[GRASS-SVN] r63479 - grass-addons/grass7/raster/r.mess
svn_grass at osgeo.org
Thu Dec 11 04:05:49 PST 2014
Author: pvanbosgeo
Date: 2014-12-11 04:05:49 -0800 (Thu, 11 Dec 2014)
New Revision: 63479
grass-addons/grass7/raster/r.mess/r.mess
Change organization guisections
Modified: grass-addons/grass7/raster/r.mess/r.mess
--- grass-addons/grass7/raster/r.mess/r.mess 2014-12-11 10:52:16 UTC (rev 63478)
+++ grass-addons/grass7/raster/r.mess/r.mess 2014-12-11 12:05:49 UTC (rev 63479)
@@ -66,6 +66,7 @@
#% key_desc: names
#% required: yes
#% multiple: yes
+#% guisection: predictors
#%end
#%option
@@ -76,6 +77,7 @@
#% key_desc: names
#% required: no
#% multiple: yes
#%end
#%option
@@ -85,6 +87,7 @@
#% description: Root name of the output MESS data layers
#% key_desc: name
#% required: yes
+#% guisection: Output
#%end
#%option
@@ -92,34 +95,37 @@
#% type: integer
#% description: Precision of your input layers values
#% key_desc: string
-#% answer: 1
-#% required: yes
+#% answer: 3
#%end
-##%flag # not implemented yet
-##% key: n
-##% description: Keep individual environmental similarity layers (IES)
-##% guisection: Additional statistics
-##%end
+#%flag: IES
+#% key: i
+#% description: Keep individual environmental similarity layers (IES)
+#%end
#%flag
#% key: m
#% description: Calculate Most dissimilar variable (MoD)
#%end
#%flag
#% key: k
#% description: Calculate mean of IES layers
#%end
#%flag
#% key: l
#% description: Calculate median of IES layers
#%end
#%flag
#% key: n
#% description: Area with negative MESS
#%end
@@ -330,7 +336,9 @@
ipl2 <- ipl
}else{
ipl2 <- unlist(strsplit(ipl2,","))
- if(length(ipl)!=length(ipl2)){stop("list with old and new environmental data layers is not of the same length")}
+ if(length(ipl)!=length(ipl2)){
+ stop("list with old and new environmental data layers is not of the same length")
opl <- Sys.getenv("arrOUT") # output layers
opl <- unlist(strsplit(opl,";"))
@@ -342,6 +350,7 @@
flk <- Sys.getenv("GIS_FLAG_K")
fll <- Sys.getenv("GIS_FLAG_L")
fln <- Sys.getenv("GIS_FLAG_N")
+IL <- Sys.getenv("GIS_FLAG_I")
digits <- as.numeric(Sys.getenv("GIS_OPT_DIGITS")) # Precision
digits2 <- 10^digits
options(echo=TRUE, digits=digits+4, scipen=digits+4)
@@ -407,6 +416,9 @@
write.table(xy2, file=tmp.rule, quote=F, row.names=F, col.names=F)
# Restore mask
+ # ToDo: as option, set region to env_new (and do not restore MASK, or have an option to set
+ # a new mask for the new scenario. This will make it possible to calculate MESS for new
+ # geographic areas outside the current region
if(citiam==0){
execGRASS("r.mask", flags="overwrite", raster=rname)
execGRASS("g.remove", flags="f", type="rast", name=rname)
@@ -439,6 +451,7 @@
execGRASS("v.extract", flags="t", input=vtl, type="point", output="tmpMESS976543210")
system(paste("v.db.addtable tmpMESS976543210 columns='", paste(ipn, " double precision", collapse=","), "'", sep=""))
+ execGRASS("db.execute", sql="CREATE UNIQUE INDEX tmpMESS123 ON tmpMESS976543210 (cat)")
# make compatible for both v6.4 and 7
if(grassversion==7){
@@ -531,6 +544,10 @@
system(paste("r.series output=", opc, "_median input=", paste(opi, collapse=","), " method=median", sep=""))
+if(IL==0){
+ system(paste("g.remove -f type=rast name=", paste(opi, collapse=","), sep=""))
EOF
