[GRASS-SVN] r63457 - grass/trunk/display/d.mon
svn_grass at osgeo.org
Tue Dec 9 11:19:02 PST 2014
Author: martinl
Date: 2014-12-09 11:19:02 -0800 (Tue, 09 Dec 2014)
New Revision: 63457
grass/trunk/display/d.mon/start.c
d.mon: output - rely always on full path
Modified: grass/trunk/display/d.mon/start.c
--- grass/trunk/display/d.mon/start.c 2014-12-09 18:51:22 UTC (rev 63456)
+++ grass/trunk/display/d.mon/start.c 2014-12-09 19:19:02 UTC (rev 63457)
@@ -13,14 +13,31 @@
/* start file-based monitor */
void start(const char *name, const char *output)
- char *env_name;
+ char *env_name, output_path[GPATH_MAX];
if (!output)
return;
+ if (!strchr(output, HOST_DIRSEP)) { /* relative path */
+ char *ptr;
+ if (!getcwd(output_path, PATH_MAX))
+ G_fatal_error(_("Unable to get current working directory"));
+ ptr = output_path + strlen(output_path) - 1;
+ if (*(ptr++) != HOST_DIRSEP) {
+ *(ptr++) = HOST_DIRSEP;
+ *(ptr) = '\0';
+ strcat(output_path, output);
+ G_message(_("Output file: %s"), output_path);
+ else {
+ strcpy(output_path, output); /* already full path */
env_name = NULL;
G_asprintf(&env_name, "MONITOR_%s_MAPFILE", G_store_upper(name));
- G_setenv(env_name, output);
+ G_setenv(env_name, output_path);
/* start wxGUI display monitor */
