[GRASS-SVN] r63699 - grass/branches/releasebranch_7_0/vector/v.to.db
svn_grass at osgeo.org
Wed Dec 24 02:05:57 PST 2014
Author: martinl
Date: 2014-12-24 02:05:57 -0800 (Wed, 24 Dec 2014)
New Revision: 63699
grass/branches/releasebranch_7_0/vector/v.to.db/main.c
v.to.db: check if the map is in the current mapset (when modifying data)
bugfix segfault
(merge r63698 from trunk)
Modified: grass/branches/releasebranch_7_0/vector/v.to.db/main.c
--- grass/branches/releasebranch_7_0/vector/v.to.db/main.c 2014-12-24 09:40:34 UTC (rev 63698)
+++ grass/branches/releasebranch_7_0/vector/v.to.db/main.c 2014-12-24 10:05:57 UTC (rev 63699)
@@ -40,13 +40,24 @@
parse_command_line(argc, argv);
+ if (!options.print && !options.total) {
+ const char *mapset;
+ mapset = G_find_vector2(options.name, "");
+ if (!mapset || (strcmp(mapset, G_mapset()) != 0))
+ G_fatal_error(_("Vector map <%s> not found in the current mapset. "
+ "Unable to modify vector maps from different mapsets."),
+ options.name);
G_begin_distance_calculations();
G_begin_polygon_area_calculations();
/* open map */
Vect_set_open_level(2);
Vect_open_old(&Map, options.name, "");
+ Vect_set_error_handler_io(&Map, NULL);
Fi = Vect_get_field(&Map, options.field);
if (!options.print && Fi == NULL) {
