[GRASS-SVN] r63647 - grass/branches/releasebranch_7_0/scripts/v.db.update
Sat Dec 20 06:33:06 PST 2014
Author: neteler
Date: 2014-12-20 06:33:06 -0800 (Sat, 20 Dec 2014)
New Revision: 63647
   grass/branches/releasebranch_7_0/scripts/v.db.update/v.db.update.html
v.db.update manual: removed example for on the fly calculation (yet unsubmitted code)
Modified: grass/branches/releasebranch_7_0/scripts/v.db.update/v.db.update.html
--- grass/branches/releasebranch_7_0/scripts/v.db.update/v.db.update.html	2014-12-20 14:31:54 UTC (rev 63646)
+++ grass/branches/releasebranch_7_0/scripts/v.db.update/v.db.update.html	2014-12-20 14:33:06 UTC (rev 63647)
@@ -60,28 +60,7 @@
             where="z_value <> 'N/A'"
 </pre></div>
-<h3>Updating of columns with on the fly calculation (SQLite extended functions)</h3>
-North Carolina data set example: adding new column, copying values from
-another table column with on the fly calculation:
-<div class="code"><pre>
-g.copy vect=precip_30ynormals,myprecip_30ynormals
-v.db.addcolumn myprecip_30ynormals column="logjuly double precision"
-v.db.update myprecip_30ynormals column="logjuly" query_column="log(jul)" \
-  sqliteextra=$HOME/sqlite_extensions/libsqlitefunctions.so
-v.db.select myprecip_30ynormals columns=jul,logjuly
-jul|logjuly
-132.842|4.88916045210132
-127|4.84418708645859
-124.206|4.82194147751127
-104.648|4.65060233738593
-98.298|4.58800368106618
-</pre></div>
 <h2>SEE ALSO</h2>
 <em>
