[GRASS-SVN] r63447 - grass/trunk/lib/python/pygrass/vector
svn_grass at osgeo.org
Tue Dec 9 00:08:08 PST 2014
Author: zarch
Date: 2014-12-09 00:08:08 -0800 (Tue, 09 Dec 2014)
New Revision: 63447
grass/trunk/lib/python/pygrass/vector/geometry.py
pygrass: add documentation to method segment
Modified: grass/trunk/lib/python/pygrass/vector/geometry.py
--- grass/trunk/lib/python/pygrass/vector/geometry.py 2014-12-08 18:17:38 UTC (rev 63446)
+++ grass/trunk/lib/python/pygrass/vector/geometry.py 2014-12-09 08:08:08 UTC (rev 63447)
@@ -919,8 +919,28 @@
libvect.Vect_line_reverse(self.c_points)
def segment(self, start, end):
- # TODO improve documentation
"""Create line segment. using the ``Vect_line_segment`` C function.
+ :param start: distance from the begining of the line where
+ the segment start
+ :type start: float
+ :param end: distance from the begining of the line where
+ the segment end
+ :type end: float
+ # x (1, 1)
+ # x--------x (1, 0)
+ # (0, 0) ^
+ >>> line = Line([(0, 0), (1, 0), (1, 1)])
+ >>> line.segment(0.5, 1.5) #doctest: +NORMALIZE_WHITESPACE
+ Line([Point(0.500000, 0.000000),
+ Point(1.000000, 0.000000),
+ Point(1.000000, 0.500000)])
line = Line()
libvect.Vect_line_segment(self.c_points, start, end, line.c_points)
