[GRASS-SVN] r63704 - in grass/trunk: lib/gis raster/r.colors temporal/t.rast.colors vector/v.colors
svn_grass at osgeo.org
Wed Dec 24 02:53:28 PST 2014
Author: martinl
Date: 2014-12-24 02:53:28 -0800 (Wed, 24 Dec 2014)
New Revision: 63704
grass/trunk/lib/gis/renamed_options
grass/trunk/raster/r.colors/edit_colors.c
grass/trunk/raster/r.colors/r.colors.html
grass/trunk/temporal/t.rast.colors/t.rast.colors.py
grass/trunk/vector/v.colors/main.c
grass/trunk/vector/v.colors/v.colors.html
r.colors|r3.colors|v.colors: rename 'volume' to 'raster_3d' - #2409
Modified: grass/trunk/lib/gis/renamed_options
--- grass/trunk/lib/gis/renamed_options 2014-12-24 10:42:58 UTC (rev 63703)
+++ grass/trunk/lib/gis/renamed_options 2014-12-24 10:53:28 UTC (rev 63704)
@@ -170,6 +170,8 @@
r.basins.fill|result:output
# r.blend
r.blend|output:output_prefix
+# r.colors
+r.colors|volume:raster_3d
# r.colors.stddev
r.colors.stddev|input:map
# r.cost
@@ -375,6 +377,8 @@
### Raster 3D module changes
+# r3.colors
+r3.colors|volume:raster_3d
# r3.gwflow
r3.gwflow|q:sink
r3.gwflow|s:yield
@@ -402,6 +406,8 @@
# v.clean
v.clean|thresh:threshold
+# v.colors
+v.colors|volume:raster_3d
# v.drape
v.drape|rast:elevation
# v.edit
Modified: grass/trunk/raster/r.colors/edit_colors.c
--- grass/trunk/raster/r.colors/edit_colors.c 2014-12-24 10:42:58 UTC (rev 63703)
+++ grass/trunk/raster/r.colors/edit_colors.c 2014-12-24 10:53:28 UTC (rev 63704)
@@ -97,7 +97,7 @@
opt.rast->guisection = _("Define");
opt.volume = G_define_standard_option(G_OPT_R3_INPUT);
- opt.volume->key = "volume";
+ opt.volume->key = "raster_3d";
opt.volume->required = NO;
opt.volume->description =
_("3D raster map from which to copy color table");
Modified: grass/trunk/raster/r.colors/r.colors.html
--- grass/trunk/raster/r.colors/r.colors.html 2014-12-24 10:42:58 UTC (rev 63703)
+++ grass/trunk/raster/r.colors/r.colors.html 2014-12-24 10:53:28 UTC (rev 63704)
@@ -6,10 +6,10 @@
by <b>map</b> or as <b>file</b> using an input file with one map name per line)
must exist in the user's current mapset search path.
-<p>The <b>rast</b> option allows user to specify a raster map <i>name</i>
+<p>The <b>raster</b> option allows user to specify a raster map <i>name</i>
from which to copy the color map.
-<p>The <b>volume</b> option allows user to specify a volume (3D raster)
+<p>The <b>raster_3d</b> option allows user to specify a 3D raster
map <i>name</i> from which to copy the color map.
<p>The <b>-e</b> flag equalizes the original raster's color table. It can
Modified: grass/trunk/temporal/t.rast.colors/t.rast.colors.py
--- grass/trunk/temporal/t.rast.colors/t.rast.colors.py 2014-12-24 10:42:58 UTC (rev 63703)
+++ grass/trunk/temporal/t.rast.colors/t.rast.colors.py 2014-12-24 10:53:28 UTC (rev 63704)
@@ -41,7 +41,7 @@
#%end
#%option G_OPT_R3_INPUT
-#% key: volume
+#% key: raster_3d
#% description: 3D raster map from which to copy color table
#% required: no
#% guisection: Define
@@ -108,7 +108,7 @@
input = options["input"]
color = options["color"]
raster = options["raster"]
- volume = options["volume"]
+ volume = options["raster_3d"]
rules = options["rules"]
remove = flags["r"]
write = flags["w"]
Modified: grass/trunk/vector/v.colors/main.c
--- grass/trunk/vector/v.colors/main.c 2014-12-24 10:42:58 UTC (rev 63703)
+++ grass/trunk/vector/v.colors/main.c 2014-12-24 10:53:28 UTC (rev 63704)
@@ -99,7 +99,7 @@
Modified: grass/trunk/vector/v.colors/v.colors.html
--- grass/trunk/vector/v.colors/v.colors.html 2014-12-24 10:42:58 UTC (rev 63703)
+++ grass/trunk/vector/v.colors/v.colors.html 2014-12-24 10:53:28 UTC (rev 63704)
@@ -11,7 +11,7 @@
vector lines are not supported.
<p>The <b>raster</b> option allows user to specify a raster map from
-which to copy the color table, similarly <b>volume</b> option for 3D
+which to copy the color table, similarly <b>raster_3d</b> option for 3D
raster map.
<p>The <b>rules</b> color table type will cause <em>v.colors</em> to
