[GRASS-SVN] r63590 - in grass/trunk/temporal: t.info t.list t.rast3d.algebra/testsuite t.rast3d.extract/testsuite t.remove
svn_grass at osgeo.org
Thu Dec 18 07:46:36 PST 2014
Author: martinl
Date: 2014-12-18 07:46:36 -0800 (Thu, 18 Dec 2014)
New Revision: 63590
grass/trunk/temporal/t.info/t.info.py
grass/trunk/temporal/t.list/t.list.py
grass/trunk/temporal/t.rast3d.algebra/testsuite/test_raster3d_algebra.py
grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py
grass/trunk/temporal/t.remove/t.remove.py
update temporal modules to `raster_3d` (#2409)
Modified: grass/trunk/temporal/t.info/t.info.py
--- grass/trunk/temporal/t.info/t.info.py 2014-12-18 15:43:47 UTC (rev 63589)
+++ grass/trunk/temporal/t.info/t.info.py 2014-12-18 15:46:36 UTC (rev 63590)
@@ -28,7 +28,7 @@
#%option G_OPT_STDS_TYPE
#% guidependency: input
#% guisection: Required
-#% options: strds, str3ds, stvds, raster, 3draster, vector
+#% options: strds, str3ds, stvds, raster, raster_3d, vector
#%end
#%flag
Modified: grass/trunk/temporal/t.list/t.list.py
--- grass/trunk/temporal/t.list/t.list.py 2014-12-18 15:43:47 UTC (rev 63589)
+++ grass/trunk/temporal/t.list/t.list.py 2014-12-18 15:46:36 UTC (rev 63590)
@@ -27,7 +27,7 @@
#% description: Type of the space time dataset or map, default is strds
#% guisection: Selection
#% required: no
#% answer: strds
#%end
Modified: grass/trunk/temporal/t.rast3d.algebra/testsuite/test_raster3d_algebra.py
--- grass/trunk/temporal/t.rast3d.algebra/testsuite/test_raster3d_algebra.py 2014-12-18 15:43:47 UTC (rev 63589)
+++ grass/trunk/temporal/t.rast3d.algebra/testsuite/test_raster3d_algebra.py 2014-12-18 15:46:36 UTC (rev 63590)
@@ -34,7 +34,7 @@
tgis.open_new_stds(name="A", type="str3ds", temporaltype="absolute",
title="A", descr="A", semantic="field", overwrite=True)
- tgis.register_maps_in_space_time_dataset(type="3draster", name="A", maps="a1,a2,a3,a4",
+ tgis.register_maps_in_space_time_dataset(type="raster_3d", name="A", maps="a1,a2,a3,a4",
start="2001-01-01", increment="1 day", interval=True)
def tearDown(self):
Modified: grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py
--- grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py 2014-12-18 15:43:47 UTC (rev 63589)
+++ grass/trunk/temporal/t.rast3d.extract/testsuite/test_extract.py 2014-12-18 15:46:36 UTC (rev 63590)
@@ -41,7 +41,7 @@
self.runModule("t.create", type="str3ds", temporaltype="absolute",
output="A", title="A test", description="A test", overwrite=True)
- self.runModule("t.register", flags="i", type="3draster", input="A",
+ self.runModule("t.register", flags="i", type="raster_3d", input="A",
maps="a1,a2,a3,a4,a5,a6",
start="2001-01-01", increment="3 months", overwrite=True)
Modified: grass/trunk/temporal/t.remove/t.remove.py
--- grass/trunk/temporal/t.remove/t.remove.py 2014-12-18 15:43:47 UTC (rev 63589)
+++ grass/trunk/temporal/t.remove/t.remove.py 2014-12-18 15:46:36 UTC (rev 63590)
@@ -137,7 +137,7 @@
if type == "stvds":
remove(type="vector", name=name_list, run_=True)
if type == "str3ds":
- remove(type="3draster", name=name_list, run_=True)
+ remove(type="raster_3d", name=name_list, run_=True)
map_statement = ""
name_list = []
@@ -149,7 +149,7 @@
if type == "stvds":
statement += sp.delete(dbif=dbif, execute=False)
