[GRASS-SVN] r63685 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Mon Dec 22 12:46:43 PST 2014
Author: martinl
Date: 2014-12-22 12:46:43 -0800 (Mon, 22 Dec 2014)
New Revision: 63685
grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: fix description for 'geometry' option
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2014-12-22 20:38:09 UTC (rev 63684)
+++ grass/trunk/vector/v.in.ogr/main.c 2014-12-22 20:46:43 UTC (rev 63685)
@@ -243,7 +243,7 @@
param.geom = G_define_standard_option(G_OPT_DB_COLUMN);
param.geom->key = "geometry";
param.geom->label = _("Name of geometry column");
- param.geom->description = _("If not given, first geometry column from the input is used");
+ param.geom->description = _("If not given, all geometry columns from the input are used");
param.geom->guisection = _("Selection");
flag.formats = G_define_flag();
