[GRASS-SVN] r63460 - in grass/branches/releasebranch_7_0: . lib/driver
Tue Dec 9 12:30:44 PST 2014
Author: martinl
Date: 2014-12-09 12:30:43 -0800 (Tue, 09 Dec 2014)
New Revision: 63460
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/lib/driver/driver.h
driverlib: header cosmetics (file renamed to lower-case)
           (merge r63459 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,
 63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63302,63315,63319,63330,63332,63339,63342,63345,63362,63367,63391,63393,63408-63409,63416-63417,63425,63427,63429,63431,63433,63451,63453,63457
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62933,62935,62940,62942,62944-62946,62949,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,63083,63085,63087,
 63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63302,63315,63319,63330,63332,63339,63342,63345,63362,63367,63391,63393,63408-63409,63416-63417,63425,63427,63429,63431,63433,63451,63453,63457,63459
Modified: grass/branches/releasebranch_7_0/lib/driver/driver.h
--- grass/branches/releasebranch_7_0/lib/driver/driver.h	2014-12-09 20:28:30 UTC (rev 63459)
+++ grass/branches/releasebranch_7_0/lib/driver/driver.h	2014-12-09 20:30:43 UTC (rev 63460)
@@ -60,56 +60,56 @@
 /* Commands */
-/* Box.c */
+/* box.c */
 extern void COM_Box_abs(double, double, double, double);
-/* Color.c */
+/* color.c */
 extern void COM_Color_RGB(unsigned char, unsigned char, unsigned char);
 extern void COM_Standard_color(int);
-/* Erase.c */
+/* erase.c */
 extern void COM_Erase(void);
-/* Font.c */
+/* font.c */
 extern void COM_Set_font(const char *);
 extern void COM_Set_encoding(const char *);
 extern void COM_Font_list(char ***, int *);
 extern void COM_Font_info(char ***, int *);
-/* Get_t_box.c */
+/* get_t_box.c */
 extern void COM_Get_text_box(const char *, double *, double *, double *, double *);
-/* Graph.c */
+/* graph.c */
 extern int COM_Graph_set(void);
 extern void COM_Graph_close(void);
-/* Line_width.c */
+/* line_width.c */
 extern void COM_Line_width(double);
-/* Move.c */
+/* move.c */
 extern void COM_Pos_abs(double, double);
-/* Raster.c */
+/* raster.c */
 extern void COM_begin_raster(int, int[2][2], double[2][2]);
 extern int COM_raster(int, int, const unsigned char *,
 		      const unsigned char *, const unsigned char *,
 		      const unsigned char *);
 extern void COM_end_raster(void);
-/* Set_window.c */
+/* set_window.c */
 extern void COM_Set_window(double, double, double, double);
 extern void COM_Get_window(double *, double *, double *, double *);
-/* Text.c */
+/* text.c */
 extern void COM_Text(const char *);
-/* Text_size.c */
+/* text_size.c */
 extern void COM_Text_size(double, double);
 extern void COM_Text_rotation(double);
 /* Driver Operations */
-/* Draw.c */
+/* draw.c */
 extern void COM_Bitmap(int, int, int, const unsigned char *);
 extern void COM_Begin(void);
 extern void COM_Move(double, double);
