[GRASS-SVN] r63655 - in grass-addons/grass7: general/g.copyall raster/r.droka raster/r.fidimo raster/r.mcda.input raster/r.mcda.roughset raster/r.popgrowth vector/v.civil/v.civil.topo vector/v.isochrones
Sat Dec 20 12:21:46 PST 2014
Author: neteler
Date: 2014-12-20 12:21:46 -0800 (Sat, 20 Dec 2014)
New Revision: 63655
   grass-addons/grass7/general/g.copyall/g.copyall.py
   grass-addons/grass7/raster/r.droka/r.droka.py
   grass-addons/grass7/raster/r.fidimo/r.fidimo.py
   grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py
   grass-addons/grass7/raster/r.mcda.roughset/r.mcda.roughset.py
   grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py
   grass-addons/grass7/vector/v.civil/v.civil.topo/v.civil.topo.py
   grass-addons/grass7/vector/v.isochrones/v.isochrones.py
update g.copy calls to use new element names (#2409)
Modified: grass-addons/grass7/general/g.copyall/g.copyall.py
--- grass-addons/grass7/general/g.copyall/g.copyall.py	2014-12-20 20:07:43 UTC (rev 63654)
+++ grass-addons/grass7/general/g.copyall/g.copyall.py	2014-12-20 20:21:46 UTC (rev 63655)
@@ -107,7 +107,7 @@
         params = {datatype: '%s@%s,%s' % (input, mapset, output)}
         grass.run_command('g.copy', overwrite=overwrite, **params)
-        if datatype == 'vect' and flags['t']:
+        if datatype == 'vector' and flags['t']:
             grass.run_command('v.build', map=output)
 if __name__ == "__main__":
Modified: grass-addons/grass7/raster/r.droka/r.droka.py
--- grass-addons/grass7/raster/r.droka/r.droka.py	2014-12-20 20:07:43 UTC (rev 63654)
+++ grass-addons/grass7/raster/r.droka/r.droka.py	2014-12-20 20:21:46 UTC (rev 63655)
@@ -143,7 +143,7 @@
     grass.message("Defining starting points...")
     if int(num) == 1:
         grass.run_command('g.copy' ,
-            vect= start+',start_points_' ,
+            vector= start+',start_points_' ,
             quiet = True )
     else:
         grass.run_command('v.buffer' ,
@@ -155,7 +155,7 @@
         grass.run_command('v.random' ,
             input = 'start_buffer_' ,
-            n = num ,
+            npoints = num ,
             output = 'start_random_' ,
             flags = 'a' ,
             quiet = True )
Modified: grass-addons/grass7/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.py	2014-12-20 20:07:43 UTC (rev 63654)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.py	2014-12-20 20:21:46 UTC (rev 63655)
@@ -404,7 +404,7 @@
 	#Prepare Barriers/Snap barriers to river_vector
 	if options['barriers']:
 		grass.run_command("g.copy",
-						vect = input_barriers + "," + "barriers_tmp_%d" % os.getpid())
+						  vector = input_barriers + "," + "barriers_tmp_%d" % os.getpid())
 		grass.run_command("v.db.addcolumn",
 						  map ="barriers_tmp_%d" % os.getpid(),
@@ -427,7 +427,7 @@
 						  columns="dist DOUBLE")
 		# Making barriers permanent
-			vect = "barriers_%d" % os.getpid() + "," + output_fidimo + "_barriers")
+			vector = "barriers_%d" % os.getpid() + "," + output_fidimo + "_barriers")
 		#Breaking river_vector at position of barriers to get segments
 		for adj_X,adj_Y in db.execute('SELECT adj_X, adj_Y FROM barriers_%d'% os.getpid()):
@@ -529,7 +529,7 @@
 							res = res)
 					overwrite=True,
-					rast = "river_raster_combine_tmp_%d" % os.getpid() + "," "river_raster_tmp_%d" % os.getpid())
+					raster = "river_raster_combine_tmp_%d" % os.getpid() + "," "river_raster_tmp_%d" % os.getpid())
@@ -644,7 +644,7 @@
 	# Make source points permanent
-		vect = "source_points_%d" % os.getpid() + "," + output_fidimo + "_source_points")
+		vector = "source_points_%d" % os.getpid() + "," + output_fidimo + "_source_points")
 	########### Looping over nrun, over segements, over source points ##########
@@ -1038,7 +1038,7 @@
 						mapcalc_string_Bb_aggregate = mapcalc_string_Bb_aggregate,
 						overwrite = True)
-			rast = "realised_density_final_%d" % os.getpid() + ",realised_" + output_fidimo+"_"+i)
+			raster = "realised_density_final_%d" % os.getpid() + ",realised_" + output_fidimo+"_"+i)
 			# Set all 0-values to NULL, Backgroundvalues
 			grass.run_command("r.null", map="realised_"+output_fidimo+"_"+i, setnull="0")
@@ -1052,7 +1052,7 @@
 					scalar = scalar)
-		rast = "density_final_corrected_%d" % os.getpid() + "," + output_fidimo+"_"+i)
+		raster = "density_final_corrected_%d" % os.getpid() + "," + output_fidimo+"_"+i)
Modified: grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py
--- grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py	2014-12-20 20:07:43 UTC (rev 63654)
+++ grass-addons/grass7/raster/r.mcda.input/r.mcda.input.py	2014-12-20 20:21:46 UTC (rev 63655)
@@ -121,7 +121,7 @@
 		if len(map_synth)>1:
 			grass.run_command("r.patch", overwrite='True', input=(",".join(map_synth)), output=l )
 		else:
-			grass.run_command("g.copy",rast=(str(map_synth),l))
+			grass.run_command("g.copy", raster=(str(map_synth),l))
 		grass.run_command("r.to.vect", overwrite='True', flags='s', input=l, output=l, feature='area')
 		grass.run_command("v.db.addcol", map=l, columns='rule varchar(25)')
@@ -132,7 +132,7 @@
 	if len(maps)>1:
 		grass.run_command("v.patch", overwrite='True', flags='e', input=mapstring, output=outputMap)
 	else:
-		grass.run_command("g.copy",vect=(mapstring,outputMap))
+		grass.run_command("g.copy", vector=(mapstring,outputMap))
 def main():
Modified: grass-addons/grass7/raster/r.mcda.roughset/r.mcda.roughset.py
--- grass-addons/grass7/raster/r.mcda.roughset/r.mcda.roughset.py	2014-12-20 20:07:43 UTC (rev 63654)
+++ grass-addons/grass7/raster/r.mcda.roughset/r.mcda.roughset.py	2014-12-20 20:21:46 UTC (rev 63655)
@@ -543,7 +543,7 @@
 		else:
 		print "__",str(map_synth),l
@@ -554,7 +554,7 @@
 	if len(maps)>1:
 		grass.run_command("v.patch", overwrite='True', flags='e', input=mapslabels, output=outputMap)
 	else:
-		grass.run_command("g.copy",vect=(mapslabels,outputMap))
+		grass.run_command("g.copy", vector=(mapslabels,outputMap))
 	if not flags['l']:
 		grass.run_command("g.remove", flags='f', type='raster', name=mapstring)
Modified: grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py
--- grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py	2014-12-20 20:07:43 UTC (rev 63654)
+++ grass-addons/grass7/raster/r.popgrowth/r.popgrowth.py	2014-12-20 20:21:46 UTC (rev 63655)
@@ -181,7 +181,7 @@
 				output="n0_tmp_%d" % os.getpid())
 	else:
-				rast=options['n_initial']+","+"n0_tmp_%d" % os.getpid())
+				raster=options['n_initial']+","+"n0_tmp_%d" % os.getpid())
 	tmp_map_rast.append("n0_tmp_")
@@ -240,7 +240,7 @@
 						output="r_exp_tmp_%d" % os.getpid())
 			else:
-						rast=options['r_exp_map']+","+"r_exp_tmp_%d" % os.getpid())
+						raster=options['r_exp_map']+","+"r_exp_tmp_%d" % os.getpid())
 			tmp_map_rast.append("r_exp_tmp_")
@@ -271,7 +271,7 @@
 		else:
-				rast="exponential_output_tmp_%d" % os.getpid() + ","+options['exponential_output'])
+				raster="exponential_output_tmp_%d" % os.getpid() + ","+options['exponential_output'])
 	################# Ricker Model #################
 	if options['ricker_output']:
@@ -292,7 +292,7 @@
 						output="r_rick_tmp_%d" % os.getpid())
 			else:
-						rast=options['r_rick_map']+","+"r_rick_tmp_%d" % os.getpid())
+						raster=options['r_rick_map']+","+"r_rick_tmp_%d" % os.getpid())
 			tmp_map_rast.append("r_rick_tmp_")
@@ -314,7 +314,7 @@
 						output="k_tmp_%d" % os.getpid())
 			else:
-						rast=options['k_map']+","+"k_tmp_%d" % os.getpid())
+						raster=options['k_map']+","+"k_tmp_%d" % os.getpid())
 			tmp_map_rast.append("k_tmp_")
@@ -345,7 +345,7 @@
 		else:
-				rast="ricker_output_tmp_%d" % os.getpid() +","+options['ricker_output'])
+				raster="ricker_output_tmp_%d" % os.getpid() +","+options['ricker_output'])
Modified: grass-addons/grass7/vector/v.civil/v.civil.topo/v.civil.topo.py
--- grass-addons/grass7/vector/v.civil/v.civil.topo/v.civil.topo.py	2014-12-20 20:07:43 UTC (rev 63654)
+++ grass-addons/grass7/vector/v.civil/v.civil.topo/v.civil.topo.py	2014-12-20 20:21:46 UTC (rev 63655)
@@ -391,7 +391,7 @@
 def patch_maps(pointsMap,linesMap,tmpMap):
-    grass.run_command('g.copy', vect=pointsMap+','+tmpMap)
+    grass.run_command('g.copy', vector=pointsMap+','+tmpMap)
     # lee las columnas de mapa de puntos y inserta las columnas si no existen
     columsPts=grass.read_command('db.columns', table=tmpMap)
Modified: grass-addons/grass7/vector/v.isochrones/v.isochrones.py
--- grass-addons/grass7/vector/v.isochrones/v.isochrones.py	2014-12-20 20:07:43 UTC (rev 63654)
+++ grass-addons/grass7/vector/v.isochrones/v.isochrones.py	2014-12-20 20:21:46 UTC (rev 63655)
@@ -175,7 +175,7 @@
         grass.run_command('g.rename', raster = (tmp_map, tmp_time_map))
     if timemap:
-        grass.run_command('g.copy', rast=(tmp_time_map, timemap))
+        grass.run_command('g.copy', raster=(tmp_time_map, timemap))
         grass.run_command('r.colors', map=timemap, color='grey', flags='ne')
     # recode time distance to time steps
