[GRASS-SVN] r63554 - in grass/trunk/lib: display pngdriver
svn_grass at osgeo.org
Mon Dec 15 04:40:52 PST 2014
Author: martinl
Date: 2014-12-15 04:40:52 -0800 (Mon, 15 Dec 2014)
New Revision: 63554
grass/trunk/lib/display/raster.c
grass/trunk/lib/pngdriver/raster.c
displaylib: doxygen cosmetics
Modified: grass/trunk/lib/display/raster.c
--- grass/trunk/lib/display/raster.c 2014-12-15 12:29:22 UTC (rev 63553)
+++ grass/trunk/lib/display/raster.c 2014-12-15 12:40:52 UTC (rev 63554)
@@ -27,40 +27,26 @@
static int draw_cell(int, const void *, struct Colors *, RASTER_MAP_TYPE);
-/* routines used by programs such as Dcell, display, combine, and weight
- * for generating raster images (for 1-byte, i.e. not super-cell, data)
- * D_cell_draw_setup(t, b, l, r)
- * int t, b, l, r (pixle extents of display window)
- * (obtainable via D_get_dst(&t, &b, &l, &r)
- * Sets up the environment for D_draw_cell
- * D_draw_cell(A_row, xarray, colors)
- * int A_row ;
- * CELL *xarray ;
- * - determinew which pixle row gets the data
- * - resamples the data to create a pixle array
- * - determines best way to draw the array
- * a - for single cat array, a move and a draw
- * b - otherwise, a call to D_raster()
- * - returns -1 on error or end of picture
- * or array row number needed for next pixle row.
- * presumes the map is drawn from north to south
- * ALSO: if overlay mode is desired, then call D_set_overlay_mode(1)
- * first.
\brief Draw raster row
- \param A_row row number
- \param array
+ - determine which pixel row gets the data
+ - resamples the data to create a pixel array
+ - determines best way to draw the array
+ a - for single cat array, a move and a draw
+ b - otherwise, a call to D_raster()
+ Presumes the map is drawn from north to south.
+ If overlay mode is desired, then call D_set_overlay_mode() first.
+ \param A_row row number (starts at 0)
+ \param array data buffer
\param colors pointer to Colors structure
\param data_type raster type (CELL, FCELL, DCELL)
- \return
+ \return next row number needed for next pixel row
+ \return -1 nothing to draw (on error or end of raster)
int D_draw_raster(int A_row,
const void *array,
@@ -72,8 +58,8 @@
\brief Draw raster row (DCELL)
- \param darray
+ \param darray data buffer
\return
@@ -129,7 +115,8 @@
\param carray
- \return
+ \return next row to draw
int D_draw_cell(int A_row, const CELL * carray, struct Colors *colors)
Modified: grass/trunk/lib/pngdriver/raster.c
--- grass/trunk/lib/pngdriver/raster.c 2014-12-15 12:29:22 UTC (rev 63553)
+++ grass/trunk/lib/pngdriver/raster.c 2014-12-15 12:40:52 UTC (rev 63554)
@@ -102,8 +102,8 @@
- \param n number of cell
- \param row raster row
+ \param n number of cells
+ \param row raster row (starts at 0)
\param red,grn,blu,nul red,green,blue and null value
\return next row
