[GRASS-SVN] r63466 - grass/trunk/display/d.mon
svn_grass at osgeo.org
Wed Dec 10 01:37:08 PST 2014
Author: martinl
Date: 2014-12-10 01:37:08 -0800 (Wed, 10 Dec 2014)
New Revision: 63466
grass/trunk/display/d.mon/start.c
d.mon: fix #2509 (d.mon output overwrite)
Modified: grass/trunk/display/d.mon/start.c
--- grass/trunk/display/d.mon/start.c 2014-12-10 09:28:58 UTC (rev 63465)
+++ grass/trunk/display/d.mon/start.c 2014-12-10 09:37:08 UTC (rev 63466)
@@ -24,7 +24,13 @@
output_name = D_get_file();
if (!output_name)
return;
- D_close_driver();
+ if (!G_get_overwrite() && access(output_name, F_OK) == 0) {
+ D_close_driver();
+ G_fatal_error(_("option <%s>: <%s> exists."),
+ "output", output_name);
+ D_close_driver(); /* must be called after check because this
+ * function produces default map file */
else {
output_name = output;
