[GRASS-SVN] r63613 - in grass/branches/releasebranch_7_0/lib/python/pygrass: . gis messages modules/interface raster vector
Fri Dec 19 05:54:36 PST 2014
Author: zarch
Date: 2014-12-19 05:54:36 -0800 (Fri, 19 Dec 2014)
New Revision: 63613
   grass/branches/releasebranch_7_0/lib/python/pygrass/gis/__init__.py
   grass/branches/releasebranch_7_0/lib/python/pygrass/messages/__init__.py
   grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
   grass/branches/releasebranch_7_0/lib/python/pygrass/raster/__init__.py
   grass/branches/releasebranch_7_0/lib/python/pygrass/raster/buffer.py
   grass/branches/releasebranch_7_0/lib/python/pygrass/utils.py
   grass/branches/releasebranch_7_0/lib/python/pygrass/vector/geometry.py
   grass/branches/releasebranch_7_0/lib/python/pygrass/vector/table.py
pygrass: sync relbr7 with trunk
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/gis/__init__.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/gis/__init__.py	2014-12-19 13:51:54 UTC (rev 63612)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/gis/__init__.py	2014-12-19 13:54:36 UTC (rev 63613)
@@ -15,11 +15,11 @@
 from grass.pygrass.errors import GrassError
-ETYPE = {'rast': libgis.G_ELEMENT_RASTER,
-         'rast3d': libgis.G_ELEMENT_RASTER3D,
-         'vect': libgis.G_ELEMENT_VECTOR,
-         'oldvect': libgis.G_ELEMENT_OLDVECTOR,
-         'asciivect': libgis.G_ELEMENT_ASCIIVECTOR,
+ETYPE = {'raster': libgis.G_ELEMENT_RASTER,
+         'raster_3d': libgis.G_ELEMENT_RASTER3D,
+         'vector': libgis.G_ELEMENT_VECTOR,
+         'oldvector': libgis.G_ELEMENT_OLDVECTOR,
+         'asciivector': libgis.G_ELEMENT_ASCIIVECTOR,
          'icon': libgis.G_ELEMENT_ICON,
          'labels': libgis.G_ELEMENT_LABEL,
          'sites': libgis.G_ELEMENT_SITE,
@@ -309,17 +309,17 @@
     def glist(self, type, pattern=None):
         """Return a list of grass types like:
-            * 'asciivect',
+            * 'asciivector',
             * 'group',
             * 'icon',
             * 'labels',
-            * 'oldvect',
-            * 'rast',
-            * 'rast3d',
+            * 'oldvector',
+            * 'raster',
+            * 'raster_3d',
             * 'region',
             * 'region3d',
             * 'sites',
-            * 'vect',
+            * 'vector',
             * 'view3d'
         :param type: the type of element to query
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/messages/__init__.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/messages/__init__.py	2014-12-19 13:51:54 UTC (rev 63612)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/messages/__init__.py	2014-12-19 13:54:36 UTC (rev 63613)
@@ -81,10 +81,6 @@
         if isinstance(message,  type(" ")):
             if len(message) >= 2000:
                 message = message[:1999]
-        # libgis limitation
-        if isinstance(message,  type(" ")):
-            if len(message) >= 2000:
-                message = message[:1999]
         if message_type == "PERCENT":
             n = int(data[1])
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py	2014-12-19 13:51:54 UTC (rev 63612)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py	2014-12-19 13:54:36 UTC (rev 63613)
@@ -697,7 +697,7 @@
                 args.append(str(self.flags[flg]))
         return args
-    @mdebug(1, extra=_get_bash)
+    # @mdebug(1, extra=_get_bash)
     def run(self):
         """Run the module
@@ -711,6 +711,7 @@
         termination. The handling of stdout and stderr must then be done
         outside of this function.
+        get_msgr().debug(1, self.get_bash())
         if self.inputs['stdin'].value:
             self.stdin = self.inputs['stdin'].value
             self.stdin_ = PIPE
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/raster/__init__.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/raster/__init__.py	2014-12-19 13:51:54 UTC (rev 63612)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/raster/__init__.py	2014-12-19 13:54:36 UTC (rev 63613)
@@ -457,217 +457,6 @@
         self._fd = None
-FLAGS = {1: {'b': 'i', 'i': 'i', 'u': 'i'},
-         2: {'b': 'i', 'i': 'i', 'u': 'i'},
-         4: {'f': 'f', 'i': 'i', 'b': 'i', 'u': 'i'},
-         8: {'f': 'd'}, }
-class RasterNumpy(np.memmap, RasterAbstractBase):
-    """Raster_cached_narray": Inherits "Raster_abstract_base" and
-    "numpy.memmap". Its purpose is to allow numpy narray like access to
-    raster maps without loading the map into the main memory.
-    * Behaves like a numpy array and supports all kind of mathematical
-      operations: __add__, ...
-    * Overrides the open and close methods
-    * Be aware of the 2Gig file size limit
-    >>> import grass.pygrass as pygrass
-    >>> elev = pygrass.raster.RasterNumpy('elevation')
-    >>> elev.open()
-    >>> elev[:5, :3]
-    RasterNumpy([[ 141.99613953,  141.27848816,  141.37904358],
-           [ 142.90461731,  142.39450073,  142.68611145],
-           [ 143.81854248,  143.54707336,  143.83972168],
-           [ 144.56524658,  144.58493042,  144.86477661],
-           [ 144.99488831,  145.22894287,  145.57142639]], dtype=float32)
-    >>> el = elev < 144
-    >>> el[:5, :3]
-    RasterNumpy([[1, 1, 1],
-           [1, 1, 1],
-           [1, 1, 1],
-           [0, 0, 0],
-           [0, 0, 0]], dtype=int32)
-    >>> el.exist()
-    False
-    >>> el.close('elev_bool', overwrite=True)
-    >>> el.exist()
-    True
-    >>> el.remove()
-    def __new__(cls, name, mapset="", mtype='CELL', mode='r+',
-                overwrite=False):
-        reg = Region()
-        shape = (reg.rows, reg.cols)
-        mapset = libgis.G_find_raster(name, mapset)
-        gtype = None
-        if mapset:
-            # map exist, set the map type
-            gtype = libraster.Rast_map_type(name, mapset)
-            mtype = RTYPE_STR[gtype]
-        filename = grasscore.tempfile()
-        obj = np.memmap.__new__(cls, filename=filename,
-                                dtype=RTYPE[mtype]['numpy'],
-                                mode=mode,
-                                shape=shape)
-        obj.mtype = mtype.upper()
-        obj.gtype = gtype if gtype else RTYPE[mtype]['grass type']
-        obj._rows = reg.rows
-        obj._cols = reg.cols
-        obj.filename = filename
-        obj._name = name
-        obj.mapset = mapset
-        obj.reg = reg
-        obj.overwrite = overwrite
-        return obj
-    def __array_finalize__(self, obj):
-        if hasattr(obj, '_mmap'):
-            self._mmap = obj._mmap
-            self.filename = grasscore.tempfile()
-            self.offset = obj.offset
-            self.mode = obj.mode
-            self._rows = obj._rows
-            self._cols = obj._cols
-            self._name = None
-            self.mapset = ''
-            self.reg = obj.reg
-            self.overwrite = obj.overwrite
-            self.mtype = obj.mtype
-            self._fd = obj._fd
-        else:
-            self._mmap = None
-    def _get_mode(self):
-        return self._mode
-    def _set_mode(self, mode):
-        if mode.lower() not in ('r', 'w+', 'r+', 'c'):
-            raise ValueError(_("Mode type: {0} not supported.").format(mode))
-        self._mode = mode
-    mode = property(fget=_get_mode, fset=_set_mode,
-                    doc="Set or obtain the opening mode of raster")
-    def __array_wrap__(self, out_arr, context=None):
-        """See:
-        http://docs.scipy.org/doc/numpy/user/
-        basics.subclassing.html#array-wrap-for-ufuncs"""
-        if out_arr.dtype.kind in 'bui':
-            # there is not support for boolean maps, so convert into integer
-            out_arr = out_arr.astype(np.int32)
-            out_arr.mtype = 'CELL'
-        #out_arr.p = out_arr.ctypes.data_as(out_arr.pointer_type)
-        return np.ndarray.__array_wrap__(self, out_arr, context)
-    def __init__(self, name, *args, **kargs):
-        ## Private attribute `_fd` that return the file descriptor of the map
-        self._fd = None
-        rows, cols = self._rows, self._cols
-        RasterAbstractBase.__init__(self, name)
-        self._rows, self._cols = rows, cols
-    def __unicode__(self):
-        return RasterAbstractBase.__unicode__(self)
-    def __str__(self):
-        return self.__unicode__()
-    def _get_flags(self, size, kind):
-        if size in FLAGS:
-            if kind in FLAGS[size]:
-                return size, FLAGS[size][kind]
-            else:
-                raise ValueError(_('Invalid type {0}'.format(kind)))
-        else:
-            raise ValueError(_('Invalid size {0}'.format(size)))
-    def _read(self):
-        """!Read raster map into array
-        :return: 0 on success
-        :return: non-zero code on failure
-        with RasterRow(self.name, self.mapset, mode='r') as rst:
-            buff = rst[0]
-            for i in range(len(rst)):
-                self[i] = rst.get_row(i, buff)
-    def _write(self, name, overwrite):
-        """Write the numpy array into map
-        if not self.exist() or self.mode != 'r':
-            self.flush()
-            buff = Buffer(self[0].shape, mtype=self.mtype)
-            with RasterRow(name, self.mapset, mode='w',
-                           mtype=self.mtype, overwrite=overwrite) as rst:
-                    buff[:] = self[i][:]
-                    rst.put_row(buff[:])
-            self.name = name
-    def open(self, mtype='', null=None, overwrite=None):
-        """Open the map, if the map already exist: determine the map type
-        and copy the map to the segment files;
-        else, open a new segment map.
-        :param mtype: specify the map type, valid only for new maps: CELL,
-                      FCELL, DCELL;
-        :type mtype: str
-        :param null:
-        :type null:
-        :param overwrite: use this flag to set the overwrite mode of existing
-                          raster maps
-        :type overwrite: bool
-        if overwrite is not None:
-            self.overwrite = overwrite
-        self.null = null
-        # rows and cols already set in __new__
-        if self.exist():
-            self.info.read()
-            self.cats.mtype = self.mtype
-            self.cats.read()
-            self.hist.read()
-            self._read()
-        else:
-            if mtype:
-                self.mtype = mtype
-            self._gtype = RTYPE[self.mtype]['grass type']
-        # set _fd, because this attribute is used to check
-        # if the map is open or not
-        self._fd = 1
-    def close(self, name='', overwrite=False):
-        """Function to close the map
-        :param name: the name of raster
-        :type name: str
-        if self.is_open():
-            name = name if name else self.name
-            if not name:
-                raise RuntimeError('Raster name not set neither '
-                                   'given as parameter.')
-            self._write(name, overwrite)
-            os.remove(self.filename)
-            self._fd = None
-    def get_value(self, point, region=None):
-        """This method returns the pixel value of a given pair of coordinates:
-        :param point: pair of coordinates in tuple object
-        :type point: tuple
-        :param region: the region to crop the request
-        :type region: Region object
-        if not region:
-            region = Region()
-        x, y = utils.coor2pixel(point.coords(), region)
-        return self[x][y]
 def random_map_only_columns(mapname, mtype, overwrite=True, factor=100):
     region = Region()
     random_map = RasterRow(mapname)
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/raster/buffer.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/raster/buffer.py	2014-12-19 13:51:54 UTC (rev 63612)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/raster/buffer.py	2014-12-19 13:54:36 UTC (rev 63613)
@@ -4,8 +4,10 @@
 import numpy as np
-CELL = (np.int, np.int0, np.int8, np.int16, np.int32, np.int64)
-FCELL = (np.float, np.float16, np.float32)
+_CELL = ('int', 'int0', 'int8', 'int16', 'int32', 'int64')
+CELL = tuple([getattr(np, attr) for attr in _CELL if hasattr(np, attr)])
+_FCELL = 'float', 'float16', 'float32'
+FCELL = tuple([getattr(np, attr) for attr in _FCELL if hasattr(np, attr)])
 _DCELL = 'float64', 'float128'
 DCELL = tuple([getattr(np, attr) for attr in _DCELL if hasattr(np, attr)])
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/utils.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/utils.py	2014-12-19 13:51:54 UTC (rev 63612)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/utils.py	2014-12-19 13:54:36 UTC (rev 63613)
@@ -286,6 +286,22 @@
     return path
+def set_path(modulename, dirname, path='.'):
+    import sys
+    """Set sys.path looking in the the local directory GRASS directories."""
+    pathlib = os.path.join(path, dirname)
+    if os.path.exists(pathlib):
+        # we are running the script from the script directory
+        sys.path.append(os.path.abspath(path))
+    else:
+        # running from GRASS GIS session
+        from grass.pygrass.utils import get_lib_path
+        path = get_lib_path(modulename, dirname)
+        if path is None:
+            raise ImportError("Not able to find the path %s directory." % path)
+        sys.path.append(path)
 def split_in_chunk(iterable, lenght=10):
     """Split a list in chunk.
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/vector/geometry.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/vector/geometry.py	2014-12-19 13:51:54 UTC (rev 63612)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/vector/geometry.py	2014-12-19 13:54:36 UTC (rev 63613)
@@ -7,6 +7,7 @@
 import ctypes
 import re
+from collections import namedtuple
 import numpy as np
@@ -19,6 +20,8 @@
 from grass.pygrass.vector import sql
+LineDist = namedtuple('LineDist', 'point dist spdist sldist')
 WKT = {'POINT\((.*)\)': 'point',  # 'POINT\(\s*([+-]*\d+\.*\d*)+\s*\)'
        'LINESTRING\((.*)\)': 'line'}
@@ -763,18 +766,20 @@
         :param pnt: the point to calculate distance
         :type pnt: a Point object or a tuple with the coordinates
-        Return a tuple with:
+        Return a namedtuple with:
-            * the closest point on the line,
-            * the distance between these two points,
-            * distance of point from segment beginning
-            * distance of point from line
+            * point: the closest point on the line,
+            * dist: the distance between these two points,
+            * spdist: distance to point on line from segment beginning
+            * sldist: distance to point on line form line beginning along line
         The distance is compute using the ``Vect_line_distance`` C function.
-            >>> line = Line([(0, 0), (0, 2)])
-            >>> line.distance(Point(1, 1))
-            (Point(0.000000, 1.000000), 1.0, 1.0, 1.0)
+            >>> point = Point(2.3, 0.5)
+            >>> line = Line([(0, 0), (2, 0), (3, 0)])
+            >>> line.distance(point)           #doctest: +NORMALIZE_WHITESPACE
+            LineDist(point=Point(2.300000, 0.000000),
+                     dist=0.5, spdist=0.2999999999999998, sldist=2.3)
         # instantite outputs
@@ -795,7 +800,7 @@
         # instantiate the Point class
         point = Point(cx.value, cy.value, cz.value)
         point.is2D = self.is2D
-        return point, dist.value, sp_dist.value, lp_dist.value
+        return LineDist(point, dist.value, sp_dist.value, lp_dist.value)
     def get_first_cat(self):
         """Fetches FIRST category number for given vector line and field, using
@@ -919,8 +924,27 @@
         libvect.Vect_line_reverse(self.c_points)
     def segment(self, start, end):
-        # TODO improve documentation
         """Create line segment. using the ``Vect_line_segment`` C function.
+        :param start: distance from the begining of the line where
+                      the segment start
+        :type start: float
+        :param end: distance from the begining of the line where
+                    the segment end
+        :type end: float
+            #            x (1, 1)
+            #   x--------x (1, 0)
+            # (0, 0) ^
+            >>> line = Line([(0, 0), (1, 0), (1, 1)])
+            >>> line.segment(0.5, 1.5)         #doctest: +NORMALIZE_WHITESPACE
+            Line([Point(0.500000, 0.000000),
+                  Point(1.000000, 0.000000),
+                  Point(1.000000, 0.500000)])
         line = Line()
         libvect.Vect_line_segment(self.c_points, start, end, line.c_points)
@@ -1122,7 +1146,7 @@
         :type only_out: bool
         for iline in self.ilines(only_in, only_out):
-            yield Line(id=abs(iline), c_mapinfo=self.c_mapinfo)
+            yield Line(v_id=abs(iline), c_mapinfo=self.c_mapinfo)
     def angles(self):
         """Return a generator with all lines angles in a node."""
@@ -1321,7 +1345,7 @@
         """Return the perimeter value of an Isle.
         border = self.points()
-        return libvect.Vect_area_perimeter(border.c_points)
+        return libvect.Vect_line_geodesic_length(border.c_points)
 class Isles(object):
@@ -1562,7 +1586,7 @@
         border = self.get_points()
     def read(self, line=None, centroid=None, isles=None):
         self.boundary = self.get_points(line)
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/vector/table.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/vector/table.py	2014-12-19 13:51:54 UTC (rev 63612)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/vector/table.py	2014-12-19 13:54:36 UTC (rev 63613)
@@ -398,7 +398,7 @@
         >>> remove('mycensus', 'vect')
-        def check_col(col_type):
+        def check(col_type):
             """Check the column type if it is supported by GRASS
             :param col_type: the type of column
@@ -407,26 +407,19 @@
             valid_type = ('DOUBLE PRECISION', 'DOUBLE', 'INT', 'INTEGER',
                           'DATE')
             if 'VARCHAR' in col_type or col_type.upper() not in valid_type:
-                str_err = "Type is not supported, supported types are: %s"
-                raise TypeError(str_err % ", ".join(valid_type))
+                str_err = ("Type: %r is not supported."
+                           "\nSupported types are: %s")
+                raise TypeError(str_err % (col_type, ", ".join(valid_type)))
+            return col_type
-        if isinstance(col_name, unicode):
-            check_col(col_type)
-        else:
-            if len(col_name) == len(col_type):
-                cvars = []
-                for name, ctype in zip(col_name, col_type):
-                    check_col(ctype)
-                    cvars.append('%s %s' % (name, ctype))
-                col_name = ''
-                col_type = ','.join(cvars)
-            else:
-                str_err = "The lenghts of the columns are different:\n%r\n%r"
-                raise TypeError(str_err % (col_name, col_type))
+        col_type = ([check(col_type), ] if isinstance(col_type, (str, unicode))
+                    else [check(col) for col in col_type])
+        col_name = ([col_name, ] if isinstance(col_name, (str, unicode))
+                    else col_name)
+        sqlcode = [sql.ADD_COL.format(tname=self.tname, cname=cn, ctype=ct)
+                   for cn, ct in zip(col_name, col_type)]
         cur = self.conn.cursor()
-        cur.execute(sql.ADD_COL.format(tname=self.tname,
-                                       cname=col_name,
-                                       ctype=col_type))
+        cur.executescript('\n'.join(sqlcode))
         self.conn.commit()
         cur.close()
         self.update_odict()
@@ -1022,7 +1015,7 @@
         cur = cursor if cursor else self.conn.cursor()
         if self.exist(cursor=cur):
             used = db_table_in_vector(self.name)
-            if len(used) > 0 and not force:
+            if used is not None and len(used) > 0 and not force:
                 print(_("Deleting table <%s> which is attached"
                         " to following map(s):") % self.name)
                 for vect in used:
@@ -1125,7 +1118,8 @@
         :type cursor: Cursor object
-        return cur.execute(self.columns.update_str, values)
+        vals = list(values) + [key, ]
+        return cur.execute(self.columns.update_str, vals)
     def create(self, cols, name=None, overwrite=False, cursor=None):
         """Create a new table
