[GRASS-SVN] r63451 - in grass/trunk: display/d.vect.chart general/g.copy general/g.filename general/g.findfile general/g.list general/g.message general/g.proj general/g.rename general/g.version imagery/i.albedo imagery/i.aster.toar imagery/i.biomass imagery/i.eb.eta imagery/i.eb.hsebal01 imagery/i.eb.netrad imagery/i.eb.soilheatflux imagery/i.emissivity imagery/i.evapo.mh imagery/i.evapo.pm imagery/i.evapo.pt imagery/i.evapo.time imagery/i.his.rgb imagery/i.landsat.acca imagery/i.modis.qc lib/htmldriver lib/init scripts/d.vect.thematic scripts/i.tasscap vector/v.info
svn_grass at osgeo.org
Tue Dec 9 09:23:56 PST 2014
Author: neteler
Date: 2014-12-09 09:23:56 -0800 (Tue, 09 Dec 2014)
New Revision: 63451
grass/trunk/display/d.vect.chart/d.vect.chart.html
grass/trunk/general/g.copy/g.copy.html
grass/trunk/general/g.filename/g.filename.html
grass/trunk/general/g.findfile/g.findfile.html
grass/trunk/general/g.list/g.list.html
grass/trunk/general/g.message/g.message.html
grass/trunk/general/g.proj/g.proj.html
grass/trunk/general/g.rename/g.rename.html
grass/trunk/general/g.version/g.version.html
grass/trunk/imagery/i.albedo/i.albedo.html
grass/trunk/imagery/i.albedo/main.c
grass/trunk/imagery/i.aster.toar/i.aster.toar.html
grass/trunk/imagery/i.biomass/i.biomass.html
grass/trunk/imagery/i.eb.eta/i.eb.eta.html
grass/trunk/imagery/i.eb.hsebal01/i.eb.hsebal01.html
grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html
grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html
grass/trunk/imagery/i.emissivity/i.emissivity.html
grass/trunk/imagery/i.evapo.mh/i.evapo.mh.html
grass/trunk/imagery/i.evapo.pm/i.evapo.pm.html
grass/trunk/imagery/i.evapo.pt/i.evapo.pt.html
grass/trunk/imagery/i.evapo.time/i.evapo.time.html
grass/trunk/imagery/i.his.rgb/i.his.rgb.html
grass/trunk/imagery/i.landsat.acca/i.landsat.acca.html
grass/trunk/imagery/i.modis.qc/i.modis.qc.html
grass/trunk/lib/htmldriver/htmldriver.html
grass/trunk/lib/init/grass7.html
grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html
grass/trunk/scripts/i.tasscap/i.tasscap.html
grass/trunk/vector/v.info/v.info.html
manual: some cleanup of HTML and examples
Modified: grass/trunk/display/d.vect.chart/d.vect.chart.html
--- grass/trunk/display/d.vect.chart/d.vect.chart.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/display/d.vect.chart/d.vect.chart.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -7,9 +7,9 @@
The charts are positioned as follows:
<ul>
-<li> vector points: on point position
-<li> vector lines: on line centers
-<li> vector areas: on area centroids
+<li> vector points: on point position,
+<li> vector lines: on line centers,
+<li> vector areas: on area centroids.
</ul>
Bar charts are placed with their lower edge starting from the y-coordinate
@@ -27,25 +27,38 @@
<h2>EXAMPLES</h2>
<h3>Example 1</h3>
+Pie-chart of winter precipitation (North Carolina sample dataset):
<div class="code"><pre>
-d.vect.chart map=vectmap columns=cens51,cens61,cens71,cens81
+d.vect.chart precip_30ynormals columns=nov,dec,jan,feb -l
</pre></div>
<h3>Example 2</h3>
-Create framed bar graphs of an erodibiliy index from the SPEARFISH dataset.
+Bar-chart of different census map values:
+d.vect.chart map=vectmap columns=cens51,cens61,cens71,cens81 chart_type=bar
+</pre></div>
+<h3>Example 3</h3>
+Creation of framed bar charts of an erodibiliy index from the Spearfish
+sample dataset:
+<div class="code"><pre>
g.region rast=erode.index -p
-r.to.vect -s -v input=erode.index output=erode_index type=area
+r.to.vect -s input=erode.index output=erode_index type=area
v.extract input=erode_index output=erode_index_ctrds type=centroid
d.rast aspect
d.vect.chart map=erode_index_ctrds chart_type=bar columns=cat \
- size=10 max_ref=12 scale=1.5 colors=yellow
+ size=10 max_ref=12 scale=0.05 colors=yellow
d.vect erode_index_ctrds icon=basic/circle fcol=black col=black size=5
</pre></div>
-Example screenshot (zoomed):<br>
-<img src="d.vect.chart_example.jpg" alt="d.vect.chart example">
+<img src="d.vect.chart_example.jpg" alt="d.vect.chart example"><br>
+Bar charts of an erodibiliy index (spatial subset)
<h2>SEE ALSO</h2>
Modified: grass/trunk/general/g.copy/g.copy.html
--- grass/trunk/general/g.copy/g.copy.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/general/g.copy/g.copy.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -16,7 +16,11 @@
called <em>rds.old</em>, the user could type:
-g.copy rast=soils,soils.ph vect=roads,rds.old
+g.copy raster=soils,soils.ph
+g.copy vector=roads,rds.old
+# or even combined:
+g.copy raster=soils,soils.ph vector=roads,rds.old
</pre></div>
<p>
@@ -27,7 +31,7 @@
current mapset:
-g.copy rast=soils at wilson,soils
+g.copy raster=soils at wilson,soils
</pre></div>
If no mapset name is specified, <em>g.copy</em> searches for the
Modified: grass/trunk/general/g.filename/g.filename.html
--- grass/trunk/general/g.filename/g.filename.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/general/g.filename/g.filename.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -5,8 +5,8 @@
vector and site maps, region definitions and imagery groups.
<p>The list of element names to search for is not fixed; any subdirectory of the
mapset directory is a valid element name.
-<p>However, the user can find the list of standard GRASS element names in
-the file $GISBASE/etc/element_list. This is the file which
+<p>However, the user can find the list of standard GRASS GIS element names in
+the file <tt>$GISBASE/etc/element_list</tt>. This is the file which
g.remove/g.rename/g.copy use to determine which files need to be
deleted/renamed/copied for a given entity type.
@@ -50,14 +50,14 @@
<dl>
<dd>
-eval `g.filename element=<em>name</em> mapset=<em>name</em> file=<em>name</em>`
+eval `g.filename element=name mapset=name file=name`
</pre></div>
</dl>
<h2>NOTES</h2>
-This routine generates the filename, but does not care if the file (or mapset
+This module generates the filename, but does not care if the file (or mapset
or element) exists or not. This feature allows shell scripts to create new data
base files as well as use existing ones.
Modified: grass/trunk/general/g.findfile/g.findfile.html
--- grass/trunk/general/g.findfile/g.findfile.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/general/g.findfile/g.findfile.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -33,7 +33,9 @@
eval `g.findfile element=name mapset=name file=name`
</pre></div>
-<p>For example (raster map):
+<p>
+For example (raster map):
eval `g.findfile element=cell file=elevation`
</pre></div>
@@ -52,28 +54,31 @@
if [ ! "$file" ]
then
- exit
+ exit 1
fi
</pre></div>
<h2>PYTHON</h2>
-See <em><a href="http://grass.osgeo.org/programming7/pythonlib.html">Python
+See <em><a href="http://grass.osgeo.org/grass71/manuals/libpython/">Python
Scripting Library</a></em> for more info.
+<p>
+Note: The Python shell in the <em>wxGUI</em> can be used for entering the
+following code:
+<p>
-import grass.script as grass
+import grass.script as gcore
-grass.find_file('elevation', element = 'cell')
+gcore.find_file('elevation', element = 'cell')
</pre></div>
<h2>SEE ALSO</h2>
<em>
- <a href="g.filename.html">g.filename</a>,
- <a href="g.gisenv.html">g.gisenv</a>,
- <a href="g.mapsets.html">g.mapsets</a>,
- <a href="g.parser.html">g.parser</a>
+<a href="g.filename.html">g.filename</a>,
+<a href="g.gisenv.html">g.gisenv</a>,
+<a href="g.mapsets.html">g.mapsets</a>,
+<a href="g.parser.html">g.parser</a>
</em>
<h2>AUTHOR</h2>
Modified: grass/trunk/general/g.list/g.list.html
--- grass/trunk/general/g.list/g.list.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/general/g.list/g.list.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -11,16 +11,32 @@
<h2>EXAMPLES</h2>
-List all available GRASS data base files:
+List all raster maps as continuous, sorted list:
-g.list type=all
+g.list type=rast
</pre></div>
-List all raster and vector maps:
+List all vector maps as continuous, sorted list with MAPSET info (i.e.
+fully-qualified map names):
+g.list type=vect -m
+</pre></div>
+List all raster and vector maps ordered by mapset:
+g.list type=rast -p
+</pre></div>
+List all raster and vector maps as continuous, sorted list:
g.list type=rast,vect
</pre></div>
+List all available GRASS data base files:
+g.list type=all
+</pre></div>
<h3>Mapset search path</h3>
If <b>mapset</b> is not specified than <em>g.list</em> searches for
@@ -29,7 +45,7 @@
see <tt>g.mapsets -p</tt>.
-g.list rast
+g.list rast -p
raster map(s) available in mapset <user1>:
dmt
@@ -44,16 +60,16 @@
g.list rast mapset=.
-raster map(s) available in mapset <user1>:
-dmt
</pre></div>
+<!-- better quote * as "*"? -->
Similarly <b>mapset</b>=* (one asterisk) prints data files from all
available mapsets also including those which are not listed in the
current search path (see <tt>g.mapsets -l</tt>).
-g.list rast mapset=*
+g.list rast mapset=* -p
raster map(s) available in mapset <landsat>:
lsat5_1987_10
@@ -181,6 +197,8 @@
Huidae Cho<br>
grass4u at gmail.com
+<br>
+based on general/manage/cmd/list.c by Michael Shapiro
<p>
<i>Last changed: $Date$</i>
Modified: grass/trunk/general/g.message/g.message.html
--- grass/trunk/general/g.message/g.message.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/general/g.message/g.message.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -47,7 +47,7 @@
<h3>Usage in Python scripts</h3>
-<a href="http://grass.osgeo.org/programming7/pythonlib.html">GRASS
+<a href="http://grass.osgeo.org/grass71/manuals/libpython/">GRASS
Python Scripting Library</a> defines special wrappers
for <em>g.message</em>.
@@ -61,11 +61,15 @@
<li><tt>warning()</tt> for <tt>g.message -w</tt>
</ul>
-Eg.
+<p>
+following sample code:
+<p>
-grass.warning("This is a warning")
+gcore.warning("This is a warning")
</pre></div>
is identical with
Modified: grass/trunk/general/g.proj/g.proj.html
--- grass/trunk/general/g.proj/g.proj.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/general/g.proj/g.proj.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -148,7 +148,7 @@
900913 (<a href="http://spatialreference.org/ref/user/6/">Google Mercator Projection</a>)<br>
-g.proj -c epsg=900913 loc=google
+g.proj -c epsg=900913 location=google
</pre></div>
<p>Create a new location with the co-ordinate system referred to by EPSG code
Modified: grass/trunk/general/g.rename/g.rename.html
--- grass/trunk/general/g.rename/g.rename.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/general/g.rename/g.rename.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -13,24 +13,21 @@
in the current mapset. The file element <em>old</em> is
then renamed to <em>new</em>.
<p>
-Users can also simply type <em>g.rename -help</em> without
+Users can also simply type <em>g.rename --help</em> without
arguments on the command line, to receive a menu of
existing data base element types and files from which to
choose for possible renaming:
-<div class="code">
-<pre>
- rast rast file(s) to be renamed
- oldvect oldvect file(s) to be renamed (GRASS 5.0)
- vect vect file(s) to be renamed (GRASS >5.1)
- icon icon file(s) to be renamed
- labels labels file(s) to be renamed
- sites sites file(s) to be renamed
- region region file(s) to be renamed
- group group file(s) to be renamed
- 3dview 3dview file(s) to be renamed
+ raster raster map(s) to be renamed
+ 3draster 3D raster map(s) to be renamed
+ vector vector map(s) to be renamed
+ oldvector old (GRASS 5.0) vector map(s) to be renamed
+ asciivector ASCII vector map(s) to be renamed
+ labels paint label file(s) to be renamed
+ region region definition(s) to be renamed
+ group imagery group(s) to be renamed
</pre></div>
@@ -43,7 +40,7 @@
<p>
If the user attempts to rename a file to itself by setting
the <em>new</em> file name equal to the <em>old</em> file
-name (e.g., <b>g.rename rast=soils,soils</b>),
+name (e.g., <b>g.rename raster=soils,soils</b>),
<em>g.rename</em> will not execute the rename, but instead
state that no rename is needed. However, <em>g.rename</em>
@@ -59,19 +56,22 @@
# rename raster map
-g.rename rast=oldrast,newrast
+g.rename raster=oldrast,newrast
# rename vector map
-g.rename vect=oldvect,newvect
+g.rename vector=oldvect,newvect
# combined renaming
-g.rename rast=oldrast,newrast vect=oldvect,newvect
+g.rename raster=oldrast,newrast vector=oldvect,newvect
</pre></div>
<h2>SEE ALSO</h2>
-<em><a href="g.copy.html">g.copy</a></em><br>
-<em><a href="g.list.html">g.list</a></em><br>
-<em><a href="g.remove.html">g.remove</a></em>
+<em>
+<a href="g.copy.html">g.copy</a>,
+<a href="g.list.html">g.list</a>,
+<a href="g.remove.html">g.remove</a>
+</em>
<h2>AUTHOR</h2>
Modified: grass/trunk/general/g.version/g.version.html
--- grass/trunk/general/g.version/g.version.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/general/g.version/g.version.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -1,17 +1,17 @@
<h2>DESCRIPTION</h2>
<em>g.version</em> prints to standard output the GRASS version number,
-date, the GRASS copyright (<b>-c</b> flag), and GRASS build information
+date, the GRASS GIS copyright (<b>-c</b> flag), and GRASS build information
(<b>-b</b> flag).
<h2>NOTES</h2>
This program requires no command line arguments; the user simply types
<em>g.version</em> on the command line to see the version number and
-date of the GRASS software currently being run by the user.
+date of the GRASS GIS software currently being run by the user.
<p>
-Information about GRASS
+Information about GRASS GIS
core <a href="http://grass.osgeo.org/programming7/gislib.html">GIS
Library</a> can be printed by <b>-r</b> flag.
@@ -27,9 +27,9 @@
Scripting Library</a>.
-print grass.version()
+print gcore.version()
</pre></div>
<h2>EXAMPLES</h2>
@@ -38,7 +38,7 @@
g.version
-GRASS 7.0.svn (2012)
+GRASS 7.0.0svn (2014)
</pre></div>
<h3>GIS Library info</h3>
@@ -46,24 +46,26 @@
g.version -r
-libgis Revision: 52468
-libgis Date: 2012-07-27 22:53:30 +0200 (Fri, 27 Jul 2012)
+libgis Revision: 63222
+libgis Date: 2014-11-28 10:04:17 +0100 (Fri, 28 Nov 2014)
</pre></div>
<h3>Full info in shell script style</h3>
g.version -rge
-version=7.0.svn
-revision=53670
-date=2012
-libgis_revision=52468
-libgis_date="2012-07-27 22:53:30 +0200 (Fri, 27 Jul 2012) "
+version=7.0.0svn
+date=2014
+revision=63285M
+build_date=2014-12-03
+build_platform=x86_64-unknown-linux-gnu
+libgis_revision=63222
+libgis_date="2014-11-28 10:04:17 +0100 (Fri, 28 Nov 2014) "
proj4=4.8.0
-gdal=1.9.2
-geos=3.3.5
-sqlite=3.7.14.1
+gdal=1.10.1
+geos=3.4.2
+sqlite=3.8.7
</pre></div>
<h2>AUTHORS</h2>
Modified: grass/trunk/imagery/i.albedo/i.albedo.html
--- grass/trunk/imagery/i.albedo/i.albedo.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.albedo/i.albedo.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -1,28 +1,30 @@
-<em>i.albedo</em> calculates the Albedo, that is the Shortwave surface
-reflectance in the range of 0.3-3 micro-meters. It takes input of
-individual bands of surface reflectance from Modis, AVHRR, Landsat or
-Aster and calculates the Albedo for those. This is an precursor to
-r.sun and any Energy-Balance processing.
+<em>i.albedo</em> calculates the albedo, that is the Shortwave surface
+reflectance in the range of 0.3-3 micro-meters. It takes as input
+individual bands of surface reflectance originating from MODIS, AVHRR, Landsat
+or Aster satellite sensors and calculates the albedo for those. This is
+a precursor to <em>r.sun</em> and any energy-balance processing.
-Landsat 8 weighted average reflectance (temporary until algorithm is found)
<h2>NOTES</h2>
-It assumes MODIS product surface reflectance in [0;10000]
+It uses for Landsat 8 the weighted average reflectance (temporary until algorithm is found).
+<p>
+It assumes MODIS product surface reflectance in [0;10000].
<h2>TODO</h2>
Maybe change input requirement of MODIS to [0.0-1.0]?
<h2>SEE ALSO</h2>
<em>
- <a href="r.sun.html">r.sun</a>,
- <a href="i.vi.html">i.vi</a>
+<a href="r.sun.html">r.sun</a>,
+<a href="i.vi.html">i.vi</a>
</em>
-<h2>AUTHORS</h2>
+<h2>AUTHOR</h2>
-GRASS Development Team
+Yann Chemin
<p><i>Last changed: $Date$</i>
Modified: grass/trunk/imagery/i.albedo/main.c
--- grass/trunk/imagery/i.albedo/main.c 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.albedo/main.c 2014-12-09 17:23:56 UTC (rev 63451)
@@ -6,7 +6,7 @@
* PURPOSE: Calculate Broadband Albedo (0.3-3 Micrometers)
* from Surface Reflectance (Modis, AVHRR, Landsat, Aster).
- * COPYRIGHT: (C) 2004-2008 by the GRASS Development Team
+ * COPYRIGHT: (C) 2004-2014 by the GRASS Development Team
* This program is free software under the GNU Lesser General Public
* License. Read the file COPYING that comes with GRASS for details.
@@ -116,7 +116,7 @@
flag3 = G_define_flag();
flag3->key = 'l';
- flag3->description = _("Landsat (6 input bands:1,2,3,4,5,7)");
+ flag3->description = _("Landsat 5+7 (6 input bands:1,2,3,4,5,7)");
flag4 = G_define_flag();
flag4->key = '8';
Modified: grass/trunk/imagery/i.aster.toar/i.aster.toar.html
--- grass/trunk/imagery/i.aster.toar/i.aster.toar.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.aster.toar/i.aster.toar.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -5,6 +5,8 @@
brigthness temperature for the TIR bands (5 bands), all from L1B DN values.
It is useful after importing your Aster imagery from storage format that
is generally in standard DN values range.
+<p>
The order of input bands is
<ul>
<li> VNIR: 1,2,3N,3B
Modified: grass/trunk/imagery/i.biomass/i.biomass.html
--- grass/trunk/imagery/i.biomass/i.biomass.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.biomass/i.biomass.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -1,15 +1,15 @@
-<em>i.biomass</em> Calculates the biomass growth for a day after [1][2].
+<em>i.biomass</em> calculates the biomass growth for a day after [1][2].
Input:
<ul>
<li>fPAR, the modified Photosynthetic Active Radiation for crops.
<li>Light Use Efficiency [0.0-1.0], in Uzbekistan cotton is at 1.9 most of the time.
- <li>Latitude [0.0-90.0], from r.latlong.
+ <li>Latitude [0.0-90.0], from <em>r.latlong</em>.
<li>DOY [1-366].
<li>Transmissivity of the Atmosphere single-way [0.0-1.0], mostly around 0.7+ in clear sky.
- <li>Water availability [0.0-1.0], possibly using direct output from i.eb.evapfr.
+ <li>Water availability [0.0-1.0], possibly using direct output from <em>i.eb.evapfr</em>.
</ul>
<h2>NOTES</h2>
@@ -17,12 +17,13 @@
<h2>TODO</h2>
Remove Latitude, DOY and Tsw from input and replace with a raster
-input compatible with r.sun output.
+input compatible with <em>r.sun</em> output.
<h2>SEE ALSO</h2>
<em>
-<a href="i.eb.evapfr">i.eb.evapfr</a><br>
+<a href="i.eb.evapfr.html">i.eb.evapfr</a>,
+<a href="r.latlong.html">r.latlong</a>
</em>
<h2>REFERENCES</h2>
Modified: grass/trunk/imagery/i.eb.eta/i.eb.eta.html
--- grass/trunk/imagery/i.eb.eta/i.eb.eta.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.eb.eta/i.eb.eta.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -2,28 +2,28 @@
<em>i.eb.eta</em> calculates the actual evapotranspiration (ETa ; mm/d) for
diurnal period after [1], implemented in [3].
-It takes input of Diurnal Net Radiation (see <i>r.sun</i>), evaporative fraction (see
-<i>i.eb.evapfr</i>) and surface skin temperature.
+It takes input of Diurnal Net Radiation (see <em>r.sun</em>), evaporative fraction (see
+<em>i.eb.evapfr</em>) and surface skin temperature.
<h2>NOTES</h2>
Full ETa processing will need those:
<ul>
- <li>i.vi, i.albedo, r.latlong, i.emissivity
- <li>i.evapo.potrad (Addon)
- <li>i.eb.netrad, i.eb.soilheatflux, i.eb.hsebal01
- <li>i.eb.evapfr, i.eb.eta
+ <li><em>i.vi</em>, <em>i.albedo</em>, <em>r.latlong</em>, <em>i.emissivity</em>
+ <li><em>i.evapo.potrad</em> (GRASS Addon)
+ <li><em>i.eb.netrad</em>, <em>i.eb.soilheatflux</em>, <em>i.eb.hsebal01</em>
+ <li><em>i.eb.evapfr</em>, <em>i.eb.eta</em>
</ul>
-(for time integration: i.evapo.time_integration)
+(for time integration: <em>i.evapo.time_integration</em>) <!-- TODO unknown module -->
<p>For more details on the algorithms see [1][2][3][4].
<h2>SEE ALSO</h2>
<em>
-<a href="r.sun.html">r.sun</a><br>
-<a href="i.eb.evapfr.html">i.eb.evapfr</a><br>
-<a href="i.eb.netrad.html">i.eb.netrad</a><br>
+<a href="i.eb.netrad.html">i.eb.netrad</a>
</em>
<h2>REFERENCES</h2>
@@ -47,7 +47,6 @@
in: Irmak, A. (Ed.), Evapotranspiration - Remote Sensing and Modeling. InTech.
(<a href="http://www.intechopen.com/books/evapotranspiration-remote-sensing-and-modeling/a-distributed-benchmarking-framework-for-actual-et-models">PDF</a>)
<h2>AUTHORS</h2>
Yann Chemin, Asian Institute of Technology, Thailand
Modified: grass/trunk/imagery/i.eb.hsebal01/i.eb.hsebal01.html
--- grass/trunk/imagery/i.eb.hsebal01/i.eb.hsebal01.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.eb.hsebal01/i.eb.hsebal01.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -8,13 +8,13 @@
Full process will need those:
<ul>
</ul>
<p>
<em>i.eb.hsebal01</em> performs the computation of <i>sensible heat flux</i>
@@ -23,7 +23,7 @@
<h2>NOTES</h2>
<ul>
-<li> z0m can be alculated by i.eb.z0m or i.eb.z0m0 (grass-addons).
+<li> z0m can be alculated by <em>i.eb.z0m</em> or <em>i.eb.z0m0</em> (GRASS Addons).
<li> ea can be calculated with standard meteorological data.<br>
eoTmin=0.6108*EXP(17.27*Tmin/(Tmin+237.3))<br>
eoTmax=0.6108*EXP(17.27*Tmax/(Tmax+237.3))<br>
@@ -33,13 +33,13 @@
<h2>SEE ALSO</h2>
<em>
-<a href=i.eb.soilheatflux.html>i.eb.soilheatflux</a>,
-<a href=i.eb.hsebal01.html>i.eb.hsebal01</a>,
-<a href=i.eb.evapfr.html>i.eb.evapfr</a>
+<a href="i.eb.soilheatflux.html">i.eb.soilheatflux</a>,
+<a href="i.eb.hsebal01.html">i.eb.hsebal01</a>,
</em>
<h2>REFERENCES</h2>
<p>[1] Bastiaanssen, W.G.M., 1995.
@@ -48,7 +48,7 @@
(<a href="http://edepot.wur.nl/206553">PDF</a>)
<p>[2] Chemin Y., Alexandridis T.A., 2001. Improving spatial resolution of ET
-seasonal for irrigated rice in Zhanghe, China}''. Asian Journal of
+seasonal for irrigated rice in Zhanghe, China. Asian Journal of
Geoinformatics. 5(1):3-11,2004.
<p>[3] Alexandridis T.K., Cherif I., Chemin Y., Silleos N.G., Stavrinos E.,
Modified: grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html
--- grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.eb.netrad/i.eb.netrad.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -9,10 +9,12 @@
transmissivity (tsw), Day of Year (DOY), and sun zenith angle.
<h2>NOTES</h2>
+<!-- rewrite too sloppy notes or move to addons -->
In the old methods, dT was taken as flat images (dT=5.0), if you don't have a dT
map from ground data, you would want to try something in this line, this is to
calculate atmospherical energy balance. In the same way, a standard tsw is used
-in those equations. Refer to r_net.c for that and for other non-used equations,
+in those equations. Refer to <tt>r_net.c</tt> for that and for other non-used equations,
but stored in there for further research convenience.
<h2>TODO</h2>
Modified: grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html
--- grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.eb.soilheatflux/i.eb.soilheatflux.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -1,7 +1,7 @@
<em>i.eb.soilheatflux</em> calculates the soil heat flux approximation (g0)
-after Bastiaanssen (1995). The main reference for implementation is Alexandridis, submitted.
+after Bastiaanssen (1995). The main reference for implementation is Alexandridis, 2009.
It takes input of Albedo, NDVI, Surface Skin temperature, Net Radiation (see
<em>r.sun</em>), time of satellite overpass, and a flag for the Roerink empirical
modification from the HAPEX-Sahel experiment.
Modified: grass/trunk/imagery/i.emissivity/i.emissivity.html
--- grass/trunk/imagery/i.emissivity/i.emissivity.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.emissivity/i.emissivity.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -3,9 +3,10 @@
<em>i.emissivity</em> calculates the emissivity in the longwave radiation
spectrum, according to the semi-empirical equation related to NDVI by
Caselles and Colles (1997), valid in the NDVI range of 0.16 to 0.74.
-<p>Estimation in the 8-14 micrometers range for sparse canopy...
+<p>
+Estimation in the 8-14 micrometers range for sparse canopy...
+<!-- TODO: incomplete phrase! -->
<h2>SEE ALSO</h2>
<em>
Modified: grass/trunk/imagery/i.evapo.mh/i.evapo.mh.html
--- grass/trunk/imagery/i.evapo.mh/i.evapo.mh.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.evapo.mh/i.evapo.mh.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -3,6 +3,8 @@
<em>i.evapo.MH</em> Calculates the reference ET after Hargreaves (1985)
and Modified Hargreaves (2001).
+<!-- TODO Hargreaves (2001) citation missing! -->
<h2>SEE ALSO</h2>
<em>
@@ -20,7 +22,7 @@
evapotranspiration equation. Irrigation Science.
<p>Droogers, P., and R.G. Allen. 2002. Estimating reference evapotranspiration
under inaccurate data conditions. Irrigation and Drainage Systems 16: 33-45.
-<p>Hargreaves and Samani, 1985.
+<p>Hargreaves and Samani, 1985. <!-- incomplete -->
<h2>AUTHORS</h2>
Modified: grass/trunk/imagery/i.evapo.pm/i.evapo.pm.html
--- grass/trunk/imagery/i.evapo.pm/i.evapo.pm.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.evapo.pm/i.evapo.pm.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -12,7 +12,9 @@
problems. The usage of the flag -n detect that the module is run in night hours
and the appropriate soil heat flux is calculated.
-<p>The algorithm implements well known approaches: the hourly Penman-Monteith method as presented in Allen et al. (1998) for land surfaces and the Penman method (Penman, 1948) for water surfaces.<br>
+<p>The algorithm implements well known approaches: the hourly
+Penman-Monteith method as presented in Allen et al. (1998) for land
+surfaces and the Penman method (Penman, 1948) for water surfaces.
<p>Land and water surfaces are idenfyied by Vh:
<ul>
@@ -52,8 +54,8 @@
<a href="i.evapo.mh.html">i.evapo.mh</a>,
<a href="i.evapo.pm.html">i.evapo.pm</a>,
<a href="i.evapo.time.html">i.evapo.time</a>,
-<a href=r.sun.html>r.sun</a>,
-<a href=r.mapcalc.html>r.mapcalc</a>
+<a href="r.mapcalc.html">r.mapcalc</a>
</em>
<h2>AUTHORS</h2>
@@ -76,6 +78,7 @@
Crop Evapotranspiration: Guidelines for computing crop water requirements.
Irrigation and Drainage Paper 56, Food and Agriculture Organization of the
United Nations, Rome, pp. 300
<p>[3] Penman, H. L. 1948. Natural evaporation from open water,
bare soil and grass. Proc. Roy. Soc. London, A193, pp. 120-146.
Modified: grass/trunk/imagery/i.evapo.pt/i.evapo.pt.html
--- grass/trunk/imagery/i.evapo.pt/i.evapo.pt.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.evapo.pt/i.evapo.pt.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -16,11 +16,12 @@
Stewart and Rouse, 1976; Shuttleworth and Calder, 1979), and temperate
hardwood swamps (Munro, 1979)
<li> 1.74 has been recommended for estimating potential evapotranspiration
-in more arid regions (ASCE, 1990). This Worked well in Greece with University of Thessaloniki.
+in more arid regions (ASCE, 1990). This worked well in Greece with University
+of Thessaloniki.
</ul>
Alpha values extracted from:
-http://www.civil.uwaterloo.ca/Watflood/Manual/02_03_1.htm
+<a href="http://www.civil.uwaterloo.ca/Watflood/Manual/02_03_1.htm">Watflood manual</a>.
<h2>SEE ALSO</h2>
Modified: grass/trunk/imagery/i.evapo.time/i.evapo.time.html
--- grass/trunk/imagery/i.evapo.time/i.evapo.time.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.evapo.time/i.evapo.time.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -36,7 +36,7 @@
for ETo_val in Eto[1] Eto[2] ...
do
r.mapcalc "eto$n = $ETo_val"
- `expr n = n + 1'
+ `expr n = n + 1`
done
</pre></div>
@@ -63,7 +63,7 @@
</em>
-<h2>AUTHORS</h2>
+<h2>AUTHOR</h2>
Yann Chemin, International Rice Research Institute, The Philippines
Modified: grass/trunk/imagery/i.his.rgb/i.his.rgb.html
--- grass/trunk/imagery/i.his.rgb/i.his.rgb.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.his.rgb/i.his.rgb.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -14,10 +14,8 @@
It is not possible to process three bands with
<em>i.his.rgb</em> and then exactly recover the original
-bands with
+bands with <em>i.rgb.his</em>.
-<em><a href="i.rgb.his.html">i.rgb.his</a></em>.
This is due to loss of precision because of integer
computations and rounding. Tests have shown that more than
70% of the original cell values will be reproduced exactly
@@ -27,7 +25,10 @@
<h2>SEE ALSO</h2>
-<em><a href="r.colors.html">r.colors</a></em>
+<em>
+<a href="i.rgb.his.html">i.rgb.his</a>,
+<a href="r.colors.html">r.colors</a>
+</em>
<h2>AUTHOR</h2>
Modified: grass/trunk/imagery/i.landsat.acca/i.landsat.acca.html
--- grass/trunk/imagery/i.landsat.acca/i.landsat.acca.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.landsat.acca/i.landsat.acca.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -27,8 +27,10 @@
named <tt>226_62.acca</tt>:
- i.landsat.toar sensor=7 gain=HHHLHLHHL date=2003-04-07 product_date=2008-11-27 band_prefix=226_62 solar_elevation=49.51654
- i.landsat.acca -f band_prefix=226_62.toar output=226_62.acca
+i.landsat.toar sensor=7 gain=HHHLHLHHL date=2003-04-07 \
+ product_date=2008-11-27 band_prefix=226_62 solar_elevation=49.51654
+i.landsat.acca -f band_prefix=226_62.toar output=226_62.acca
</pre></div>
@@ -49,7 +51,7 @@
<h2>SEE ALSO</h2>
<em>
- <a href="i.landsat.toar.html">i.landsat.toar</a>
+<a href="i.landsat.toar.html">i.landsat.toar</a>
</em>
<h2>AUTHOR</h2>
Modified: grass/trunk/imagery/i.modis.qc/i.modis.qc.html
--- grass/trunk/imagery/i.modis.qc/i.modis.qc.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/imagery/i.modis.qc/i.modis.qc.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -412,7 +412,8 @@
<ul>
<li> <a href="https://lpdaac.usgs.gov/products/modis_products_table">MODIS Products</a>
<li> Vermote E.F., Kotchenova S.Y., Ray J.P. MODIS Surface Reflectance User's Guide.
- Version 1.2. June 2008. MODIS Land Surface Reflectance Science Computing Facility. <a href="http://modis-sr.ltdri.org">Homepage</a>
+ Version 1.2. June 2008. MODIS Land Surface Reflectance Science Computing Facility.
+ <a href="http://modis-sr.ltdri.org">Homepage</a>
</ul>
<h2>AUTHOR</h2>
Modified: grass/trunk/lib/htmldriver/htmldriver.html
--- grass/trunk/lib/htmldriver/htmldriver.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/lib/htmldriver/htmldriver.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -133,7 +133,8 @@
d.vect map=states color=green
d.vect map=roads color=black
d.mon stop=png
-<!-- ???? FIXME -->
+<!-- ???? FIXME and the ppm stuff looks overly complicated -->
# make the region the same as the newly created cell for ppm export
g.region save=saved.reg
g.region raster=D_cell
@@ -172,9 +173,9 @@
with the name
<tt>map</tt>. A small sed script can easily change the map name:
-<pre>
- sed -e 's/NAME="map"/NAME="foomap"/' < htmlmap > foomap.html
-</pre>
+sed -e 's/NAME="map"/NAME="foomap"/' < htmlmap > foomap.html
+</pre></div>
<h2>SEE ALSO</h2>
Modified: grass/trunk/lib/init/grass7.html
--- grass/trunk/lib/init/grass7.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/lib/init/grass7.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -129,13 +129,13 @@
interface, then the GRASS_PYTHON environment variable can be used to
override your system default <tt>python</tt> command.
-<p>Suppose for example your system has Python 2.4 installed and you
-install a personal version of the Python 2.5 binaries
+<p>Suppose for example your system has Python 2.5 installed and you
+install a personal version of the Python 2.6 binaries
under <tt>$HOME/bin</tt>. You can use the above variables to have
-GRASS use the Python 2.5 binaries instead.
+GRASS use the Python 2.6 binaries instead.
- GRASS_PYTHON=python2.5
+ GRASS_PYTHON=python2.6
</pre></div>
<h3>Addon Path to Extra User Scripts</h3>
@@ -327,7 +327,7 @@
If you start GRASS using the <em><a href="wxGUI.html">wxGUI</a></em>
interface you must have a <tt>python</tt> command in your $PATH
variable. That is, the command must be named
-<tt>python</tt> and not something like <tt>python2.5</tt>. Rarely some
+<tt>python</tt> and not something like <tt>python2.6</tt>. Rarely some
Python installations do not create a <tt>python</tt> command. In these
cases you can override <tt>python</tt> by GRASS_PYTHON environmental
variable.
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -67,25 +67,27 @@
# random sampling of elevation points:
g.region rast=elevation -p
-v.random random n=200
-v.db.addtable random col="el10 double precision"
+v.random random npoints=200
+v.db.addtable random column="el10 double precision"
# transfer elevations to attribute table of random points map:
-v.what.rast random rast=elevation col=el10
+v.what.rast random rast=elevation column=el10
v.db.select random
# comparative sampling of second map, incl. differences:
-v.sample in=random col=el10 rast=elev_state_500m out=elev_sample
+v.sample input=random column=el10 raster=elev_state_500m output=elev_sample
v.db.select elev_sample
# univariate statistics:
-v.univar -e elev_sample col=diff type=point
+v.univar -e elev_sample column=diff type=point
# thematic map:
d.mon wx0
d.vect.thematic -l elev_sample column=diff type=point
</pre></div>
-<p>North Carolina data set example:
+<p>
+North Carolina sample dataset example:
g.region vect=nc_state
d.vect.thematic -l precip_30ynormals column=annual type=point
@@ -94,7 +96,7 @@
<h2>SEE ALSO</h2>
<em>
-<a href="d.vect.html">d.vect</a>,
+<a href="d.vect.html">d.vect</a>,
<a href="d.vect.chart.html">d.vect.chart</a>,
<a href="v.univar.html">v.univar</a>
</em>
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.html
--- grass/trunk/scripts/i.tasscap/i.tasscap.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -18,13 +18,13 @@
<li> tasscap.1: corresponds to brightness,
<li> tasscap.2: corresponds to greenness,
<li> tasscap.3: corresponds to wetness,
-<li> tasscap.4: corresponds to atmospheric haze (only selected sensors).
+<li> tasscap.4: corresponds to atmospheric haze (only selected sensors: Landsat 5,7,8).
</ul>
<h2>EXAMPLE</h2>
-Calculation of TC maps from North Carolina Landsat scene:
+Calculation of TC maps from North Carolina Landsat 7 ETM scene:
g.region rast=lsat7_2002_10 -p
@@ -106,5 +106,5 @@
<h2>AUTHOR</h2>
-Markus Neteler, ITC-irst
+Markus Neteler, ITC-irst, based on a script by Agustin Lobo
Modified: grass/trunk/vector/v.info/v.info.html
--- grass/trunk/vector/v.info/v.info.html 2014-12-09 16:27:44 UTC (rev 63450)
+++ grass/trunk/vector/v.info/v.info.html 2014-12-09 17:23:56 UTC (rev 63451)
@@ -9,7 +9,7 @@
<h2>EXAMPLE</h2>
-<h3>Basic info</h3>
+<h3>Basic metadata information</h3>
v.info map=geology
@@ -46,7 +46,7 @@
</pre></div>
-<h3>History</h3>
+<h3>Map history</h3>
v.info -h map=geology
@@ -78,7 +78,7 @@
DOUBLE PRECISION|SHAPE_len
</pre></div>
-<h3>Basic info in shell script style</h3>
+<h3>Basic metadata information in shell script style</h3>
v.info -get map=geology
@@ -128,21 +128,25 @@
<h2>PYTHON</h2>
+<p>
+following code:
+<p>
-grass.vector_columns('geology') # for `v.info -c`
-grass.vector_info_topo('geology') # for `v.info shell=topo`
+gcore.vector_columns('geology') # for `v.info -c`
+gcore.vector_info_topo('geology') # for `v.info shell=topo`
</pre></div>
<h2>SEE ALSO</h2>
<em>
- <a href="r.info.html">r.info</a>,
- <a href="r3.info.html">r3.info</a>
+<a href="r.info.html">r.info</a>,
+<a href="r3.info.html">r3.info</a>,
+<a href="t.info.html">t.info</a>
</em>
<h2>AUTHOR</h2>
