[GRASS-SVN] r63576 - grass/trunk/scripts/i.pansharpen
svn_grass at osgeo.org
Wed Dec 17 01:11:23 PST 2014
Author: lucadelu
Date: 2014-12-17 01:11:23 -0800 (Wed, 17 Dec 2014)
New Revision: 63576
grass/trunk/scripts/i.pansharpen/i.pansharpen.py
i.pansharpen: added group creation for the output, PEP8 cleaning
Modified: grass/trunk/scripts/i.pansharpen/i.pansharpen.py
--- grass/trunk/scripts/i.pansharpen/i.pansharpen.py 2014-12-16 21:58:25 UTC (rev 63575)
+++ grass/trunk/scripts/i.pansharpen/i.pansharpen.py 2014-12-17 09:11:23 UTC (rev 63576)
@@ -4,7 +4,7 @@
# MODULE: i.panmethod
-# AUTHOR(S): Overall script by Michael Barton (ASU)
+# AUTHOR(S): Overall script by Michael Barton (ASU)
# Brovey transformation in i.fusion.brovey by Markus Neteler <<neteler at osgeo org>>
# i.fusion brovey converted to Python by Glynn Clements
# IHS and PCA transformation added by Michael Barton (ASU)
@@ -12,7 +12,7 @@
# Thanks to Markus Metz for help with PCA inversion
# Thanks to Hamish Bowman for parallel processing algorithm
-# PURPOSE: Sharpening of 3 RGB channels using a high-resolution panchromatic channel
+# PURPOSE: Sharpening of 3 RGB channels using a high-resolution panchromatic channel
# COPYRIGHT: (C) 2002-2012 by the GRASS Development Team
@@ -21,14 +21,14 @@
# for details.
# REFERENCES:
-# Roller, N.E.G. and Cox, S., 1980. Comparison of Landsat MSS and merged MSS/RBV
-# data for analysis of natural vegetation. Proc. of the 14th International
+# Roller, N.E.G. and Cox, S., 1980. Comparison of Landsat MSS and merged MSS/RBV
+# data for analysis of natural vegetation. Proc. of the 14th International
# Symposium on Remote Sensing of Environment, San Jose, Costa Rica, 23-30 April, pp. 1001-1007.
-# Amarsaikhan, D., & Douglas, T. (2004). Data fusion and multisource image classification.
+# Amarsaikhan, D., & Douglas, T. (2004). Data fusion and multisource image classification.
# International Journal of Remote Sensing, 25(17), 3529-3539.
-# Behnia, P. (2005). Comparison between four methods for data fusion of ETM+
+# Behnia, P. (2005). Comparison between four methods for data fusion of ETM+
# multispectral and pan images. Geo-spatial Information Science, 8(2), 98-103
# for LANDSAT 5: see Pohl, C 1996 and others
@@ -80,7 +80,6 @@
#% description: Rebalance blue channel for LANDSAT
#%end
-import sys
import os
try:
@@ -91,47 +90,48 @@
import grass.script as grass
def main():
if not hasNumPy:
grass.fatal(_("Required dependency NumPy not found. Exiting."))
- sharpen = options['method'] # sharpening algorithm
- ms1 = options['blue'] # blue channel
- ms2 = options['green'] # green channel
- ms3 = options['red'] # red channel
- pan = options['pan'] # high res pan channel
- out = options['output'] # prefix for output RGB maps
- bladjust = flags['l'] # adjust blue channel
- sproc = flags['s'] # serial processing
+ sharpen = options['method'] # sharpening algorithm
+ ms1 = options['blue'] # blue channel
+ ms2 = options['green'] # green channel
+ ms3 = options['red'] # red channel
+ pan = options['pan'] # high res pan channel
+ out = options['output'] # prefix for output RGB maps
+ bladjust = flags['l'] # adjust blue channel
+ sproc = flags['s'] # serial processing
outb = grass.core.find_file('%s_blue' % out)
outg = grass.core.find_file('%s_green' % out)
outr = grass.core.find_file('%s_red' % out)
if (outb['name'] != '' or outg['name'] != '' or outr['name'] != '') and not grass.overwrite():
- grass.warning(_('Maps with selected output prefix names already exist. \
- Delete them or use overwrite flag'))
+ grass.warning(_('Maps with selected output prefix names already exist.'
+ ' Delete them or use overwrite flag'))
return
pid = str(os.getpid())
- #get PAN resolution:
- kv = grass.raster_info(map = pan)
+ # get PAN resolution:
+ kv = grass.raster_info(map=pan)
nsres = kv['nsres']
ewres = kv['ewres']
panres = (nsres + ewres) / 2
# clone current region
grass.use_temp_region()
- grass.run_command('g.region', res = panres, align = pan)
+ grass.run_command('g.region', res=panres, align=pan)
grass.message(_("Performing pan sharpening with hi res pan image: %f" % panres))
if sharpen == "brovey":
grass.verbose(_("Using Brovey algorithm"))
- #pan/intensity histogram matching using linear regression
+ # pan/intensity histogram matching using linear regression
outname = 'tmp%s_pan1' % pid
panmatch1 = matchhist(pan, ms1, outname)
@@ -140,39 +140,39 @@
outname = 'tmp%s_pan3' % pid
panmatch3 = matchhist(pan, ms3, outname)
outr = '%s_red' % out
outg = '%s_green' % out
outb = '%s_blue' % out
- #calculate brovey transformation
+ # calculate brovey transformation
grass.message(_("Calculating Brovey transformation..."))
if sproc:
# serial processing
e = '''eval(k = "$ms1" + "$ms2" + "$ms3")
"$outr" = 1.0 * "$ms3" * "$panmatch3" / k
"$outg" = 1.0 * "$ms2" * "$panmatch2" / k
"$outb" = 1.0 * "$ms1" * "$panmatch1" / k'''
- grass.mapcalc(e, outr=outr, outg=outg, outb=outb,
- panmatch1=panmatch1, panmatch2=panmatch2, panmatch3=panmatch3,
- ms1=ms1, ms2=ms2, ms3=ms3, overwrite=True)
+ grass.mapcalc(e, outr=outr, outg=outg, outb=outb,
+ panmatch1=panmatch1, panmatch2=panmatch2,
+ panmatch3=panmatch3, ms1=ms1, ms2=ms2, ms3=ms3,
+ overwrite=True)
else:
# parallel processing
pb = grass.mapcalc_start('%s_blue = (1.0 * %s * %s) / (%s + %s + %s)' %
- (out, ms1, panmatch1, ms1, ms2, ms3),
- overwrite=True)
+ (out, ms1, panmatch1, ms1, ms2, ms3),
+ overwrite=True)
pg = grass.mapcalc_start('%s_green = (1.0 * %s * %s) / (%s + %s + %s)' %
- (out, ms2, panmatch2, ms1, ms2, ms3),
- overwrite=True)
+ (out, ms2, panmatch2, ms1, ms2, ms3),
+ overwrite=True)
pr = grass.mapcalc_start('%s_red = (1.0 * %s * %s) / (%s + %s + %s)' %
- (out, ms3, panmatch3, ms1, ms2, ms3),
- overwrite=True)
+ (out, ms3, panmatch3, ms1, ms2, ms3),
+ overwrite=True)
pb.wait()
pg.wait()
pr.wait()
# Cleanup
grass.run_command('g.remove', flags='f', quiet=True, type='rast',
@@ -180,53 +180,55 @@
elif sharpen == "ihs":
grass.verbose(_("Using IHS<->RGB algorithm"))
- #transform RGB channels into IHS color space
+ # transform RGB channels into IHS color space
grass.message(_("Transforming to IHS color space..."))
grass.run_command('i.rgb.his', overwrite=True,
- red_input=ms3,
- green_input=ms2,
- blue_input=ms1,
- hue_output="tmp%s_hue" % pid,
- intensity_output="tmp%s_int" % pid,
+ red_input=ms3,
+ green_input=ms2,
+ blue_input=ms1,
+ hue_output="tmp%s_hue" % pid,
+ intensity_output="tmp%s_int" % pid,
saturation_output="tmp%s_sat" % pid)
target = "tmp%s_int" % pid
outname = "tmp%s_pan_int" % pid
panmatch = matchhist(pan, target, outname)
- #substitute pan for intensity channel and transform back to RGB color space
+ # substitute pan for intensity channel and transform back to RGB color space
grass.message(_("Transforming back to RGB color space and sharpening..."))
- grass.run_command('i.his.rgb', overwrite=True,
- hue_input="tmp%s_hue" % pid,
- intensity_input="%s" % panmatch,
+ grass.run_command('i.his.rgb', overwrite=True,
+ hue_input="tmp%s_hue" % pid,
+ intensity_input="%s" % panmatch,
saturation_input="tmp%s_sat" % pid,
- red_output="%s_red" % out,
- green_output="%s_green" % out,
+ red_output="%s_red" % out,
+ green_output="%s_green" % out,
blue_output="%s_blue" % out)
# Cleanup
name=panmatch)
elif sharpen == "pca":
grass.verbose(_("Using PCA/inverse PCA algorithm"))
grass.message(_("Creating PCA images and calculating eigenvectors..."))
- #initial PCA with RGB channels
- pca_out = grass.read_command('i.pca', quiet=True, rescale='0,0', input='%s,%s,%s' % (ms1, ms2, ms3), output='tmp%s.pca' % pid)
+ # initial PCA with RGB channels
+ pca_out = grass.read_command('i.pca', quiet=True, rescale='0,0',
+ input='%s,%s,%s' % (ms1, ms2, ms3),
+ output='tmp%s.pca' % pid)
if len(pca_out) < 1:
grass.fatal(_("Input has no data. Check region settings."))
b1evect = []
b2evect = []
b3evect = []
- for l in pca_out.replace('(',',').replace(')',',').splitlines():
+ for l in pca_out.replace('(', ',').replace(')', ',').splitlines():
b1evect.append(float(l.split(',')[1]))
b2evect.append(float(l.split(',')[2]))
b3evect.append(float(l.split(',')[3]))
- #inverse PCA with hi res pan channel substituted for principal component 1
+ # inverse PCA with hi res pan channel substituted for principal component 1
pca1 = 'tmp%s.pca.1' % pid
pca2 = 'tmp%s.pca.2' % pid
pca3 = 'tmp%s.pca.3' % pid
@@ -242,22 +244,24 @@
outname = 'tmp%s_pan' % pid
panmatch = matchhist(pan, ms1, outname)
grass.message(_("Performing inverse PCA ..."))
- stats1 = grass.parse_command("r.univar", map=ms1, flags='g',
- parse=(grass.parse_key_val, { 'sep' : '=' }))
- stats2 = grass.parse_command("r.univar", map=ms2, flags='g',
- stats3 = grass.parse_command("r.univar", map=ms3, flags='g',
+ stats1 = grass.parse_command("r.univar", map=ms1, flags='g',
+ parse=(grass.parse_key_val,
+ {'sep': '='}))
+ stats2 = grass.parse_command("r.univar", map=ms2, flags='g',
+ {'sep': '='}))
+ stats3 = grass.parse_command("r.univar", map=ms3, flags='g',
+ {'sep': '='}))
b1mean = float(stats1['mean'])
b2mean = float(stats2['mean'])
b3mean = float(stats3['mean'])
- if sproc:
+ if sproc:
# serial processing
@@ -271,48 +275,51 @@
cmd1 = "$outb = (1.0 * $panmatch * $b1evect1) + ($pca2 * $b2evect1) + ($pca3 * $b3evect1) + $b1mean"
cmd2 = "$outg = (1.0 * $panmatch * $b1evect2) + ($pca2 * $b2evect1) + ($pca3 * $b3evect2) + $b2mean"
cmd3 = "$outr = (1.0 * $panmatch * $b1evect3) + ($pca2 * $b2evect3) + ($pca3 * $b3evect3) + $b3mean"
- cmd = '\n'.join([cmd1, cmd2, cmd3])
+ cmd = '\n'.join([cmd1, cmd2, cmd3])
grass.mapcalc(cmd, outb=outb, outg=outg, outr=outr,
- panmatch=panmatch, pca2=pca2, pca3=pca3,
- b1evect1=b1evect1, b2evect1=b2evect1, b3evect1=b3evect1,
- b1evect2=b1evect2, b2evect2=b2evect2, b3evect2=b3evect2,
- b1evect3=b1evect3, b2evect3=b2evect3, b3evect3=b3evect3,
- b1mean=b1mean, b2mean=b2mean, b3mean=b3mean,
+ panmatch=panmatch, pca2=pca2, pca3=pca3,
+ b1evect1=b1evect1, b2evect1=b2evect1, b3evect1=b3evect1,
+ b1evect2=b1evect2, b2evect2=b2evect2, b3evect2=b3evect2,
+ b1evect3=b1evect3, b2evect3=b2evect3, b3evect3=b3evect3,
+ b1mean=b1mean, b2mean=b2mean, b3mean=b3mean,
overwrite=True)
else:
- pb = grass.mapcalc_start('%s_blue = (%s * %f) + (%s * %f) + (%s * %f) + %f'
- % (out, panmatch, b1evect1, pca2, b2evect1, pca3, b3evect1, b1mean),
- overwrite=True)
- pg = grass.mapcalc_start('%s_green = (%s * %f) + (%s * %f) + (%s * %f) + %f'
- % (out, panmatch, b1evect2, pca2, b2evect2, pca3, b3evect2, b2mean),
- overwrite=True)
- pr = grass.mapcalc_start('%s_red = (%s * %f) + (%s * %f) + (%s * %f) + %f'
- % (out, panmatch, b1evect3, pca2, b2evect3, pca3, b3evect3, b3mean),
- overwrite=True)
+ pb = grass.mapcalc_start('%s_blue = (%s * %f) + (%s * %f) + (%s * %f) + %f'
+ % (out, panmatch, b1evect1, pca2,
+ b2evect1, pca3, b3evect1, b1mean),
+ overwrite=True)
+ pg = grass.mapcalc_start('%s_green = (%s * %f) + (%s * %f) + (%s * %f) + %f'
+ % (out, panmatch, b1evect2, pca2,
+ b2evect2, pca3, b3evect2, b2mean),
+ overwrite=True)
+ pr = grass.mapcalc_start('%s_red = (%s * %f) + (%s * %f) + (%s * ''%f) + %f'
+ % (out, panmatch, b1evect3, pca2,
+ b2evect3, pca3, b3evect3, b3mean),
+ overwrite=True)
pr.wait()
pg.wait()
pb.wait()
# Cleanup
grass.run_command('g.remove', flags='f', quiet=True, type="rast",
- pattern='tmp%s*,%s' % (pid,panmatch))
- #Could add other sharpening algorithms here, e.g. wavelet transformation
+ pattern='tmp%s*,%s' % (pid, panmatch))
+ # Could add other sharpening algorithms here, e.g. wavelet transformation
grass.message(_("Assigning grey equalized color tables to output images..."))
- #equalized grey scales give best contrast
+ # equalized grey scales give best contrast
for ch in ['red', 'green', 'blue']:
- grass.run_command('r.colors', quiet=True, map = "%s_%s" % (out, ch), flags="e", col = 'grey')
+ grass.run_command('r.colors', quiet=True, map="%s_%s" % (out, ch),
+ flags="e", col='grey')
- #Landsat too blue-ish because panchromatic band less sensitive to blue light,
- # so output blue channed can be modified
+ # Landsat too blue-ish because panchromatic band less sensitive to blue
+ # light, so output blue channed can be modified
if bladjust:
grass.message(_("Adjusting blue channel color table..."))
rules = grass.tempfile()
@@ -323,7 +330,7 @@
grass.run_command('r.colors', map="%s_blue" % out, rules=rules)
os.remove(rules)
- #output notice
+ # output notice
grass.verbose(_("The following pan-sharpened output maps have been generated:"))
grass.verbose(_("%s_%s") % (out, ch))
@@ -337,99 +344,105 @@
grass.raster_history("%s_%s" % (out, ch))
- # Cleanup
+ # create a group with the three output
+ grass.run_command('i.group', group=out,
+ input="{n}_red,{n}_blue,{n}_green".format(n=out))
+ # Cleanup
grass.run_command('g.remove', flags="f", type="rast",
pattern="tmp%s*" % pid, quiet=True)
def matchhist(original, target, matched):
- #pan/intensity histogram matching using numpy arrays
+ # pan/intensity histogram matching using numpy arrays
grass.message(_("Histogram matching..."))
# input images
original = original.split('@')[0]
target = target.split('@')[0]
images = [original, target]
- # create a dictionary to hold arrays for each image
+ # create a dictionary to hold arrays for each image
arrays = {}
for i in images:
# calculate number of cells for each grey value for for each image
- stats_out = grass.pipe_command('r.stats', flags='cin', input= i, sep=':')
- stats = stats_out.communicate()[0].split('\n')[:-1]
- stats_dict = dict( s.split(':', 1) for s in stats)
- total_cells = 0 # total non-null cells
+ stats_out = grass.pipe_command('r.stats', flags='cin', input=i,
+ sep=':')
+ stats = stats_out.communicate()[0].split('\n')[:-1]
+ stats_dict = dict(s.split(':', 1) for s in stats)
+ total_cells = 0 # total non-null cells
for j in stats_dict:
stats_dict[j] = int(stats_dict[j])
if j != '*':
- total_cells += stats_dict[j]
+ total_cells += stats_dict[j]
if total_cells < 1:
- # Make a 2x256 structured array for each image with a
+ # Make a 2x256 structured array for each image with a
# cumulative distribution function (CDF) for each grey value.
# Grey value is the integer (i4) and cdf is float (f4).
- arrays[i] = np.zeros((256,),dtype=('i4,f4'))
- cum_cells = 0 # cumulative total of cells for sum of current and all lower grey values
- for n in range(0,256):
+ arrays[i] = np.zeros((256, ), dtype=('i4,f4'))
+ cum_cells = 0 # cumulative total of cells for sum of current and all lower grey values
+ for n in range(0, 256):
if str(n) in stats_dict:
num_cells = stats_dict[str(n)]
else:
num_cells = 0
- cum_cells += num_cells
+ cum_cells += num_cells
# cdf is the the number of cells at or below a given grey value
- # divided by the total number of cells
+ # divided by the total number of cells
cdf = float(cum_cells) / float(total_cells)
# insert values into array
- arrays[i][n] = (n, cdf)
+ arrays[i][n] = (n, cdf)
# open file for reclass rules
outfile = open(grass.tempfile(), 'w')
- new_grey = 0
for i in arrays[original]:
- # for each grey value and corresponding cdf value in original, find the
- # cdf value in target that is closest to the target cdf value
+ # for each grey value and corresponding cdf value in original, find the
+ # cdf value in target that is closest to the target cdf value
difference_list = []
for j in arrays[target]:
# make a list of the difference between each original cdf value and
# the target cdf value
difference_list.append(abs(i[1] - j[1]))
# get the smallest difference in the list
min_difference = min(difference_list)
- # find the grey value in target that correspondes to the cdf
+ # find the grey value in target that correspondes to the cdf
# closest to the original cdf
if j[1] == i[1] + min_difference or j[1] == i[1] - min_difference:
# build a reclass rules file from the original grey value and
# corresponding grey value from target
out_line = "%d = %d\n" % (i[0], j[0])
- outfile.write(out_line)
+ outfile.write(out_line)
break
- outfile.close()
+ outfile.close()
# create reclass of target from reclass rules file
- result = grass.core.find_file(matched, element = 'cell')
+ result = grass.core.find_file(matched, element='cell')
if result['fullname']:
name=matched)
- grass.run_command('r.reclass', input=original, out=matched, rules=outfile.name)
+ grass.run_command('r.reclass', input=original, out=matched,
+ rules=outfile.name)
else:
# Cleanup
# remove the rules file
- grass.try_remove(outfile.name)
+ grass.try_remove(outfile.name)
# return reclass of target with histogram that matches original
return matched
