[GRASS-SVN] r63444 - in grass-addons/grass7/misc/m.surf.nnbathy: libnnbathy r.surf.nnbathy v.surf.nnbathy
Mon Dec 8 08:01:19 PST 2014
Author: lazaa
Date: 2014-12-08 08:01:19 -0800 (Mon, 08 Dec 2014)
New Revision: 63444
   grass-addons/grass7/misc/m.surf.nnbathy/libnnbathy/nnbathy.py
   grass-addons/grass7/misc/m.surf.nnbathy/r.surf.nnbathy/r.surf.nnbathy.html
   grass-addons/grass7/misc/m.surf.nnbathy/v.surf.nnbathy/v.surf.nnbathy.html
   grass-addons/grass7/misc/m.surf.nnbathy/v.surf.nnbathy/v.surf.nnbathy.py
m.surf.nnbathy: use standardized key option names
                manual cosmetics
Modified: grass-addons/grass7/misc/m.surf.nnbathy/libnnbathy/nnbathy.py
--- grass-addons/grass7/misc/m.surf.nnbathy/libnnbathy/nnbathy.py	2014-12-08 15:48:24 UTC (rev 63443)
+++ grass-addons/grass7/misc/m.surf.nnbathy/libnnbathy/nnbathy.py	2014-12-08 16:01:19 UTC (rev 63444)
@@ -126,23 +126,17 @@
             _column = ''
         else:
             _layer = int(options['layer'])
-            if options['zcolumn']:
-                _column = options['zcolumn']
+            if options['column']:
+                _column = options['column']
             else:
                 grass.message('Name of z column required for 2D vector maps.')
         # convert vector to ASCII
-        if options['kwhere']:
-            grass.run_command("v.out.ascii", flags='r', overwrite=1,
-                              input=options['input'], output=self._tmpcat,
-                              format="point", separator="space", dp=15,
-                              where=options['kwhere'], layer=_layer,
-                              columns=_column)
-        else:
-                              layer=_layer, columns=_column)
+        grass.run_command("v.out.ascii", flags='r', overwrite=1,
+                          input=options['input'], output=self._tmpcat,
+                          format="point", separator="space", precision=15,
+                          where=options['where'], layer=_layer,
+                          columns=_column)
         # edit ASCII file, crop out one column
         if int(options['layer']) > 0:
Modified: grass-addons/grass7/misc/m.surf.nnbathy/r.surf.nnbathy/r.surf.nnbathy.html
--- grass-addons/grass7/misc/m.surf.nnbathy/r.surf.nnbathy/r.surf.nnbathy.html	2014-12-08 15:48:24 UTC (rev 63443)
+++ grass-addons/grass7/misc/m.surf.nnbathy/r.surf.nnbathy/r.surf.nnbathy.html	2014-12-08 16:01:19 UTC (rev 63444)
@@ -18,7 +18,7 @@
 <p>
 The <b>output</b> raster map is a continous surface interpolated from the
-<b>raster</b> data.
+<b>input</b> data.
 <h2>NOTES</h2>
@@ -29,7 +29,7 @@
 held in the memory.
 <ol>
-<li>Requires <em>GRASS</em> 6 and <em>nnbathy</em> 1.76 or greater.</li>
+<li>Requires <em>GRASS</em> 7 and <em>nnbathy</em> 1.76 or greater.</li>
 <li>Build <em>nnbathy</em> according to instructions provided with its source
 code and put it somewhere in your $PATH.</li>
 <li>The output raster map extent and resolution match the region settings at
@@ -50,6 +50,16 @@
 GRASS raster map would actually occupy.</li>
 </ol>
+<h2>EXAMPLE</h2>
+TODO
+<h2>REFERENCES</h2>
+<ul>
+  <li><a href="https://code.google.com/p/nn-c/">nnbathy</a> library by Pavel Sakov</li>
+</ul>
 <h2>SEE ALSO</h2>
 <em>
@@ -58,12 +68,13 @@
 <h2>AUTHOR</h2>
-Adam Laza (mentor: Martin Landa)<br>
+Adam Laza, Czech Technical University in Prague (mentor: Martin Landa)
+<p>
 based on v.surf.nnbathy from GRASS 6 by<br>
 Hamish Bowman, Otago University, New Zealand<br>
 Based on <em>r.surf.nnbathy</em> by Maciej Sieczka<br>
-<em><a href="https://code.google.com/p/nn-c/">nnbathy</a></em>
- written by Pavel Sakov
 <p>
 <i>Last changed: $Date$</i>
Modified: grass-addons/grass7/misc/m.surf.nnbathy/v.surf.nnbathy/v.surf.nnbathy.html
--- grass-addons/grass7/misc/m.surf.nnbathy/v.surf.nnbathy/v.surf.nnbathy.html	2014-12-08 15:48:24 UTC (rev 63443)
+++ grass-addons/grass7/misc/m.surf.nnbathy/v.surf.nnbathy/v.surf.nnbathy.html	2014-12-08 16:01:19 UTC (rev 63444)
@@ -29,7 +29,7 @@
 held in the memory.
 <ol>
@@ -50,20 +50,30 @@
 </ol>
+<h2>EXAMPLE</h2>
+TODO
+<ul>
+</ul>
 <h2>SEE ALSO</h2>
 <em>
   <a href="r.surf.nnbathy.html">r.surf.nnbathy</a>
 </em>
+<h2>AUTHOR</h2>
-<h2>AUTHOR</h2>
-based on v.surf.nnbathy from GRASS 6 by<br>
+<p>
+Based on v.surf.nnbathy from GRASS 6 by:<br>
 <p>
Modified: grass-addons/grass7/misc/m.surf.nnbathy/v.surf.nnbathy/v.surf.nnbathy.py
--- grass-addons/grass7/misc/m.surf.nnbathy/v.surf.nnbathy/v.surf.nnbathy.py	2014-12-08 15:48:24 UTC (rev 63443)
+++ grass-addons/grass7/misc/m.surf.nnbathy/v.surf.nnbathy/v.surf.nnbathy.py	2014-12-08 16:01:19 UTC (rev 63444)
@@ -59,14 +59,10 @@
 #% description: Name of output raster map
 #%end
 #%option G_OPT_DB_COLUMN
-#% key: zcolumn
 #% description: Name of the attribute column with values to be used for approximation (if layer>0)
 #% guisection: Settings
 #%end
 #%option G_OPT_DB_WHERE
-#% key: kwhere
-#% type: string
-#% label: WHERE conditions of SQL query statement without 'where' keyword
 #% guisection: Selection
 #%end
 #%option
