+ /* Actual Sorting, needs to transport max n0n1 length */
+ for (n0=0;n0<n0n1;n0++){
+ for (n=1; n<n0n1; n++){
+ if(sorted[n-1]>sorted[n]){
+ temp=sorted[n];
+ sorted[n]=sorted[n-1];
+ sorted[n-1]=temp;
+ /* Extract median slope (list halfway) */
+ outrast0[col] = sorted[n0n1/2];
+ /* Prepare Theil-Sen colour palette range from data */
+ if (sorted[n0n1/2]<min)
+ min=sorted[n0n1/2];
+ if (sorted[n0n1/2]>max)
+ max=sorted[n0n1/2];
+ /* Mann-Kendall Trend Test */
+ /* Not yet implemented */
+ mk_min=min;
+ mk_max=max;
+ outrast1[col] = sorted[n0n1/2];
+ Rast_put_d_row(outfd0, outrast0);
+ /* Rast_put_d_row(outfd1, outrast1);*/
+ Rast_put_d_row(outfd1, outrast1);
+ for (n = 0; n < nfiles; n++) {
+ G_free(cell[n]);
+ G_free(slope[n]);
+ Rast_close(cellfd[n]);
+ G_free(signal);
+ G_free(sorted);
+ G_free(outrast0);
+ G_free(outrast1);
+ Rast_close(outfd0);
+ Rast_close(outfd1);
+ /* For the time being dont touch this */
+ /* Color table from slope min to slope max */
+ Rast_init_colors(&colors);
+ val1 = min;
+ val2 = max;
+ Rast_add_c_color_rule(&val1, 0, 0, 0, &val2, 255, 255, 255, &colors);
+ /* Metadata */
+ Rast_short_history(out0->answer, "raster", &history);
+ Rast_command_history(&history);
+ Rast_write_history(out0->answer, &history);
+ /* Color table from Mann-Kendall test min and max */
+ val1 = mk_min;
+ val2 = mk_max;
+ /* Metadata */
+ Rast_short_history(out1->answer, "raster", &history);
+ Rast_write_history(out1->answer, &history);
+ exit(EXIT_SUCCESS);
+/* Separate function for opening maps */
+ char *name, *mapset;
+ int n, missing;
+ I_init_group_ref(&ref);
+ G_strip(group);
+ if (!I_find_group(group))
+ G_fatal_error(_("Group <%s> not found in current mapset"), group);
+ G_strip(subgroup);
+ if (!I_find_subgroup(group, subgroup))
+ G_fatal_error(_("Subgroup <%s> in group <%s> not found"),
+ subgroup, group);
+ I_free_group_ref(&ref);
+ I_get_subgroup_ref(group, subgroup, &ref);
+ missing = 0;
+ for (n = 0; n < ref.nfiles; n++) {
+ name = ref.file[n].name;
+ mapset = ref.file[n].mapset;
+ if (G_find_raster(name, mapset) == NULL) {
+ missing = 1;
+ G_warning(_("Raster map <%s> do not exists in subgroup <%s>"),
+ G_fully_qualified_name(name, mapset), subgroup);
+ if (missing)
+ G_fatal_error(_("No raster maps found"));
+ if (ref.nfiles <= 1) {
+ if (ref.nfiles <= 0)
+ G_warning(_("Subgroup <%s> doesn't have any raster maps"),
+ subgroup);
+ else
+ G_warning(_("Subgroup <%s> only has 1 raster map"), subgroup);
+ G_fatal_error(_("Subgroup must have at least 2 raster maps"));
+ cell = (DCELL **) G_malloc(ref.nfiles * sizeof(DCELL *));
+ cellfd = (int *)G_malloc(ref.nfiles * sizeof(int));
+ cell[n] = Rast_allocate_d_buf();
+ cellfd[n] = Rast_open_old(name, mapset);
+ return(ref.nfiles);
