[GRASS-SVN] r63719 - grass/trunk/vector/v.net
Wed Dec 24 04:30:06 PST 2014
Author: martinl
Date: 2014-12-24 04:30:06 -0800 (Wed, 24 Dec 2014)
New Revision: 63719
   grass/trunk/vector/v.net/args.c
   grass/trunk/vector/v.net/v.net.html
v.net: tlayer -> turn_layer and tuc_layer -> turn_uc_layer (#2409)
Modified: grass/trunk/vector/v.net/args.c
--- grass/trunk/vector/v.net/args.c	2014-12-24 12:22:32 UTC (rev 63718)
+++ grass/trunk/vector/v.net/args.c	2014-12-24 12:30:06 UTC (rev 63719)
@@ -106,7 +106,7 @@
     ("Layer where turntable will be attached. Format: layer number[/layer name]."
      "Required for operation 'turntable'.");
     opt->tfield->answer = "3";
-    opt->tfield->key = "tlayer";
+    opt->tfield->key = "turn_layer";
     opt->tfield->required = NO;
     opt->tfield->guisection = _("Turntable");
@@ -118,7 +118,7 @@
      " The categories are used in turntable. Format: layer number[/layer name]. "
     opt->tucfield->answer = "4";
-    opt->tucfield->key = "tuclayer";
+    opt->tucfield->key = "turn_uc_layer";
     opt->tucfield->required = NO;
     opt->tucfield->guisection = _("Turntable");
Modified: grass/trunk/vector/v.net/v.net.html
--- grass/trunk/vector/v.net/v.net.html	2014-12-24 12:22:32 UTC (rev 63718)
+++ grass/trunk/vector/v.net/v.net.html	2014-12-24 12:30:06 UTC (rev 63719)
@@ -83,13 +83,13 @@
 with the costs for every possible
 turn on every possible node (intersection, crossroad) in given layer (arc_layer).
 U-turns are taken in account too.
-Turntable is created in <b>tlayer</b> and <b>tuclayer</b>.
+Turntable is created in <b>turn_layer</b> and <b>turn_uc_layer</b>.
 Building the turntable allows you to model e.g. trafic code, where some turns
 may be prohibited.
 If features in analyzed network are changed, the turntable must be created again
 (e.g. it includes v.net connect operation).
-Turntable name consists of output vector map name + "_turntable_" + "t" + "_" + tlayer +
- "_" + "tuc" + "_" + tuclayer + "_" + "a" + "_" + arc_layer  e. g. roads_turntable_t_3_tuc_4_a_1
+Turntable name consists of output vector map name + "_turntable_" + "t" + "_" + turn_layer +
+ "_" + "tuc" + "_" + turn_uc_layer + "_" + "a" + "_" + arc_layer  e. g. roads_turntable_t_3_tuc_4_a_1
 <p>These modules are able to work with the turntable:
 <em><a href="v.net.alloc.html">v.net.alloc</a></em>,
