[GRASS-SVN] r63409 - grass/trunk/lib/init
Sun Dec 7 01:58:01 PST 2014
Author: martinl
Date: 2014-12-07 01:58:01 -0800 (Sun, 07 Dec 2014)
New Revision: 63409
   grass/trunk/lib/init/variables.html
r63408: improve wording
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html	2014-12-07 09:53:57 UTC (rev 63408)
+++ grass/trunk/lib/init/variables.html	2014-12-07 09:58:01 UTC (rev 63409)
@@ -344,7 +344,9 @@
   <dd>defines the height of output image (default is 480).</dd>
   <dt>GRASS_RENDER_FRAME</dt>
-  <dd>contains 4 coordinates, <em>top,bottom,left,right</em> (pixel values) from top-left corner, defining the initial frame.</dd>
+  <dd>contains 4 coordinates, <em>top,bottom,left,right</em> (pixel
+  values) with respect to the top left corner of the output image,
+  defining the initial frame.</dd>
   <dt>GRASS_RENDER_LINE_WIDTH</dt>
   <dd>defines default line width.</dd>
