[GRASS-SVN] r63475 - grass/trunk/gui/wxpython/mapdisp
svn_grass at osgeo.org
Wed Dec 10 13:41:10 PST 2014
Author: martinl
Date: 2014-12-10 13:41:10 -0800 (Wed, 10 Dec 2014)
New Revision: 63475
grass/trunk/gui/wxpython/mapdisp/main.py
d.mon wx0: don't call g.gisenv in the watcher (it's too much invasive) - TODO: find better solution
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py 2014-12-10 21:17:38 UTC (rev 63474)
+++ grass/trunk/gui/wxpython/mapdisp/main.py 2014-12-10 21:41:10 UTC (rev 63475)
@@ -412,14 +412,19 @@
"""Redraw, if new layer appears (check's timestamp of
cmdfile)
- try:
- # GISBASE and other sytem enviromental variables can not be used
+ ### TODO: fint better solution
+ ### the check bellow disabled, it's invasive to call g.gisenv
+ ### in the watcher...
+ # try:
+ # GISBASE and other system enviromental variables can not be used
# since the process inherited them from GRASS
# raises exception when vaiable does not exists
- grass.gisenv()['GISDBASE']
- except KeyError:
- self.timer.Stop()
- return
+ ### grass.gisenv()['GISDBASE']
+ # except KeyError:
+ # self.timer.Stop()
+ # return
# todo: events
try:
