[GRASS-SVN] r63436 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Mon Dec 8 04:13:44 PST 2014
Author: martinl
Date: 2014-12-08 04:13:44 -0800 (Mon, 08 Dec 2014)
New Revision: 63436
grass/trunk/gui/wxpython/core/gcmd.py
wxGUI: RunCommand() avoid non-sense debug messages
Modified: grass/trunk/gui/wxpython/core/gcmd.py
--- grass/trunk/gui/wxpython/core/gcmd.py 2014-12-08 12:08:23 UTC (rev 63435)
+++ grass/trunk/gui/wxpython/core/gcmd.py 2014-12-08 12:13:44 UTC (rev 63436)
@@ -689,7 +689,6 @@
messageFormat = os.getenv('GRASS_MESSAGE_FORMAT', 'gui')
os.environ['GRASS_MESSAGE_FORMAT'] = 'standard'
- Debug.msg(2, "gcmd.RunCommand(): command started")
start = time.time()
ps = grass.start_command(prog, flags, overwrite, quiet, verbose, **kwargs)
@@ -699,7 +698,6 @@
ps.stdin.close()
ps.stdin = None
- Debug.msg(3, "gcmd.RunCommand(): decoding string")
stdout, stderr = map(DecodeString, ps.communicate())
if parent: # restore previous settings
@@ -709,7 +707,6 @@
Debug.msg(1, "gcmd.RunCommand(): get return code %d (%.6f sec)" % \
(ret, (time.time() - start)))
- Debug.msg(3, "gcmd.RunCommand(): print error")
if ret != 0:
if stderr:
Debug.msg(2, "gcmd.RunCommand(): error %s" % stderr)
@@ -721,7 +718,6 @@
caption = _("Error in %s") % prog,
message = stderr)
- Debug.msg(3, "gcmd.RunCommand(): print read error")
if not read:
if not getErrorMsg:
return ret
@@ -729,9 +725,9 @@
return ret, _formatMsg(stderr)
if stdout:
- Debug.msg(2, "gcmd.RunCommand(): return stdout\n'%s'" % stdout)
+ Debug.msg(3, "gcmd.RunCommand(): return stdout\n'%s'" % stdout)
else:
- Debug.msg(2, "gcmd.RunCommand(): return stdout = None")
+ Debug.msg(3, "gcmd.RunCommand(): return stdout = None")
if parse:
stdout = parse(stdout)
@@ -739,11 +735,9 @@
if not getErrorMsg:
return stdout
- Debug.msg(2, "gcmd.RunCommand(): return ret, stdout")
if read and getErrorMsg:
return ret, stdout, _formatMsg(stderr)
- Debug.msg(2, "gcmd.RunCommand(): return result")
return stdout, _formatMsg(stderr)
def GetDefaultEncoding(forceUTF8 = False):
