[GRASS-SVN] r63689 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Mon Dec 22 13:16:25 PST 2014
Author: martinl
Date: 2014-12-22 13:16:25 -0800 (Mon, 22 Dec 2014)
New Revision: 63689
grass/trunk/vector/v.in.ogr/v.in.ogr.html
v.in.ogr: add example from multiple geometry columns to the manual
Modified: grass/trunk/vector/v.in.ogr/v.in.ogr.html
--- grass/trunk/vector/v.in.ogr/v.in.ogr.html 2014-12-22 21:02:19 UTC (rev 63688)
+++ grass/trunk/vector/v.in.ogr/v.in.ogr.html 2014-12-22 21:16:25 UTC (rev 63689)
@@ -149,6 +149,13 @@
numbers are generated starting with 1 and stored in the column named
"cat".
+<p>
+Starting with GDAL 1.11 the library supports multiple geometry columns
+in OGR. By default <em>v.in.ogr</em> reads all geometry columns from
+given layer. The user can choose desired geometry column
+by <b>geometry</b> option,
+see <a href="#multiple-geometry-columns">example bellow</a>.
<h2>EXAMPLES</h2>
The command imports various vector formats:
@@ -275,6 +282,35 @@
v.in.ogr input=OCI:username/password at database_instance output=grasslayer layer=roads_oci
</pre></div>
+<h3>Multiple geometry columns</h3>
+This example shows how to work with data which contain multiple
+geometry per feature. The number of geometry columns per feature can
+be checked by <em><a href="v.external.html">v.external</a></em>
+together with <b>-t</b> flag.
+<div class="code"><pre>
+v.external -t input=20141130_ST_UKSH.xml.gz
+Okresy,point,1,DefinicniBod
+Okresy,multipolygon,1,OriginalniHranice
+Okresy,multipolygon,1,GeneralizovaneHranice
+</pre></div>
+In our example layer "Okresy" has three geometry columns:
+"DefinicniBod", "OriginalniHranice" and
+"GeneralizovanaHranice". By default <em>v.in.ogr</em> reads data from
+all three geometry columns. The user can specify desired geometry
+column by <b>geometry</b> option, in this case the module will read
+geometry only from the specified geometry column. In the example bellow,
+the output vector map will contain only geometry saved in
+"OriginalniHranice" geometry column.
+v.in.ogr input=20141130_ST_UKSH.xml.gz layer=Okresy geometry=OriginalniHranice
+</pre></div>
<h2>WARNINGS</h2>
If a message like "WARNING: Area size 1.3e-06, area not
@@ -329,11 +365,13 @@
<h2>AUTHORS</h2>
-Radim Blazek, ITC-irst, Trento, Italy
+Original author: Radim Blazek, ITC-irst, Trento, Italy
<br>
Location and spatial extent support by Markus Neteler and Paul Kelly
<br>
-Markus Metz
+Various improvements by Markus Metz
+<br>
+Multiple geometry columns support by Martin Landa, OSGeoREL, Czech Technical University in Prague, Czech Republic
<p>
<i>Last changed: $Date$</i>
