[GRASS-SVN] r63569 - grass/branches/releasebranch_7_0/raster/r.in.gdal
svn_grass at osgeo.org
Tue Dec 16 00:39:59 PST 2014
Author: mmetz
Date: 2014-12-16 00:39:59 -0800 (Tue, 16 Dec 2014)
New Revision: 63569
grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c
r.in.gdal: sync to trunk
Modified: grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c
--- grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c 2014-12-16 08:35:02 UTC (rev 63568)
+++ grass/branches/releasebranch_7_0/raster/r.in.gdal/main.c 2014-12-16 08:39:59 UTC (rev 63569)
@@ -18,6 +18,8 @@
#include <stdlib.h>
+#include <stdio.h>
+#include <errno.h>
#include <unistd.h>
#include <math.h>
#include <string.h>
@@ -39,7 +41,7 @@
struct Ref *group_ref);
static void SetupReprojector(const char *pszSrcWKT, const char *pszDstLoc,
struct pj_info *iproj, struct pj_info *oproj);
+static int dump_rat(GDALRasterBandH hBand, char *outrat, int nBand);
static int l1bdriver;
@@ -59,6 +61,7 @@
GDALDriverH hDriver;
GDALRasterBandH hBand;
double adfGeoTransform[6];
+ int n_bands;
int force_imagery = FALSE;
char error_msg[8096];
int projcomp_error = 0;
@@ -68,7 +71,8 @@
struct GModule *module;
struct
- struct Option *input, *output, *target, *title, *outloc, *band, *memory, *offset;
+ struct Option *input, *output, *target, *title, *outloc, *band,
+ *memory, *offset, *rat;
} parm;
struct Flag *flag_o, *flag_e, *flag_k, *flag_f, *flag_l, *flag_c;
@@ -94,8 +98,9 @@
parm.band = G_define_option();
parm.band->key = "band";
parm.band->type = TYPE_INTEGER;
+ parm.band->multiple = YES;
parm.band->required = NO;
- parm.band->description = _("Band to select (default is all bands)");
+ parm.band->description = _("Band(s) to select (default is all bands)");
parm.memory = G_define_option();
parm.memory->key = "memory";
@@ -138,6 +143,14 @@
parm.outloc->description = _("Name for new location to create");
parm.outloc->key_desc = "name";
+ parm.rat = G_define_option();
+ parm.rat->key = "table";
+ parm.rat->type = TYPE_STRING;
+ parm.rat->required = NO;
+ parm.rat->label = _("File prefix for raster attribute tables");
+ parm.rat->description = _("The band number and \".csv\" will be appended to the file prefix");
+ parm.rat->key_desc = "file";
flag_o = G_define_flag();
flag_o->key = 'o';
flag_o->description =
@@ -495,7 +508,13 @@
/* Do we want to generate a simple raster, or an imagery group? */
- if ((GDALGetRasterCount(hDS) > 1 && parm.band->answer == NULL)
+ n_bands = 0;
+ if (parm.band->answer != NULL) {
+ while (parm.band->answers[n_bands])
+ n_bands++;
+ if ((GDALGetRasterCount(hDS) > 1 && n_bands != 1)
|| GDALGetGCPCount(hDS) > 0)
force_imagery = TRUE;
@@ -506,7 +525,7 @@
int nBand = 1;
- nBand = atoi(parm.band->answer);
+ nBand = atoi(parm.band->answers[0]);
hBand = GDALGetRasterBand(hDS, nBand);
if (hBand == NULL) {
@@ -514,6 +533,8 @@
ImportBand(hBand, output, NULL);
+ if (parm.rat->answer)
+ dump_rat(hBand, parm.rat->answer, nBand);
if (title)
Rast_put_cell_title(output, title);
@@ -526,13 +547,26 @@
else {
struct Ref ref;
char szBandName[512];
- int nBand;
+ int nBand = 0;
char colornamebuf[512], colornamebuf2[512];
I_init_group_ref(&ref);
colornamebuf2[0] = '\0';
- for (nBand = 1; nBand <= GDALGetRasterCount(hDS); nBand++) {
+ n_bands = 0;
+ while (TRUE) {
+ if (parm.band->answers[n_bands] == NULL)
+ break;
+ nBand = atoi(parm.band->answers[n_bands++]);
+ else {
+ if (nBand >= GDALGetRasterCount(hDS))
+ break;
+ nBand++;
G_debug(3, "Import raster band %d", nBand);
if (!hBand)
@@ -1131,7 +1165,8 @@
GDALRATFieldUsage field_use;
struct Colors colors;
DCELL val1, val2;
- int r1, g1, b1, r2, g2, b2;
+ double r1, g1, b1, r2, g2, b2;
+ int cf;
Rast_init_colors(&colors);
@@ -1166,11 +1201,15 @@
else if (field_use == GFU_BlueMax)
bmaxc = indx;
+ /* guess color range 0, 1 or 0, 255 */
if (minc >= 0 && maxc >= 0 && rminc >= 0 && rmaxc >= 0 &&
gminc >= 0 && gmaxc >= 0 && bminc >= 0 && bmaxc >= 0) {
+ cf = 1;
- /* fetch color rules */
+ /* analyze color rules */
for (indx = 0; indx < nrows; indx++) {
val1 = GDALRATGetValueAsDouble(gdal_rat, indx, minc);
val2 = GDALRATGetValueAsDouble(gdal_rat, indx, maxc);
@@ -1183,26 +1222,120 @@
g2 = GDALRATGetValueAsDouble(gdal_rat, indx, gmaxc);
b2 = GDALRATGetValueAsDouble(gdal_rat, indx, bmaxc);
- Rast_add_d_color_rule(&val1, r1, g1, b1,
- &val2, r2, g2, b2,
- &colors);
+ if (r1 > 0.0 && r1 < 1.0)
+ cf = 255;
+ else if (cf == 255 && r1 > 1.0) {
+ cf = 0;
+ break;
+ if (g1 > 0.0 && g1 < 1.0)
+ cf = 255;
+ else if (cf == 255 && g1 > 1.0) {
+ cf = 0;
+ break;
+ if (b1 > 0.0 && b1 < 1.0)
+ cf = 255;
+ else if (cf == 255 && b1 > 1.0) {
+ cf = 0;
+ break;
+ if (r2 > 0.0 && r2 < 1.0)
+ cf = 255;
+ else if (cf == 255 && r2 > 1.0) {
+ cf = 0;
+ break;
+ if (g2 > 0.0 && g2 < 1.0)
+ cf = 255;
+ else if (cf == 255 && g2 > 1.0) {
+ cf = 0;
+ break;
+ if (b2 > 0.0 && b2 < 1.0)
+ cf = 255;
+ else if (cf == 255 && b2 > 1.0) {
+ cf = 0;
+ break;
+ if (cf == 0)
+ G_warning(_("Inconsistent color rules in RAT"));
+ else {
+ /* fetch color rules */
+ for (indx = 0; indx < nrows; indx++) {
+ val1 = GDALRATGetValueAsDouble(gdal_rat, indx, minc);
+ val2 = GDALRATGetValueAsDouble(gdal_rat, indx, maxc);
+ r1 = GDALRATGetValueAsDouble(gdal_rat, indx, rminc);
+ g1 = GDALRATGetValueAsDouble(gdal_rat, indx, gminc);
+ b1 = GDALRATGetValueAsDouble(gdal_rat, indx, bminc);
+ r2 = GDALRATGetValueAsDouble(gdal_rat, indx, rmaxc);
+ g2 = GDALRATGetValueAsDouble(gdal_rat, indx, gmaxc);
+ b2 = GDALRATGetValueAsDouble(gdal_rat, indx, bmaxc);
+ Rast_add_d_color_rule(&val1, r1 * cf, g1 * cf, b1 * cf,
+ &val2, r2 * cf, g2 * cf, b2 * cf,
+ &colors);
else if (minmaxc >= 0 && rc >= 0 && gc >= 0 && bc >= 0) {
- if (minc < 0)
- minc = maxc;
+ cf = 1;
- /* fetch color table */
+ /* analyze color table */
val1 = GDALRATGetValueAsDouble(gdal_rat, indx, minmaxc);
r1 = GDALRATGetValueAsDouble(gdal_rat, indx, rc);
g1 = GDALRATGetValueAsDouble(gdal_rat, indx, gc);
b1 = GDALRATGetValueAsDouble(gdal_rat, indx, bc);
- Rast_set_d_color(val1, r1, g1, b1, &colors);
+ cf = 255;
+ cf = 0;
+ break;
+ cf = 255;
+ cf = 0;
+ break;
+ cf = 255;
+ cf = 0;
+ break;
+ if (cf == 0)
+ else {
+ /* fetch color table */
+ val1 = GDALRATGetValueAsDouble(gdal_rat, indx, minmaxc);
+ r1 = GDALRATGetValueAsDouble(gdal_rat, indx, rc);
+ g1 = GDALRATGetValueAsDouble(gdal_rat, indx, gc);
+ b1 = GDALRATGetValueAsDouble(gdal_rat, indx, bc);
+ Rast_set_d_color(val1, r1 * cf, g1 * cf, b1 * cf, &colors);
have_colors = Rast_colors_count(&colors) > 0;
@@ -1339,3 +1472,108 @@
return;
+ int row, col, nrows, ncols;
+ const char *field_name;
+ GDALRATFieldUsage field_use;
+ GDALRATFieldType *field_type;
+ GDALRasterAttributeTableH gdal_rat;
+ FILE *fp;
+ char fname[GNAME_MAX];
+ if ((gdal_rat = GDALGetDefaultRAT(hBand)) == NULL)
+ return 0;
+ nrows = GDALRATGetRowCount(gdal_rat);
+ ncols = GDALRATGetColumnCount(gdal_rat);
+ if (nrows == 0 || ncols == 0)
+ return 0;
+ field_type = G_malloc(ncols * sizeof(GDALRATFieldType));
+ snprintf(fname, GNAME_MAX, "%s_%d.csv", outrat, nBand);
+ if (!(fp = fopen(fname, "w"))) {
+ int err = errno;
+ G_fatal_error(_("Unable to open file <%s>: %s."),
+ fname, strerror(err));
+ /* dump column names and usage */
+ for (col = 0; col < ncols; col++) {
+ if (col)
+ fprintf(fp, "|");
+ field_name = GDALRATGetNameOfCol(gdal_rat, col);
+ fprintf(fp, "%s", field_name);
+ field_use = GDALRATGetUsageOfCol(gdal_rat, col);
+ if (field_use == GFU_Generic)
+ fprintf(fp, " (General purpose field)");
+ else if (field_use == GFU_PixelCount)
+ fprintf(fp, " (Histogram pixel count)");
+ else if (field_use == GFU_Name)
+ fprintf(fp, " (Class name)");
+ else if (field_use == GFU_Min)
+ fprintf(fp, " (Class range minimum)");
+ else if (field_use == GFU_Max)
+ fprintf(fp, " (Class range maximum)");
+ else if (field_use == GFU_MinMax)
+ fprintf(fp, " (Class value (min=max))");
+ else if (field_use == GFU_Red)
+ fprintf(fp, " (Red class color (0-255))");
+ else if (field_use == GFU_Green)
+ fprintf(fp, " (Green class color (0-255))");
+ else if (field_use == GFU_Blue)
+ fprintf(fp, " (Blue class color (0-255))");
+ else if (field_use == GFU_Alpha)
+ fprintf(fp, " (Alpha (0=transparent,255=opaque))");
+ else if (field_use == GFU_RedMin)
+ fprintf(fp, " (Color Range Red Minimum)");
+ else if (field_use == GFU_GreenMin)
+ fprintf(fp, " (Color Range Green Minimum)");
+ else if (field_use == GFU_BlueMin)
+ fprintf(fp, " (Color Range Blue Minimum)");
+ else if (field_use == GFU_AlphaMin)
+ fprintf(fp, " (Color Range Alpha Minimum)");
+ else if (field_use == GFU_RedMax)
+ fprintf(fp, " (Color Range Red Maximum)");
+ else if (field_use == GFU_GreenMax)
+ fprintf(fp, " (Color Range Green Maximum)");
+ else if (field_use == GFU_BlueMax)
+ fprintf(fp, " (Color Range Blue Maximum)");
+ else if (field_use == GFU_AlphaMax)
+ fprintf(fp, " (Color Range Alpha Maximum)");
+ else if (field_use == GFU_MaxCount)
+ fprintf(fp, " (Maximum GFU value)");
+ else
+ fprintf(fp, " (Unknown)");
+ /* remember column type */
+ field_type[col] = GDALRATGetTypeOfCol(gdal_rat, col);
+ fprintf(fp, "\n");
+ /* dump entries */
+ for (row = 0; row < nrows; row++) {
+ if (col)
+ fprintf(fp, "|");
+ if (field_type[col] == GFT_Integer)
+ fprintf(fp, "%d", GDALRATGetValueAsInt(gdal_rat, row, col));
+ else if (field_type[col] == GFT_Real)
+ fprintf(fp, "%.15g", GDALRATGetValueAsDouble(gdal_rat, row, col));
+ else
+ fprintf(fp, "%s", GDALRATGetValueAsString(gdal_rat, row, col));
+ fclose(fp);
+ return 1;
