[GRASS-SVN] r63623 - in grass/branches/releasebranch_7_0/general: g.remove g.rename
svn_grass at osgeo.org
Fri Dec 19 12:07:19 PST 2014
Author: martinl
Date: 2014-12-19 12:07:19 -0800 (Fri, 19 Dec 2014)
New Revision: 63623
grass/branches/releasebranch_7_0/general/g.remove/g.remove.html
grass/branches/releasebranch_7_0/general/g.rename/g.rename.html
sync g.remove and g.rename manuals with trunk
Modified: grass/branches/releasebranch_7_0/general/g.remove/g.remove.html
--- grass/branches/releasebranch_7_0/general/g.remove/g.remove.html 2014-12-19 20:06:05 UTC (rev 63622)
+++ grass/branches/releasebranch_7_0/general/g.remove/g.remove.html 2014-12-19 20:07:19 UTC (rev 63623)
@@ -9,23 +9,23 @@
Delete <tt>map1</tt> and <tt>map2</tt> raster maps in the current mapset:
<div class="code"><pre>
-g.remove -f type=rast name=tmp1,tmp2
+g.remove -f type=raster name=tmp1,tmp2
</pre></div>
Delete all raster and vector maps starting with "<tt>tmp_</tt>" in the current
mapset:
# show matching raster and vector maps but do not delete yet (as verification)
-g.remove type=rast,vect pattern="tmp_*"
+g.remove type=raster,vector pattern="tmp_*"
# actually delete the matching raster and vector maps
-g.remove -f type=rast,vect pattern="tmp_*"
+g.remove -f type=raster,vector pattern="tmp_*"
</pre></div>
Delete all vector maps starting with "<tt>stream_</tt>" in the current mapset,
but exclude those ending with "<tt>_final</tt>":
-g.remove -f type=vect pattern="stream_*" exclude="*_final"
+g.remove -f type=vector pattern="stream_*" exclude="*_final"
</pre></div>
<h2>AUTHOR</h2>
Modified: grass/branches/releasebranch_7_0/general/g.rename/g.rename.html
--- grass/branches/releasebranch_7_0/general/g.rename/g.rename.html 2014-12-19 20:06:05 UTC (rev 63622)
+++ grass/branches/releasebranch_7_0/general/g.rename/g.rename.html 2014-12-19 20:07:19 UTC (rev 63623)
@@ -14,22 +14,20 @@
then renamed to <em>new</em>.
<p>
-Users can also simply type <em>g.rename -help</em> without
+Users can also simply type <em>g.rename --help</em> without
arguments on the command line, to receive a menu of
existing data base element types and files from which to
choose for possible renaming:
-<div class="code">
-<pre>
- rast rast file(s) to be renamed
- oldvect oldvect file(s) to be renamed (GRASS 5.0)
- vect vect file(s) to be renamed (GRASS >5.1)
- icon icon file(s) to be renamed
- labels labels file(s) to be renamed
- sites sites file(s) to be renamed
- region region file(s) to be renamed
- group group file(s) to be renamed
- 3dview 3dview file(s) to be renamed
+<div class="code"><pre>
+ raster raster map(s) to be renamed
+ raster_3d 3D raster map(s) to be renamed
+ vector vector map(s) to be renamed
+ oldvector old (GRASS 5.0) vector map(s) to be renamed
+ asciivector ASCII vector map(s) to be renamed
+ labels paint label file(s) to be renamed
+ region region definition(s) to be renamed
+ group imagery group(s) to be renamed
</pre></div>
@@ -42,7 +40,7 @@
<p>
If the user attempts to rename a file to itself by setting
the <em>new</em> file name equal to the <em>old</em> file
-name (e.g., <b>g.rename rast=soils,soils</b>),
+name (e.g., <b>g.rename raster=soils,soils</b>),
<em>g.rename</em> will not execute the rename, but instead
state that no rename is needed. However, <em>g.rename</em>
@@ -58,13 +56,13 @@
# rename raster map
-g.rename rast=oldrast,newrast
+g.rename raster=oldrast,newrast
# rename vector map
-g.rename vect=oldvect,newvect
+g.rename vector=oldvect,newvect
# combined renaming
-g.rename rast=oldrast,newrast vect=oldvect,newvect
+g.rename raster=oldrast,newrast vector=oldvect,newvect
</pre></div>
<h2>SEE ALSO</h2>
