[GRASS-SVN] r63610 - grass/trunk/gui/wxpython/gui_core
Fri Dec 19 02:41:51 PST 2014
Author: martinl
Date: 2014-12-19 02:41:51 -0800 (Fri, 19 Dec 2014)
New Revision: 63610
   grass/trunk/gui/wxpython/gui_core/dialogs.py
   grass/trunk/gui/wxpython/gui_core/gselect.py
wxGUI: GDAL importer add support for GDAL RFC41 (Support for multiple geometry fields in OGR)
Modified: grass/trunk/gui/wxpython/gui_core/dialogs.py
--- grass/trunk/gui/wxpython/gui_core/dialogs.py	2014-12-19 10:28:48 UTC (rev 63609)
+++ grass/trunk/gui/wxpython/gui_core/dialogs.py	2014-12-19 10:41:51 UTC (rev 63610)
@@ -1889,6 +1889,10 @@
             if self.importType == 'ogr':
                 if ext and layer.rfind(ext) > -1:
                     layer = layer.replace('.' + ext, '')
+                if '|' in layer:
+                    layer, geometry = layer.split('|', 1)
+                else:
+                    geometry = None
                 if self.link:
                     cmd = ['v.external',
                            'input=%s' % dsn,
@@ -1898,7 +1902,8 @@
                     cmd = ['v.in.ogr',
                            'input=%s' % dsn,
                            'layer=%s' % layer,
-                           'output=%s' % output]
+                           'output=%s' % output,
+                           'geometry=%s' % geometry]
             else: # gdal
                 if self.dsnInput.GetType() == 'dir':
                     idsn = os.path.join(dsn, layer)
@@ -2201,8 +2206,12 @@
             if not self.IsChecked(item):
                 continue
             # layer / output name
-            data.append((self.GetItem(item, 1).GetText(),
-                         self.GetItem(item, self.GetColumnCount() - 1).GetText()))
+            layer = self.GetItem(item, 1).GetText()
+            ftype = self.GetItem(item, 2).GetText()
+            if '/' in ftype:
+                layer += '|%s' % ftype.split('/', 1)[0]
+            output = self.GetItem(item, self.GetColumnCount() - 1).GetText()
+            data.append((layer, output))
         return data
Modified: grass/trunk/gui/wxpython/gui_core/gselect.py
--- grass/trunk/gui/wxpython/gui_core/gselect.py	2014-12-19 10:28:48 UTC (rev 63609)
+++ grass/trunk/gui/wxpython/gui_core/gselect.py	2014-12-19 10:41:51 UTC (rev 63610)
@@ -1946,12 +1946,14 @@
             layerId = 1
             for line in ret.splitlines():
-                layerName, featureType, projection = map(lambda x: x.strip(), line.split(','))
+                layerName, featureType, projection, geometryColumn = map(lambda x: x.strip(), line.split(','))
                 if projection == '0':
                     projectionMatch = _("No")
                 else:
                     projectionMatch = _("Yes")
                 grassName = GetValidLayerName(layerName)
+                if geometryColumn:
+                    featureType = geometryColumn + '/' + featureType
                 data.append((layerId, layerName, featureType, projectionMatch, grassName))
                 layerId += 1
         else:
