[GRASS-SVN] r63533 - in grass/branches/releasebranch_7_0: . display/d.mon include/defs lib/cairodriver lib/display lib/driver lib/htmldriver lib/pngdriver lib/psdriver
Sun Dec 14 01:58:50 PST 2014
Author: martinl
Date: 2014-12-14 01:58:50 -0800 (Sun, 14 Dec 2014)
New Revision: 63533
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/display/d.mon/start.c
   grass/branches/releasebranch_7_0/include/defs/display.h
   grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.h
   grass/branches/releasebranch_7_0/lib/cairodriver/driver.c
   grass/branches/releasebranch_7_0/lib/cairodriver/graph.c
   grass/branches/releasebranch_7_0/lib/display/r_raster.c
   grass/branches/releasebranch_7_0/lib/display/setup.c
   grass/branches/releasebranch_7_0/lib/driver/driver.h
   grass/branches/releasebranch_7_0/lib/driver/graph.c
   grass/branches/releasebranch_7_0/lib/htmldriver/driver.c
   grass/branches/releasebranch_7_0/lib/pngdriver/driver.c
   grass/branches/releasebranch_7_0/lib/pngdriver/graph_set.c
   grass/branches/releasebranch_7_0/lib/pngdriver/pngdriver.h
   grass/branches/releasebranch_7_0/lib/psdriver/driver.c
   grass/branches/releasebranch_7_0/lib/psdriver/graph_set.c
   grass/branches/releasebranch_7_0/lib/psdriver/psdriver.h
displaylib: add D_get_file (#2509)
d.mon: use always full path for output files (even if using default file name) - #2509
d.mon: fix #2509 (d.mon output overwrite)
d.mon: stop monitor on failure (#2509)
displaylib: display driver lower case by default (cosmetics)
d.mon: print warning when overwritting the output file
       (merge r63464-r63470 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,
 63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63302,63307,63315,63319,63330,63332,63339,63342,63345,63362,63367,63391,63393,63408-63409,63416-63417,63425,63427,63429,63431,63433,63451,63453,63457,63459,63473,63482,63497,63505,63508,63510,63515,63524,63526
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62831,62838,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,63076,63079,63081,
 63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63276,63279,63281,63283,63287,63290,63292,63302,63307,63315,63319,63330,63332,63339,63342,63345,63362,63367,63391,63393,63408-63409,63416-63417,63425,63427,63429,63431,63433,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63524,63526
Modified: grass/branches/releasebranch_7_0/display/d.mon/start.c
--- grass/branches/releasebranch_7_0/display/d.mon/start.c	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/display/d.mon/start.c	2014-12-14 09:58:50 UTC (rev 63533)
@@ -2,6 +2,7 @@
 #include <string.h>
 #include <grass/gis.h>
 #include <grass/spawn.h>
+#include <grass/display.h>
 #include <grass/glocale.h>
 #include "proto.h"
@@ -9,16 +10,43 @@
 static void start(const char *, const char *);
 static void start_wx(const char *, const char *, const char *,
 		     const char *, int, int);
+static void error_handler(void *);
 /* start file-based monitor */
 void start(const char *name, const char *output)
     char *env_name, output_path[GPATH_MAX];
+    const char *output_name;
-    if (!output)
-	return;
+    /* stop monitor on failure */
+    G_add_error_handler(error_handler, (char *)name);
+    if (!output) {
+        if (D_open_driver() != 0)
+            G_fatal_error(_("No graphics device selected. "
+                            "Use d.mon to select graphics device."));
+        output_name = D_get_file();
+        if (!output_name)
+            return;
+        if (access(output_name, F_OK) == 0) {
+            if (G_get_overwrite()) {
+                G_warning(_("File '%s' already exists and will be overwritten"), output_name);
+            else {
+                D_close_driver();
+                G_fatal_error(_("option <%s>: <%s> exists."),
+                              "output", output_name);
+        D_close_driver(); /* must be called after check because this
+                           * function produces default map file */
+    else {
+        output_name = output;
-    if (!strchr(output, HOST_DIRSEP)) { /* relative path */
+    if (!strchr(output_name, HOST_DIRSEP)) { /* relative path */
         char *ptr;
         if (!getcwd(output_path, GPATH_MAX))
@@ -28,13 +56,13 @@
             *(ptr++) = HOST_DIRSEP;
             *(ptr) = '\0';
-        strcat(output_path, output);
+        strcat(output_path, output_name);
         G_message(_("Output file: %s"), output_path);
     else {
-        strcpy(output_path, output); /* already full path */
+        strcpy(output_path, output_name); /* already full path */
     env_name = NULL;
     G_asprintf(&env_name, "MONITOR_%s_MAPFILE", G_store_upper(name));
     G_setenv(env_name, output_path);
@@ -157,3 +185,9 @@
     return 0;
+void error_handler(void *p)
+    const char *name = (const char *) p;
+    stop_mon(name);
Modified: grass/branches/releasebranch_7_0/include/defs/display.h
--- grass/branches/releasebranch_7_0/include/defs/display.h	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/include/defs/display.h	2014-12-14 09:58:50 UTC (rev 63533)
@@ -162,4 +162,6 @@
 void D_font_list(char ***, int *);
 void D_font_info(char ***, int *);
+const char *D_get_file(void);
 #endif /* GRASS_DISPLAYDEFS_H */
Modified: grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.h
--- grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.h	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/cairodriver/cairodriver.h	2014-12-14 09:58:50 UTC (rev 63533)
@@ -84,6 +84,7 @@
 extern void Cairo_Client_Close(void);
 extern int Cairo_Graph_set(void);
+extern const char *Cairo_Graph_get_file(void);
 extern void Cairo_Graph_close(void);
 extern void Cairo_Box(double, double, double, double);
 extern void Cairo_Set_window(double, double, double, double);
Modified: grass/branches/releasebranch_7_0/lib/cairodriver/driver.c
--- grass/branches/releasebranch_7_0/lib/cairodriver/driver.c	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/cairodriver/driver.c	2014-12-14 09:58:50 UTC (rev 63533)
@@ -3,7 +3,7 @@
   \brief GRASS cairo display driver - driver initialization
-  (C) 2007-2008, 2011 by Lars Ahlzen and the GRASS Development Team
+  (C) 2007-2014 by Lars Ahlzen and the GRASS Development Team
   This program is free software under the GNU General Public License
   (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -31,6 +31,7 @@
     drv.Box = Cairo_Box;
     drv.Erase = Cairo_Erase;
     drv.Graph_set = Cairo_Graph_set;
+    drv.Graph_get_file = Cairo_Graph_get_file;
     drv.Graph_close = Cairo_Graph_close;
     drv.Line_width = Cairo_Line_width;
     drv.Set_window = Cairo_Set_window;
@@ -51,7 +52,7 @@
     drv.Set_font = Cairo_set_font;
     drv.Font_list = Cairo_font_list;
     drv.Font_info = Cairo_font_info;
     initialized = 1;
     return &drv;
Modified: grass/branches/releasebranch_7_0/lib/cairodriver/graph.c
--- grass/branches/releasebranch_7_0/lib/cairodriver/graph.c	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/cairodriver/graph.c	2014-12-14 09:58:50 UTC (rev 63533)
@@ -286,6 +286,16 @@
+  \brief Get render file
+  \return file name
+const char *Cairo_Graph_get_file(void)
+    return ca.file_name;
   \brief Close driver
Modified: grass/branches/releasebranch_7_0/lib/display/r_raster.c
--- grass/branches/releasebranch_7_0/lib/display/r_raster.c	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/display/r_raster.c	2014-12-14 09:58:50 UTC (rev 63533)
@@ -135,9 +135,9 @@
     const struct driver *drv =
-	(p && G_strcasecmp(p, "PNG")   == 0) ? PNG_Driver() :
-	(p && G_strcasecmp(p, "PS")    == 0) ? PS_Driver() :
-	(p && G_strcasecmp(p, "HTML")  == 0) ? HTML_Driver() :
+	(p && G_strcasecmp(p, "png")   == 0) ? PNG_Driver() :
+	(p && G_strcasecmp(p, "ps")    == 0) ? PS_Driver() :
+	(p && G_strcasecmp(p, "html")  == 0) ? HTML_Driver() :
 #ifdef USE_CAIRO
 	(p && G_strcasecmp(p, "cairo") == 0) ? Cairo_Driver() :
 	Cairo_Driver();
Modified: grass/branches/releasebranch_7_0/lib/display/setup.c
--- grass/branches/releasebranch_7_0/lib/display/setup.c	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/display/setup.c	2014-12-14 09:58:50 UTC (rev 63533)
@@ -17,6 +17,8 @@
 #include <grass/raster.h>
+#include "driver.h"
   \brief Graphics frame setup
@@ -118,3 +120,13 @@
     if (clear)
 	D_erase(DEFAULT_BG_COLOR);
+  \brief Get driver output file
+  \return file name or NULL if not defined
+    return COM_Graph_get_file();
Modified: grass/branches/releasebranch_7_0/lib/driver/driver.h
--- grass/branches/releasebranch_7_0/lib/driver/driver.h	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/driver/driver.h	2014-12-14 09:58:50 UTC (rev 63533)
@@ -22,11 +22,12 @@
 struct driver
     char *name;
     void (*Box)(double, double, double, double);
     void (*Erase)(void);
     int (*Graph_set)(void);
     void (*Graph_close)(void);
+    const char * (*Graph_get_file)(void);
     void (*Line_width)(double);
     void (*Set_window)(double, double, double, double);
     void (*Begin_raster)(int, int[2][2], double[2][2]);
@@ -82,6 +83,7 @@
 /* graph.c */
 extern int COM_Graph_set(void);
 extern void COM_Graph_close(void);
+extern const char *COM_Graph_get_file(void);
 /* line_width.c */
 extern void COM_Line_width(double);
Modified: grass/branches/releasebranch_7_0/lib/driver/graph.c
--- grass/branches/releasebranch_7_0/lib/driver/graph.c	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/driver/graph.c	2014-12-14 09:58:50 UTC (rev 63533)
@@ -1,3 +1,4 @@
+#include <stdlib.h>
 #include "driver.h"
 #include "driverlib.h"
@@ -13,3 +14,11 @@
     if (driver->Graph_close)
 	(*driver->Graph_close) ();
+const char *COM_Graph_get_file(void)
+    if (driver->Graph_get_file)
+        return (*driver->Graph_get_file) ();
+    return NULL;
Modified: grass/branches/releasebranch_7_0/lib/htmldriver/driver.c
--- grass/branches/releasebranch_7_0/lib/htmldriver/driver.c	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/htmldriver/driver.c	2014-12-14 09:58:50 UTC (rev 63533)
@@ -30,6 +30,7 @@
     drv.Erase = NULL;
     drv.Graph_set = HTML_Graph_set;
     drv.Graph_close = HTML_Graph_close;
+    drv.Graph_get_file = NULL;
     drv.Line_width = NULL;
     drv.Set_window = NULL;
     drv.Begin_raster = NULL;
Modified: grass/branches/releasebranch_7_0/lib/pngdriver/driver.c
--- grass/branches/releasebranch_7_0/lib/pngdriver/driver.c	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/pngdriver/driver.c	2014-12-14 09:58:50 UTC (rev 63533)
@@ -3,7 +3,7 @@
   \brief GRASS png display driver - driver initialization
-  (C) 2007 by Glynn Clements and the GRASS Development Team
+  (C) 2007-2014 by Glynn Clements and the GRASS Development Team
@@ -31,6 +31,7 @@
     drv.Erase = PNG_Erase;
     drv.Graph_set = PNG_Graph_set;
     drv.Graph_close = PNG_Graph_close;
+    drv.Graph_get_file = PNG_Graph_get_file;
     drv.Line_width = PNG_Line_width;
     drv.Set_window = PNG_Set_window;
     drv.Begin_raster = PNG_begin_raster;
Modified: grass/branches/releasebranch_7_0/lib/pngdriver/graph_set.c
--- grass/branches/releasebranch_7_0/lib/pngdriver/graph_set.c	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/pngdriver/graph_set.c	2014-12-14 09:58:50 UTC (rev 63533)
@@ -171,3 +171,13 @@
     return 0;
+  \return file name
+const char *PNG_Graph_get_file(void)
+    return png.file_name;
Modified: grass/branches/releasebranch_7_0/lib/pngdriver/pngdriver.h
--- grass/branches/releasebranch_7_0/lib/pngdriver/pngdriver.h	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/pngdriver/pngdriver.h	2014-12-14 09:58:50 UTC (rev 63533)
@@ -76,6 +76,7 @@
 extern void PNG_Erase(void);
 extern void PNG_Graph_close(void);
 extern int PNG_Graph_set(void);
+extern const char *PNG_Graph_get_file(void);
 extern void PNG_Line_width(double);
 extern void PNG_begin_raster(int, int[2][2], double[2][2]);
 extern int PNG_raster(int, int, const unsigned char *,
Modified: grass/branches/releasebranch_7_0/lib/psdriver/driver.c
--- grass/branches/releasebranch_7_0/lib/psdriver/driver.c	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/psdriver/driver.c	2014-12-14 09:58:50 UTC (rev 63533)
@@ -32,6 +32,7 @@
     drv.Erase = PS_Erase;
     drv.Graph_set = PS_Graph_set;
     drv.Graph_close = PS_Graph_close;
+    drv.Graph_get_file = PS_Graph_get_file;
     drv.Line_width = PS_Line_width;
     drv.Set_window = PS_Set_window;
     drv.Begin_raster = PS_begin_raster;
Modified: grass/branches/releasebranch_7_0/lib/psdriver/graph_set.c
--- grass/branches/releasebranch_7_0/lib/psdriver/graph_set.c	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/psdriver/graph_set.c	2014-12-14 09:58:50 UTC (rev 63533)
@@ -220,6 +220,16 @@
     return 0;
+  \return file name
+const char *PS_Graph_get_file(void)
+    return file_name;
 void output(const char *fmt, ...)
     va_list va;
Modified: grass/branches/releasebranch_7_0/lib/psdriver/psdriver.h
--- grass/branches/releasebranch_7_0/lib/psdriver/psdriver.h	2014-12-13 23:40:06 UTC (rev 63532)
+++ grass/branches/releasebranch_7_0/lib/psdriver/psdriver.h	2014-12-14 09:58:50 UTC (rev 63533)
@@ -31,6 +31,7 @@
 extern void PS_Erase(void);
 extern void PS_Graph_close(void);
 extern int PS_Graph_set(void);
+extern const char *PS_Graph_get_file(void);
 extern void PS_Line_width(double);
 extern void PS_Set_window(double, double, double, double);
 extern void PS_Color(int, int, int);
