[GRASS-SVN] r63601 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Dec 18 13:50:47 PST 2014
Author: mmetz
Date: 2014-12-18 13:50:47 -0800 (Thu, 18 Dec 2014)
New Revision: 63601
grass/trunk/lib/vector/Vlib/snap.c
Vlib: reduce memory consumption for Vect_snap_lines(_list)()
Modified: grass/trunk/lib/vector/Vlib/snap.c
--- grass/trunk/lib/vector/Vlib/snap.c 2014-12-18 21:10:03 UTC (rev 63600)
+++ grass/trunk/lib/vector/Vlib/snap.c 2014-12-18 21:50:47 UTC (rev 63601)
@@ -21,6 +21,7 @@
#include <math.h>
#include <grass/vector.h>
#include <grass/glocale.h>
+#include <grass/kdtree.h>
/* translate segment to box and back */
#define X1W 0x01 /* x1 is West, x2 East */
@@ -121,6 +122,14 @@
return 1;
+static void
+Vect_snap_lines_list_rtree(struct Map_info *, const struct ilist *,
+ double, struct Map_info *);
+static void
+Vect_snap_lines_list_kdtree(struct Map_info *, const struct ilist *,
\brief Snap selected lines to existing vertex in threshold.
@@ -161,6 +170,16 @@
Vect_snap_lines_list(struct Map_info *Map, const struct ilist *List_lines,
double thresh, struct Map_info *Err)
+ if (getenv("GRASS_VECTOR_LOWMEM"))
+ Vect_snap_lines_list_rtree(Map, List_lines, thresh, Err);
+ else
+static void
+Vect_snap_lines_list_kdtree(struct Map_info *Map, const struct ilist *List_lines,
+ double thresh, struct Map_info *Err)
struct line_pnts *Points, *NPoints;
struct line_cats *Cats;
int line, ltype, line_idx;
@@ -177,6 +196,356 @@
int *Index = NULL; /* indexes of anchors for vertices */
int aindex = 0; /* allocated Index */
+ struct kdtree *KDTree;
+ double c[2];
+ double *kdd;
+ int *kduid, kd_found;
+ if (List_lines->n_values < 1)
+ return;
+ Points = Vect_new_line_struct();
+ NPoints = Vect_new_line_struct();
+ Cats = Vect_new_cats_struct();
+ List = Vect_new_list();
+ KDTree = kdtree_create(2, NULL);
+ thresh2 = thresh * thresh;
+ /* Go through all lines in vector, and add each point to structure of points */
+ apoints = 0;
+ point = 1; /* index starts from 1 ! */
+ nvertices = 0;
+ XPnts = NULL;
+ G_important_message(_("Snap vertices Pass 1: select points"));
+ for (line_idx = 0; line_idx < List_lines->n_values; line_idx++) {
+ int v;
+ G_percent(line_idx, List_lines->n_values, 2);
+ line = List_lines->value[line_idx];
+ G_debug(3, "line = %d", line);
+ if (!Vect_line_alive(Map, line))
+ continue;
+ ltype = Vect_read_line(Map, Points, Cats, line);
+ for (v = 0; v < Points->n_points; v++) {
+ G_debug(3, " vertex v = %d", v);
+ nvertices++;
+ /* coords */
+ c[0] = Points->x[v];
+ c[1] = Points->y[v];
+ if (kdtree_insert(KDTree, c, point, 0)) {
+ /* Add to structure */
+ if ((point - 1) == apoints) {
+ apoints += 10000;
+ XPnts =
+ (XPNT *) G_realloc(XPnts,
+ (apoints + 1) * sizeof(XPNT));
+ XPnts[point].x = Points->x[v];
+ XPnts[point].y = Points->y[v];
+ XPnts[point].anchor = -1;
+ point++;
+ G_percent(line_idx, List_lines->n_values, 2); /* finish it */
+ G_debug(0, "KD Tree depth: %d", (int)KDTree->root->depth);
+ kdtree_optimize(KDTree, 2);
+ npoints = point - 1;
+ /* Go through all registered points and if not yet marked mark it as anchor and assign this anchor
+ * to all not yet marked points in threshold */
+ G_important_message(_("Snap vertices Pass 2: assign anchor vertices"));
+ nanchors = ntosnap = 0;
+ for (point = 1; point <= npoints; point++) {
+ int i;
+ G_percent(point, npoints, 4);
+ G_debug(3, " point = %d", point);
+ if (XPnts[point].anchor >= 0)
+ continue;
+ XPnts[point].anchor = 0; /* make it anchor */
+ nanchors++;
+ /* Find points in threshold */
+ c[0] = XPnts[point].x;
+ c[1] = XPnts[point].y;
+ Vect_reset_list(List);
+ kd_found = kdtree_dnn(KDTree, c, &kduid, &kdd, thresh, &point);
+ G_debug(4, " %d points in threshold box", kd_found);
+ for (i = 0; i < kd_found; i++) {
+ int pointb;
+ double dx, dy, dist2;
+ pointb = kduid[i];
+ if (pointb == point)
+ continue;
+ dx = XPnts[pointb].x - XPnts[point].x;
+ dy = XPnts[pointb].y - XPnts[point].y;
+ dist2 = dx * dx + dy * dy;
+ if (dist2 > thresh2) /* outside threshold */
+ continue;
+ /* doesn't have an anchor yet */
+ if (XPnts[pointb].anchor == -1) {
+ XPnts[pointb].anchor = point;
+ ntosnap++;
+ else if (XPnts[pointb].anchor > 0) { /* check distance to previously assigned anchor */
+ double dist2_a;
+ dx = XPnts[XPnts[pointb].anchor].x - XPnts[pointb].x;
+ dy = XPnts[XPnts[pointb].anchor].y - XPnts[pointb].y;
+ dist2_a = dx * dx + dy * dy;
+ /* replace old anchor */
+ if (dist2 < dist2_a) {
+ if (kd_found) {
+ G_free(kdd);
+ G_free(kduid);
+ /* Go through all lines and:
+ * 1) for all vertices: if not anchor snap it to its anchor
+ * 2) for all segments: snap it to all anchors in threshold (except anchors of vertices of course) */
+ nsnapped = ncreated = 0;
+ G_important_message(_("Snap vertices Pass 3: snap to assigned points"));
+ int v, spoint, anchor;
+ int changed = 0;
+ double kddist;
+ continue;
+ if (Points->n_points >= aindex) {
+ aindex = Points->n_points;
+ Index = (int *)G_realloc(Index, aindex * sizeof(int));
+ /* Snap all vertices */
+ /* Box */
+ /* Find point ( should always find one point ) */
+ spoint = -1;
+ kdtree_knn(KDTree, c, &spoint, &kddist, 1, NULL);
+ if (spoint == -1)
+ G_fatal_error("Point not in KD Tree");
+ anchor = XPnts[spoint].anchor;
+ if (anchor > 0) { /* to be snapped */
+ Points->x[v] = XPnts[anchor].x;
+ Points->y[v] = XPnts[anchor].y;
+ nsnapped++;
+ changed = 1;
+ Index[v] = anchor; /* point on new location */
+ else {
+ Index[v] = spoint; /* old point */
+ /* New points */
+ Vect_reset_line(NPoints);
+ /* Snap all segments to anchors in threshold */
+ for (v = 0; v < Points->n_points - 1; v++) {
+ int i;
+ double x1, x2, y1, y2, xmin, xmax, ymin, ymax;
+ double dx, dy;
+ double kdthresh;
+ G_debug(3, " segment = %d end anchors : %d %d", v, Index[v],
+ Index[v + 1]);
+ x1 = Points->x[v];
+ x2 = Points->x[v + 1];
+ y1 = Points->y[v];
+ y2 = Points->y[v + 1];
+ Vect_append_point(NPoints, Points->x[v], Points->y[v],
+ Points->z[v]);
+ /* Box */
+ if (x1 <= x2) {
+ xmin = x1;
+ xmax = x2;
+ else {
+ xmin = x2;
+ xmax = x1;
+ if (y1 <= y2) {
+ ymin = y1;
+ ymax = y2;
+ else {
+ ymin = y2;
+ ymax = y1;
+ c[0] = (xmin + xmax) / 2;
+ c[1] = (ymin + ymax) / 2;
+ dx = xmax - xmin;
+ dy = ymax - ymin;
+ kdthresh = sqrt(dx * dx + dy * dy) + thresh;
+ /* Find points */
+ kd_found = kdtree_dnn(KDTree, c, &kduid, &kdd, kdthresh, NULL);
+ G_debug(3, " %d points in box", kd_found);
+ /* Snap to anchor in threshold different from end points */
+ nnew = 0;
+ double dist2, along;
+ spoint = kduid[i];
+ G_debug(4, " spoint = %d anchor = %d", spoint,
+ XPnts[spoint].anchor);
+ if (spoint == Index[v] || spoint == Index[v + 1])
+ continue; /* end point */
+ if (XPnts[spoint].anchor > 0)
+ continue; /* point is not anchor */
+ /* Check the distance */
+ dist2 =
+ dig_distance2_point_to_line(XPnts[spoint].x,
+ XPnts[spoint].y, 0, x1, y1, 0,
+ x2, y2, 0, 0, NULL, NULL,
+ NULL, &along, NULL);
+ G_debug(4, " distance = %lf", sqrt(dist2));
+ if (dist2 <= thresh2) {
+ G_debug(4, " anchor in thresh, along = %lf", along);
+ if (nnew == anew) {
+ anew += 100;
+ New = (NEW *) G_realloc(New, anew * sizeof(NEW));
+ New[nnew].anchor = spoint;
+ New[nnew].along = along;
+ nnew++;
+ if (kd_found) {
+ G_free(kduid);
+ G_free(kdd);
+ G_debug(3, " nnew = %d", nnew);
+ /* insert new vertices */
+ if (nnew > 0) {
+ /* sort by distance along the segment */
+ qsort(New, sizeof(char) * nnew, sizeof(NEW), sort_new);
+ for (i = 0; i < nnew; i++) {
+ anchor = New[i].anchor;
+ /* Vect_line_insert_point ( Points, ++v, XPnts[anchor].x, XPnts[anchor].y, 0); */
+ Vect_append_point(NPoints, XPnts[anchor].x,
+ XPnts[anchor].y, 0);
+ ncreated++;
+ changed = 1;
+ /* append end point */
+ v = Points->n_points - 1;
+ Vect_append_point(NPoints, Points->x[v], Points->y[v], Points->z[v]);
+ if (changed) { /* rewrite the line */
+ Vect_line_prune(NPoints); /* remove duplicates */
+ if (NPoints->n_points > 1 || !(ltype & GV_LINES)) {
+ Vect_rewrite_line(Map, line, ltype, NPoints, Cats);
+ else {
+ Vect_delete_line(Map, line);
+ if (Err) {
+ Vect_write_line(Err, ltype, Points, Cats);
+ } /* for each line */
+ Vect_destroy_line_struct(Points);
+ Vect_destroy_line_struct(NPoints);
+ Vect_destroy_cats_struct(Cats);
+ G_free(XPnts);
+ G_free(Index);
+ G_free(New);
+ kdtree_destroy(KDTree);
+ G_verbose_message(_("Snapped vertices: %d"), nsnapped);
+ G_verbose_message(_("New vertices: %d"), ncreated);
+static void
+Vect_snap_lines_list_rtree(struct Map_info *Map, const struct ilist *List_lines,
+ struct line_pnts *Points, *NPoints;
+ struct line_cats *Cats;
+ int line, ltype, line_idx;
+ double thresh2;
+ int point; /* index in points array */
+ int nanchors, ntosnap; /* number of anchors and number of points to be snapped */
+ int nsnapped, ncreated; /* number of snapped verices, number of new vertices (on segments) */
+ int apoints, npoints, nvertices; /* number of allocated points, registered points, vertices */
+ XPNT *XPnts; /* Array of points */
+ NEW *New = NULL; /* Array of new points */
+ int anew = 0, nnew; /* allocated new points , number of new points */
+ struct ilist *List;
+ int *Index = NULL; /* indexes of anchors for vertices */
+ int aindex = 0; /* allocated Index */
struct RTree *RTree;
int rtreefd = -1;
static struct RTree_Rect rect;
@@ -270,7 +639,7 @@
int i;
- G_percent(point, npoints, 2);
@@ -581,7 +950,7 @@
\param[in,out] Points line points to snap
\param[in] thresh threshold in which to snap vertices
\param[in] with_z 2D or 3D snapping
- \param[in,out] nsnapped number of snapped verices
+ \param[in,out] nsnapped number of snapped vertices
\param[in,out] ncreated number of new vertices (on segments)
\return 1 if line was changed, otherwise 0
