[GRASS-SVN] r63544 - in grass/trunk/gui/wxpython: animation core gui_core lmgr mapdisp mapswipe nviz vdigit
svn_grass at osgeo.org
Sun Dec 14 19:45:26 PST 2014
Author: annakrat
Date: 2014-12-14 19:45:26 -0800 (Sun, 14 Dec 2014)
New Revision: 63544
grass/trunk/gui/wxpython/animation/nviztask.py
grass/trunk/gui/wxpython/core/settings.py
grass/trunk/gui/wxpython/core/workspace.py
grass/trunk/gui/wxpython/gui_core/preferences.py
grass/trunk/gui/wxpython/lmgr/frame.py
grass/trunk/gui/wxpython/lmgr/layertree.py
grass/trunk/gui/wxpython/mapdisp/statusbar.py
grass/trunk/gui/wxpython/mapswipe/dialogs.py
grass/trunk/gui/wxpython/nviz/mapwindow.py
grass/trunk/gui/wxpython/nviz/preferences.py
grass/trunk/gui/wxpython/nviz/tools.py
grass/trunk/gui/wxpython/nviz/workspace.py
grass/trunk/gui/wxpython/vdigit/mapwindow.py
grass/trunk/gui/wxpython/vdigit/toolbars.py
wxGUI/settings: make dialog nonmodal and destroy it instead of hiding (caused problems on MacOSX with wxPython3); make apply button label more understandable; fix Set to default behavior not to apply changes but just set default values in widgets
Modified: grass/trunk/gui/wxpython/animation/nviztask.py
--- grass/trunk/gui/wxpython/animation/nviztask.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/animation/nviztask.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -139,7 +139,7 @@
if 'marker' in points:
marker = list(UserSettings.Get(group='nviz', key='vector',
subkey=['points', 'marker'],
- internal=True))[points['marker']['value']]
+ settings_type='internal'))[points['marker']['value']]
self._setMultiTaskParam('vpoint_marker', marker)
if 'mode' in points:
if points['mode']['type'] == '3d':
Modified: grass/trunk/gui/wxpython/core/settings.py
--- grass/trunk/gui/wxpython/core/settings.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/core/settings.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -1063,23 +1063,26 @@
return value
- def Get(self, group, key = None, subkey = None, internal = False):
+ def Get(self, group, key=None, subkey=None, settings_type='user'):
"""Get value by key/subkey
Raise KeyError if key is not found
:param group: settings group
:param key: (value, None)
:param subkey: (value, list or None)
- :param internal: use internal settings instead
+ :param settings_type: 'user', 'internal', 'default'
:return: value
- if internal is True:
+ if settings_type == 'user':
+ settings = self.userSettings
+ elif settings_type == 'internal':
settings = self.internalSettings
else:
- settings = self.userSettings
+ settings = self.defaultSettings
try:
if subkey is None:
if key is None:
@@ -1091,28 +1094,31 @@
type(subkey) == type(list()):
return settings[group][key][subkey[0]][subkey[1]]
else:
- return settings[group][key][subkey]
+ return settings[group][key][subkey]
except KeyError:
print >> sys.stderr, "Settings: unable to get value '%s:%s:%s'\n" % \
(group, key, subkey)
- def Set(self, group, value, key = None, subkey = None, internal = False):
+ def Set(self, group, value, key=None, subkey=None, settings_type='user'):
"""Set value of key/subkey
Raise KeyError if group/key is not found
:param key: key (value, None)
:param subkey: subkey (value, list or None)
:param value: value
else:
try:
if subkey is None:
if key is None:
@@ -1127,7 +1133,7 @@
settings[group][key][subkey] = value
except KeyError:
raise GException("%s '%s:%s:%s'" % (_("Unable to set "), group, key, subkey))
def Append(self, dict, group, key, subkey, value, overwrite = True):
Modified: grass/trunk/gui/wxpython/core/workspace.py
--- grass/trunk/gui/wxpython/core/workspace.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/core/workspace.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -482,7 +482,7 @@
marker = str(nodePoints.get('marker', ''))
markerId = list(UserSettings.Get(group='nviz', key='vector',
- subkey=['points', 'marker'], internal=True)).index(marker)
+ subkey=['points', 'marker'], settings_type='internal')).index(marker)
nvizData['vector']['points']['marker'] = {'value': markerId}
node_mode = nodePoints.find('mode')
@@ -1118,7 +1118,7 @@
elif attrb == 'points':
markerId = data[attrb]['marker']['value']
marker = UserSettings.Get(group = 'nviz', key = 'vector',
- subkey = ['points', 'marker'], internal = True)[markerId]
+ subkey = ['points', 'marker'], settings_type='internal')[markerId]
self.file.write('%s<v%s marker="%s">\n' % (' ' * self.indent,
attrb,
marker))
Modified: grass/trunk/gui/wxpython/gui_core/preferences.py
--- grass/trunk/gui/wxpython/gui_core/preferences.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/gui_core/preferences.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -85,9 +85,10 @@
# bindigs
self.btnDefault.Bind(wx.EVT_BUTTON, self.OnDefault)
- self.btnDefault.SetToolTipString(_("Revert settings to default and apply changes"))
+ self.btnDefault.SetToolTipString(_("Revert settings to default"))
self.btnApply.Bind(wx.EVT_BUTTON, self.OnApply)
- self.btnApply.SetToolTipString(_("Apply changes for the current session"))
+ self.btnApply.SetToolTipString(_("Apply changes for the current session only and close"))
+ self.btnApply.SetLabel(_("Save for this session only"))
self.btnSave.Bind(wx.EVT_BUTTON, self.OnSave)
self.btnSave.SetToolTipString(_("Apply and save changes to user settings file (default for next sessions)"))
self.btnSave.SetDefault()
@@ -119,21 +120,19 @@
self.SetSizer(mainSizer)
mainSizer.Fit(self)
def OnDefault(self, event):
"""Button 'Set to default' pressed"""
- self.settings.userSettings = copy.deepcopy(self.settings.defaultSettings)
# update widgets
for gks in self.winId.keys():
try:
group, key, subkey = gks.split(':')
- value = self.settings.Get(group, key, subkey)
+ value = self.settings.Get(group, key, subkey, settings_type='default')
except ValueError:
group, key, subkey, subkey1 = gks.split(':')
- value = self.settings.Get(group, key, [subkey, subkey1])
+ value = self.settings.Get(group, key, [subkey, subkey1], settings_type='default')
win = self.FindWindowById(self.winId[gks])
if win.GetName() in ('GetValue', 'IsChecked'):
value = win.SetValue(value)
elif win.GetName() == 'GetSelection':
@@ -144,7 +143,7 @@
value = win.SetLabel(value)
else:
def OnApply(self, event):
"""Button 'Apply' pressed
Emits signal settingsChanged.
@@ -155,7 +154,8 @@
self.Close()
def OnCloseWindow(self, event):
- self.Hide()
+ event.Skip()
+ self.Destroy()
def OnCancel(self, event):
"""Button 'Cancel' pressed"""
@@ -414,7 +414,7 @@
wx.ALIGN_CENTER_VERTICAL,
pos = (row, 0))
locales = self.settings.Get(group = 'language', key = 'locale',
- subkey = 'choices', internal = True)
+ subkey = 'choices', settings_type='internal')
loc = self.settings.Get(group = 'language', key = 'locale', subkey = 'lc_all')
elementList = wx.Choice(parent = panel, id = wx.ID_ANY, size = (325, -1),
choices = locales, name = "GetStringSelection")
@@ -450,7 +450,7 @@
pos = (row, 0))
choices = self.settings.Get(group = 'appearance', key = 'elementListExpand',
- subkey = 'choices', internal = True),
+ subkey = 'choices', settings_type='internal'),
name = "GetSelection")
elementList.SetSelection(self.settings.Get(group = 'appearance', key = 'elementListExpand',
subkey = 'selection'))
@@ -471,7 +471,7 @@
pos = (row, 0))
listOfStyles = self.settings.Get(group = 'appearance', key = 'menustyle',
+ subkey='choices', settings_type='internal')
menuItemText = wx.Choice(parent = panel, id = wx.ID_ANY, size = (325, -1),
choices = listOfStyles,
@@ -494,8 +494,8 @@
flag = wx.ALIGN_LEFT |
pos = (row, 0))
- min = self.settings.Get(group = 'appearance', key = 'gSelectPopupHeight', subkey = 'min', internal = True)
- max = self.settings.Get(group = 'appearance', key = 'gSelectPopupHeight', subkey = 'max', internal = True)
+ min = self.settings.Get(group = 'appearance', key = 'gSelectPopupHeight', subkey = 'min', settings_type='internal')
+ max = self.settings.Get(group = 'appearance', key = 'gSelectPopupHeight', subkey = 'max', settings_type='internal')
value = self.settings.Get(group = 'appearance', key = 'gSelectPopupHeight', subkey = 'value')
popupHeightSpin = wx.SpinCtrl(parent = panel, id = wx.ID_ANY, size = (100, -1))
@@ -520,7 +520,7 @@
pos = (row, 0))
iconTheme = wx.Choice(parent = panel, id = wx.ID_ANY, size = (100, -1),
choices = self.settings.Get(group = 'appearance', key = 'iconTheme',
iconTheme.SetStringSelection(self.settings.Get(group = 'appearance', key = 'iconTheme', subkey = 'type'))
self.winId['appearance:iconTheme:type'] = iconTheme.GetId()
@@ -540,7 +540,7 @@
pos = (row, 0))
styleList = wx.Choice(parent = panel, id = wx.ID_ANY, size = (325, -1),
choices = self.settings.Get(group = 'appearance', key = 'commandNotebook',
styleList.SetSelection(self.settings.Get(group = 'appearance', key = 'commandNotebook',
@@ -613,7 +613,7 @@
pos = (row, 0))
- listOfDrivers = self.settings.Get(group = 'display', key = 'driver', subkey = 'choices', internal = True)
+ listOfDrivers = self.settings.Get(group = 'display', key = 'driver', subkey = 'choices', settings_type='internal')
driver = wx.Choice(parent = panel, id = wx.ID_ANY, size = (150, -1),
choices = listOfDrivers,
@@ -633,7 +633,7 @@
pos = (row, 0))
- listOfModes = self.settings.Get(group = 'display', key = 'statusbarMode', subkey = 'choices', internal = True)
+ listOfModes = self.settings.Get(group = 'display', key = 'statusbarMode', subkey = 'choices', settings_type='internal')
statusbarMode = wx.Choice(parent = panel, id = wx.ID_ANY, size = (150, -1),
choices = listOfModes,
@@ -724,7 +724,7 @@
pos = (row, 0))
- listOfModes = self.settings.Get(group = 'display', key = 'mouseWheelZoom', subkey = 'choices', internal = True)
+ listOfModes = self.settings.Get(group = 'display', key = 'mouseWheelZoom', subkey = 'choices', settings_type='internal')
zoomAction = wx.Choice(parent = panel, id = wx.ID_ANY, size = (200, -1),
@@ -739,7 +739,7 @@
pos = (row, 0))
- listOfModes = self.settings.Get(group = 'display', key = 'scrollDirection', subkey = 'choices', internal = True)
+ listOfModes = self.settings.Get(group = 'display', key = 'scrollDirection', subkey = 'choices', settings_type='internal')
scrollDir = wx.Choice(parent = panel, id = wx.ID_ANY, size = (200, -1),
@@ -859,7 +859,7 @@
pos = (row, 0))
verbosity = wx.Choice(parent = panel, id = wx.ID_ANY, size = (200, -1),
- choices = self.settings.Get(group = 'cmd', key = 'verbosity', subkey = 'choices', internal = True),
+ choices = self.settings.Get(group = 'cmd', key = 'verbosity', subkey = 'choices', settings_type='internal'),
verbosity.SetStringSelection(self.settings.Get(group = 'cmd', key = 'verbosity', subkey = 'selection'))
self.winId['cmd:verbosity:selection'] = verbosity.GetId()
@@ -1113,7 +1113,7 @@
flexSizer.AddGrowableCol(0)
label = wx.StaticText(parent = panel, id = wx.ID_ANY, label = _("Left mouse double click:"))
leftDbClick = wx.Choice(parent = panel, id = wx.ID_ANY,
- choices = self.settings.Get(group = 'atm', key = 'leftDbClick', subkey = 'choices', internal = True),
+ choices = self.settings.Get(group = 'atm', key = 'leftDbClick', subkey = 'choices', settings_type='internal'),
leftDbClick.SetSelection(self.settings.Get(group = 'atm', key = 'leftDbClick', subkey = 'selection'))
self.winId['atm:leftDbClick:selection'] = leftDbClick.GetId()
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -1534,14 +1534,15 @@
"""General GUI preferences/settings
if not self.dialogs['preferences']:
- dlg = PreferencesDialog(parent = self, giface = self._giface)
+ dlg = PreferencesDialog(parent=self, giface=self._giface)
self.dialogs['preferences'] = dlg
- self.dialogs['preferences'].CenterOnScreen()
+ self.dialogs['preferences'].CenterOnParent()
dlg.settingsChanged.connect(self.OnSettingsChanged)
+ self.Bind(wx.EVT_CLOSE, lambda evt: self.dialogs.update(preferences=None), dlg)
+ self.dialogs['preferences'].Show()
- self.dialogs['preferences'].ShowModal()
def OnNvizPreferences(self, event):
"""Show nviz preferences"""
if not self.dialogs['nvizPreferences']:
Modified: grass/trunk/gui/wxpython/lmgr/layertree.py
--- grass/trunk/gui/wxpython/lmgr/layertree.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/lmgr/layertree.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -1450,7 +1450,7 @@
if digitToolbar:
mapLayer = self.GetLayerInfo(layer, key = 'maplayer')
bgmap = UserSettings.Get(group = 'vdigit', key = 'bgmap', subkey = 'value',
- internal = True)
if digitToolbar.GetLayer() == mapLayer:
self._setGradient('vdigit')
Modified: grass/trunk/gui/wxpython/mapdisp/statusbar.py
--- grass/trunk/gui/wxpython/mapdisp/statusbar.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/mapdisp/statusbar.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -205,7 +205,7 @@
subkey = 'choices',
value = self.choice.GetItems(),
- internal = True)
if not self._modeIndexSet:
self.choice.SetSelection(UserSettings.Get(group = 'display',
Modified: grass/trunk/gui/wxpython/mapswipe/dialogs.py
--- grass/trunk/gui/wxpython/mapswipe/dialogs.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/mapswipe/dialogs.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -256,7 +256,7 @@
flag=wx.ALIGN_LEFT | wx.ALIGN_CENTER_VERTICAL, pos=(row, 0))
cursors = wx.Choice(parent=panel,
choices=self.settings.Get(group='mapswipe', key='cursor',
- subkey=['type', 'choices'], internal=True),
+ subkey=['type', 'choices'], settings_type='internal'),
name="GetSelection")
cursors.SetSelection(self.settings.Get(group='mapswipe', key='cursor',
subkey=['type', 'selection']))
Modified: grass/trunk/gui/wxpython/nviz/mapwindow.py
--- grass/trunk/gui/wxpython/nviz/mapwindow.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/nviz/mapwindow.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -182,7 +182,7 @@
# default values
self.nvizDefault = NvizSettings()
self.view = copy.deepcopy(UserSettings.Get(group = 'nviz', key = 'view')) # copy
- self.iview = UserSettings.Get(group = 'nviz', key = 'view', internal = True)
+ self.iview = UserSettings.Get(group='nviz', key='view', settings_type='internal')
self.light = copy.deepcopy(UserSettings.Get(group = 'nviz', key = 'light')) # copy
self.decoration = self.nvizDefault.SetDecorDefaultProp(type = 'arrow')
self.decoration['scalebar'] = []
Modified: grass/trunk/gui/wxpython/nviz/preferences.py
--- grass/trunk/gui/wxpython/nviz/preferences.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/nviz/preferences.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -64,7 +64,7 @@
row = 0
# perspective
pvals = UserSettings.Get(group = 'nviz', key = 'view', subkey = 'persp')
- ipvals = UserSettings.Get(group = 'nviz', key = 'view', subkey = 'persp', internal = True)
+ ipvals = UserSettings.Get(group='nviz', key='view', subkey='persp', settings_type='internal')
gridSizer.Add(item = wx.StaticText(parent = panel, id = wx.ID_ANY,
label = _("Perspective:")),
pos = (row, 0), flag = wx.ALIGN_CENTER_VERTICAL)
@@ -127,7 +127,7 @@
# twist
tvals = UserSettings.Get(group = 'nviz', key = 'view', subkey = 'twist')
- itvals = UserSettings.Get(group = 'nviz', key = 'view', subkey = 'twist', internal = True)
+ itvals = UserSettings.Get(group='nviz', key='view', subkey='twist', settings_type='internal')
label = _("Twist:")),
@@ -532,7 +532,7 @@
pos = (row, 2), flag = wx.ALIGN_CENTER_VERTICAL)
isym = wx.Choice (parent = panel, id = wx.ID_ANY, size = (100, -1),
choices = UserSettings.Get(group = 'nviz', key = 'vector',
- subkey = ['points', 'marker'], internal = True))
isym.SetName("GetSelection")
self.winId['nviz:vector:points:marker'] = isym.GetId()
isym.SetSelection(UserSettings.Get(group = 'nviz', key = 'vector',
Modified: grass/trunk/gui/wxpython/nviz/tools.py
--- grass/trunk/gui/wxpython/nviz/tools.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/nviz/tools.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -1420,7 +1420,7 @@
pos = (0, 5), flag = wx.ALIGN_CENTER_VERTICAL | wx.ALIGN_RIGHT)
isym.SetName("selection")
self.win['vector']['points']['marker'] = isym.GetId()
isym.Bind(wx.EVT_CHOICE, self.OnVectorPoints)
Modified: grass/trunk/gui/wxpython/nviz/workspace.py
--- grass/trunk/gui/wxpython/nviz/workspace.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/nviz/workspace.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -344,7 +344,7 @@
subkey='color')[:3])
data['arrow'].update(copy.deepcopy(UserSettings.Get(group='nviz',
key='arrow',
- internal=True)))
+ settings_type='internal')))
data['arrow']['show'] = False
# arrow
@@ -356,6 +356,6 @@
data['scalebar'].update(copy.deepcopy(UserSettings.Get(group='nviz',
key='scalebar',
- internal=True)))
data['scalebar']['id'] = 0
return data
Modified: grass/trunk/gui/wxpython/vdigit/mapwindow.py
--- grass/trunk/gui/wxpython/vdigit/mapwindow.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/vdigit/mapwindow.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -756,7 +756,7 @@
pos2 = self.Pixel2Cell(self.mouse['end'])
if UserSettings.Get(group = 'vdigit', key = 'bgmap',
- subkey = 'value', internal = True) == '':
+ subkey='value', settings_type='internal') == '':
# no background map -> copy from current vector map layer
nselected = self.digit.GetDisplay().SelectLinesByBox((pos1, pos2))
@@ -774,7 +774,7 @@
colorStr = str(color[0]) + ":" + str(color[1]) + ":" + str(color[2])
dVectTmp = ['d.vect',
'map=%s' % UserSettings.Get(group = 'vdigit', key = 'bgmap',
- subkey = 'value', internal = True),
+ subkey='value', settings_type='internal'),
'cats=%s' % ListOfCatsToRange(self.copyIds),
'-i',
'color=%s' % colorStr,
Modified: grass/trunk/gui/wxpython/vdigit/toolbars.py
--- grass/trunk/gui/wxpython/vdigit/toolbars.py 2014-12-14 22:19:53 UTC (rev 63543)
+++ grass/trunk/gui/wxpython/vdigit/toolbars.py 2014-12-15 03:45:26 UTC (rev 63544)
@@ -597,14 +597,14 @@
# close open background map if any
bgMap = UserSettings.Get(group = 'vdigit', key = 'bgmap', subkey = 'value',
- internal = True)
if bgMap:
self.digit.CloseBackgroundMap()
self.editingBgMap.emit(mapName = bgMap, unset=True)
# open background map for reading
UserSettings.Set(group = 'vdigit', key = 'bgmap', subkey = 'value',
- value = str(mapName), internal = True)
+ value=str(mapName), settings_type='internal')
self.digit.OpenBackgroundMap(mapName)
self.editingBgMap.emit(mapName = mapName)
@@ -867,7 +867,7 @@
subkey = 'value', internal = True) == mapLayer.GetName():
- subkey = 'value', value = '', internal = True)
+ subkey='value', value='', settings_type='internal')
self.parent.SetStatusText(_("Please wait, "
"opening vector map <%s> for editing...") % mapLayer.GetName(),
@@ -979,7 +979,7 @@
- internal = True)
if bgMap:
