[GRASS-SVN] r63713 - in grass/trunk: lib/gis raster/r.param.scale
Wed Dec 24 03:21:10 PST 2014
Author: martinl
Date: 2014-12-24 03:21:10 -0800 (Wed, 24 Dec 2014)
New Revision: 63713
   grass/trunk/lib/gis/renamed_options
   grass/trunk/raster/r.param.scale/interface.c
r.param.scale: tol -> tolerance (#2409)
Modified: grass/trunk/lib/gis/renamed_options
--- grass/trunk/lib/gis/renamed_options	2014-12-24 11:16:01 UTC (rev 63712)
+++ grass/trunk/lib/gis/renamed_options	2014-12-24 11:21:10 UTC (rev 63713)
@@ -346,8 +346,8 @@
 r.out.vrml|elev:elevation
 r.out.vrml|exag:exaggeration
 # r.param.scale
-r.param.scale|s_tol:slope_tol
-r.param.scale|c_tol:curvature_tol
+r.param.scale|s_tol:slope_tolerance
+r.param.scale|c_tol:curvature_tolerance
 r.param.scale|exp:exponent
 # r.profile
 r.profile|null:null_value
Modified: grass/trunk/raster/r.param.scale/interface.c
--- grass/trunk/raster/r.param.scale/interface.c	2014-12-24 11:16:01 UTC (rev 63712)
+++ grass/trunk/raster/r.param.scale/interface.c	2014-12-24 11:21:10 UTC (rev 63713)
@@ -74,14 +74,14 @@
     rast_out->description =
 	_("Name for output raster map containing morphometric parameter");
-    tol1_val->key = "slope_tol";
+    tol1_val->key = "slope_tolerance";
     tol1_val->description =
 	_("Slope tolerance that defines a 'flat' surface (degrees)");
     tol1_val->type = TYPE_DOUBLE;
     tol1_val->required = NO;
     tol1_val->answer = "1.0";
-    tol2_val->key = "curvature_tol";
+    tol2_val->key = "curvature_tolerance";
     tol2_val->description =
 	_("Curvature tolerance that defines 'planar' surface");
     tol2_val->type = TYPE_DOUBLE;
