[GRASS-SVN] r63424 - in grass/trunk/gui/wxpython: lmgr mapdisp mapwin
svn_grass at osgeo.org
Sun Dec 7 07:29:56 PST 2014
Author: martinl
Date: 2014-12-07 07:29:56 -0800 (Sun, 07 Dec 2014)
New Revision: 63424
grass/trunk/gui/wxpython/lmgr/giface.py
grass/trunk/gui/wxpython/mapdisp/frame.py
grass/trunk/gui/wxpython/mapdisp/main.py
grass/trunk/gui/wxpython/mapdisp/statusbar.py
grass/trunk/gui/wxpython/mapwin/buffered.py
wxGUI: allow to hide/show toolbars and statusbar in map display
Modified: grass/trunk/gui/wxpython/lmgr/giface.py
--- grass/trunk/gui/wxpython/lmgr/giface.py 2014-12-07 13:38:13 UTC (rev 63423)
+++ grass/trunk/gui/wxpython/lmgr/giface.py 2014-12-07 15:29:56 UTC (rev 63424)
@@ -194,8 +194,24 @@
def UpdateCmdHistory(self, cmd):
self.lmgr.goutput.GetPrompt().UpdateCmdHistory(cmd)
+ def ShowStatusbar(self, show=True):
+ self.lmgr.GetMapDisplay().statusbarManager.Show(show)
+ def IsStatusbarShown(self):
+ return self.lmgr.GetMapDisplay().statusbarManager.IsShown()
+ def ShowAllToolbars(self, show=True):
+ if not show: # hide
+ action = self.lmgr.GetMapDisplay().RemoveToolbar
+ else:
+ action = self.lmgr.GetMapDisplay().AddToolbar
+ for toolbar in self.lmgr.GetMapDisplay().GetToolbarNames():
+ action(toolbar)
+ def AreAllToolbarsShown(self):
+ return self.lmgr.GetMapDisplay().GetMapToolbar().IsShown()
class LayerManagerGrassInterfaceForMapDisplay(object):
"""Provides reference only to the given layer list (according to tree),
not to the current.
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py 2014-12-07 13:38:13 UTC (rev 63423)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py 2014-12-07 15:29:56 UTC (rev 63424)
@@ -298,9 +298,10 @@
elif self._mgr.GetPane('3d').IsShown():
self._mgr.GetPane('3d').Hide()
self._mgr.GetPane('vdigit').Show()
- self.toolbars['vdigit'] = VDigitToolbar(parent=self, toolSwitcher=self._toolSwitcher,
- MapWindow = self.MapWindow,
- digitClass=VDigit, giface=self._giface)
+ if 'vdigit' not in self.toolbars:
+ self.toolbars['vdigit'] = VDigitToolbar(parent=self, toolSwitcher=self._toolSwitcher,
+ MapWindow = self.MapWindow,
+ digitClass=VDigit, giface=self._giface)
self.MapWindowVDigit.SetToolbar(self.toolbars['vdigit'])
self._mgr.AddPane(self.toolbars['vdigit'],
@@ -463,7 +464,8 @@
# default toolbar
if name == "map":
- self.toolbars['map'] = MapToolbar(self, toolSwitcher=self._toolSwitcher)
+ if 'map' not in self.toolbars:
+ self.toolbars['map'] = MapToolbar(self, toolSwitcher=self._toolSwitcher)
self._mgr.AddPane(self.toolbars['map'],
wx.aui.AuiPaneInfo().
@@ -484,20 +486,19 @@
self._mgr.Update()
- def RemoveToolbar (self, name):
+ def RemoveToolbar (self, name, destroy=False):
"""Removes defined toolbar from the window
- .. todo::
- Only hide, activate by calling AddToolbar()
+ :param name toolbar to remove
+ :param destroy True to destroy otherwise toolbar is only hidden
- # cannot hide main toolbar
- if name == "map":
- return
self._mgr.DetachPane(self.toolbars[name])
self._toolSwitcher.RemoveToolbarFromGroup('mouseUse', self.toolbars[name])
- self.toolbars[name].Destroy()
- self.toolbars.pop(name)
+ if destroy:
+ self.toolbars[name].Destroy()
+ self.toolbars.pop(name)
+ else:
+ self.toolbars[name].Hide()
if name == 'vdigit':
self._mgr.GetPane('vdigit').Hide()
@@ -1412,8 +1413,12 @@
def GetMapToolbar(self):
"""Returns toolbar with zooming tools"""
- return self.toolbars['map']
+ return self.toolbars['map'] if 'map' in self.toolbars else None
+ def GetToolbarNames(self):
+ """Return toolbar names"""
+ return self.toolbars.keys()
def OnVNet(self, event):
"""Dialog for v.net* modules
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py 2014-12-07 13:38:13 UTC (rev 63423)
+++ grass/trunk/gui/wxpython/mapdisp/main.py 2014-12-07 15:29:56 UTC (rev 63424)
@@ -327,7 +327,7 @@
def __init__(self, mapframe):
StandaloneGrassInterface.__init__(self)
self._mapframe = mapframe
def GetLayerList(self):
return LayerList(self._mapframe.GetMap(), giface=self)
@@ -337,7 +337,23 @@
def GetProgress(self):
return self._mapframe.GetProgressBar()
+ self._mapframe.statusbarManager.Show(show)
+ return self._mapframe.statusbarManager.IsShown()
+ action = self._mapframe.RemoveToolbar
+ else:
+ action = self._mapframe.AddToolbar
+ for toolbar in self._mapframe.GetToolbarNames():
+ action(toolbar)
+ return self._mapframe.GetMapToolbar().IsShown()
class DMonFrame(MapFrame):
def OnZoomToMap(self, event):
layers = self.MapWindow.GetMap().GetListOfLayers()
Modified: grass/trunk/gui/wxpython/mapdisp/statusbar.py
--- grass/trunk/gui/wxpython/mapdisp/statusbar.py 2014-12-07 13:38:13 UTC (rev 63423)
+++ grass/trunk/gui/wxpython/mapdisp/statusbar.py 2014-12-07 15:29:56 UTC (rev 63424)
@@ -319,7 +319,15 @@
self.progressbar.SetValue(value)
if text:
self.statusbar.SetStatusText(text)
+ def Show(self, show=True):
+ """Show/hide statusbar"""
+ self.statusbar.Show(show)
+ def IsShown(self):
+ """Check if statusbar is shown"""
+ return self.statusbar.IsShown()
class SbItem:
"""Base class for statusbar items.
Modified: grass/trunk/gui/wxpython/mapwin/buffered.py
--- grass/trunk/gui/wxpython/mapwin/buffered.py 2014-12-07 13:38:13 UTC (rev 63423)
+++ grass/trunk/gui/wxpython/mapwin/buffered.py 2014-12-07 15:29:56 UTC (rev 63424)
@@ -232,10 +232,23 @@
self.popupCopyCoordinates = wx.NewId()
self.Bind(wx.EVT_MENU, self.OnCopyCoordinates, id = self.popupCopyCoordinates)
menu.Append(self.popupCopyCoordinates, _("Copy coordinates to clipboard"))
+ menu.AppendSeparator()
+ if not hasattr(self, "popupShowAllToolbars"):
+ self.popupShowAllToolbars = wx.NewId()
+ self.Bind(wx.EVT_MENU, self.OnShowAllToolbars, id = self.popupShowAllToolbars)
+ menu.Append(self.popupShowAllToolbars, _("Hide all toolbars") if self._giface.AreAllToolbarsShown() else _("Show all toolbars"))
+ if not hasattr(self, "popupShowStatusbar"):
+ self.popupShowStatusbar = wx.NewId()
+ self.Bind(wx.EVT_MENU, self.OnShowStatusbar, id = self.popupShowStatusbar)
+ menu.Append(self.popupShowStatusbar, _("Hide statusbar") if self._giface.IsStatusbarShown() else _("Show statusbar"))
pos = self.ScreenToClient(event.GetPosition())
idlist = self.pdc.FindObjects(pos[0], pos[1], self.hitradius)
+ separator = True
if idlist and idlist[0] in (0, 1, 2): # legend, scale bar, north arrow
+ if separator:
+ separator = False
self._hide = wx.NewId()
lambda evt: self.overlayHidden.emit(overlayId=idlist[0]),
@@ -1542,6 +1555,14 @@
wx.TheClipboard.SetData(do)
wx.TheClipboard.Close()
+ def OnShowStatusbar(self, event):
+ self._giface.ShowStatusbar(not self._giface.IsStatusbarShown())
+ def OnShowAllToolbars(self, event):
+ """Show/hide all toolbars"""
+ self._giface.ShowAllToolbars(not self._giface.AreAllToolbarsShown())
def ClearLines(self, pdc = None):
"""Clears temporary drawn lines from PseudoDC
