[GRASS-SVN] r63464 - in grass/trunk: include/defs lib/cairodriver lib/display lib/driver lib/htmldriver lib/pngdriver lib/psdriver
svn_grass at osgeo.org
Wed Dec 10 01:21:11 PST 2014
Author: martinl
Date: 2014-12-10 01:21:11 -0800 (Wed, 10 Dec 2014)
New Revision: 63464
grass/trunk/include/defs/display.h
grass/trunk/lib/cairodriver/cairodriver.h
grass/trunk/lib/cairodriver/driver.c
grass/trunk/lib/cairodriver/graph.c
grass/trunk/lib/display/setup.c
grass/trunk/lib/driver/driver.h
grass/trunk/lib/driver/graph.c
grass/trunk/lib/htmldriver/driver.c
grass/trunk/lib/pngdriver/driver.c
grass/trunk/lib/pngdriver/graph_set.c
grass/trunk/lib/pngdriver/pngdriver.h
grass/trunk/lib/psdriver/driver.c
grass/trunk/lib/psdriver/graph_set.c
grass/trunk/lib/psdriver/psdriver.h
displaylib: add D_get_file (#2509)
Modified: grass/trunk/include/defs/display.h
--- grass/trunk/include/defs/display.h 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/include/defs/display.h 2014-12-10 09:21:11 UTC (rev 63464)
@@ -166,4 +166,6 @@
void D_set_clip_window_to_map_window(void);
void D_set_clip_window_to_screen_window(void);
+const char *D_get_file(void);
#endif /* GRASS_DISPLAYDEFS_H */
Modified: grass/trunk/lib/cairodriver/cairodriver.h
--- grass/trunk/lib/cairodriver/cairodriver.h 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/cairodriver/cairodriver.h 2014-12-10 09:21:11 UTC (rev 63464)
@@ -84,6 +84,7 @@
extern void Cairo_Client_Close(void);
extern int Cairo_Graph_set(void);
+extern const char *Cairo_Graph_get_file(void);
extern void Cairo_Graph_close(void);
extern void Cairo_Box(double, double, double, double);
extern void Cairo_Set_window(double, double, double, double);
Modified: grass/trunk/lib/cairodriver/driver.c
--- grass/trunk/lib/cairodriver/driver.c 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/cairodriver/driver.c 2014-12-10 09:21:11 UTC (rev 63464)
@@ -3,7 +3,7 @@
\brief GRASS cairo display driver - driver initialization
- (C) 2007-2008, 2011 by Lars Ahlzen and the GRASS Development Team
+ (C) 2007-2014 by Lars Ahlzen and the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
@@ -31,6 +31,7 @@
drv.Box = Cairo_Box;
drv.Erase = Cairo_Erase;
drv.Graph_set = Cairo_Graph_set;
+ drv.Graph_get_file = Cairo_Graph_get_file;
drv.Graph_close = Cairo_Graph_close;
drv.Line_width = Cairo_Line_width;
drv.Set_window = Cairo_Set_window;
@@ -51,7 +52,7 @@
drv.Set_font = Cairo_set_font;
drv.Font_list = Cairo_font_list;
drv.Font_info = Cairo_font_info;
initialized = 1;
return &drv;
Modified: grass/trunk/lib/cairodriver/graph.c
--- grass/trunk/lib/cairodriver/graph.c 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/cairodriver/graph.c 2014-12-10 09:21:11 UTC (rev 63464)
@@ -279,6 +279,16 @@
+ \brief Get render file
+ \return file name
+const char *Cairo_Graph_get_file(void)
+ return ca.file_name;
\brief Close driver
Modified: grass/trunk/lib/display/setup.c
--- grass/trunk/lib/display/setup.c 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/display/setup.c 2014-12-10 09:21:11 UTC (rev 63464)
@@ -17,6 +17,8 @@
#include <grass/raster.h>
#include <grass/display.h>
+#include "driver.h"
\brief Graphics frame setup
@@ -130,3 +132,13 @@
D_set_clip_window_to_map_window();
+ \brief Get driver output file
+ \return file name or NULL if not defined
+ return COM_Graph_get_file();
Modified: grass/trunk/lib/driver/driver.h
--- grass/trunk/lib/driver/driver.h 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/driver/driver.h 2014-12-10 09:21:11 UTC (rev 63464)
@@ -22,11 +22,12 @@
struct driver
char *name;
void (*Box)(double, double, double, double);
void (*Erase)(void);
int (*Graph_set)(void);
void (*Graph_close)(void);
+ const char * (*Graph_get_file)(void);
void (*Line_width)(double);
void (*Set_window)(double, double, double, double);
void (*Begin_raster)(int, int[2][2], double[2][2]);
@@ -82,6 +83,7 @@
/* graph.c */
extern int COM_Graph_set(void);
extern void COM_Graph_close(void);
+extern const char *COM_Graph_get_file(void);
/* line_width.c */
extern void COM_Line_width(double);
Modified: grass/trunk/lib/driver/graph.c
--- grass/trunk/lib/driver/graph.c 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/driver/graph.c 2014-12-10 09:21:11 UTC (rev 63464)
@@ -1,3 +1,4 @@
+#include <stdlib.h>
#include "driver.h"
#include "driverlib.h"
@@ -13,3 +14,11 @@
if (driver->Graph_close)
(*driver->Graph_close) ();
+const char *COM_Graph_get_file(void)
+ if (driver->Graph_get_file)
+ return (*driver->Graph_get_file) ();
+ return NULL;
Modified: grass/trunk/lib/htmldriver/driver.c
--- grass/trunk/lib/htmldriver/driver.c 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/htmldriver/driver.c 2014-12-10 09:21:11 UTC (rev 63464)
@@ -30,6 +30,7 @@
drv.Erase = NULL;
drv.Graph_set = HTML_Graph_set;
drv.Graph_close = HTML_Graph_close;
+ drv.Graph_get_file = NULL;
drv.Line_width = NULL;
drv.Set_window = NULL;
drv.Begin_raster = NULL;
Modified: grass/trunk/lib/pngdriver/driver.c
--- grass/trunk/lib/pngdriver/driver.c 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/pngdriver/driver.c 2014-12-10 09:21:11 UTC (rev 63464)
@@ -3,7 +3,7 @@
\brief GRASS png display driver - driver initialization
- (C) 2007 by Glynn Clements and the GRASS Development Team
+ (C) 2007-2014 by Glynn Clements and the GRASS Development Team
@@ -31,6 +31,7 @@
drv.Erase = PNG_Erase;
drv.Graph_set = PNG_Graph_set;
drv.Graph_close = PNG_Graph_close;
+ drv.Graph_get_file = PNG_Graph_get_file;
drv.Line_width = PNG_Line_width;
drv.Set_window = PNG_Set_window;
drv.Begin_raster = PNG_begin_raster;
Modified: grass/trunk/lib/pngdriver/graph_set.c
--- grass/trunk/lib/pngdriver/graph_set.c 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/pngdriver/graph_set.c 2014-12-10 09:21:11 UTC (rev 63464)
@@ -171,3 +171,13 @@
return 0;
+ \return file name
+const char *PNG_Graph_get_file(void)
+ return png.file_name;
Modified: grass/trunk/lib/pngdriver/pngdriver.h
--- grass/trunk/lib/pngdriver/pngdriver.h 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/pngdriver/pngdriver.h 2014-12-10 09:21:11 UTC (rev 63464)
@@ -76,6 +76,7 @@
extern void PNG_Erase(void);
extern void PNG_Graph_close(void);
extern int PNG_Graph_set(void);
+extern const char *PNG_Graph_get_file(void);
extern void PNG_Line_width(double);
extern void PNG_begin_raster(int, int[2][2], double[2][2]);
extern int PNG_raster(int, int, const unsigned char *,
Modified: grass/trunk/lib/psdriver/driver.c
--- grass/trunk/lib/psdriver/driver.c 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/psdriver/driver.c 2014-12-10 09:21:11 UTC (rev 63464)
@@ -32,6 +32,7 @@
drv.Erase = PS_Erase;
drv.Graph_set = PS_Graph_set;
drv.Graph_close = PS_Graph_close;
+ drv.Graph_get_file = PS_Graph_get_file;
drv.Line_width = PS_Line_width;
drv.Set_window = PS_Set_window;
drv.Begin_raster = PS_begin_raster;
Modified: grass/trunk/lib/psdriver/graph_set.c
--- grass/trunk/lib/psdriver/graph_set.c 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/psdriver/graph_set.c 2014-12-10 09:21:11 UTC (rev 63464)
@@ -220,6 +220,16 @@
return 0;
+ \return file name
+const char *PS_Graph_get_file(void)
+ return file_name;
void output(const char *fmt, ...)
va_list va;
Modified: grass/trunk/lib/psdriver/psdriver.h
--- grass/trunk/lib/psdriver/psdriver.h 2014-12-10 08:31:23 UTC (rev 63463)
+++ grass/trunk/lib/psdriver/psdriver.h 2014-12-10 09:21:11 UTC (rev 63464)
@@ -31,6 +31,7 @@
extern void PS_Erase(void);
extern void PS_Graph_close(void);
extern int PS_Graph_set(void);
+extern const char *PS_Graph_get_file(void);
extern void PS_Line_width(double);
extern void PS_Set_window(double, double, double, double);
extern void PS_Color(int, int, int);
