[GRASS-SVN] r63727 - in grass/trunk: lib/gis vector/v.net.visibility
svn_grass at osgeo.org
Wed Dec 24 06:24:37 PST 2014
Author: martinl
Date: 2014-12-24 06:24:37 -0800 (Wed, 24 Dec 2014)
New Revision: 63727
grass/trunk/lib/gis/renamed_options
grass/trunk/vector/v.net.visibility/main.c
grass/trunk/vector/v.net.visibility/v.net.visibility.html
v.net.visibility: coordinate -> coordinates and vis -> visibility (#2409)
Modified: grass/trunk/lib/gis/renamed_options
--- grass/trunk/lib/gis/renamed_options 2014-12-24 14:17:53 UTC (rev 63726)
+++ grass/trunk/lib/gis/renamed_options 2014-12-24 14:24:37 UTC (rev 63727)
@@ -530,6 +530,9 @@
v.net.timetable|ncolumn:node_column
v.net.timetable|afcolumn:arc_column
v.net.timetable|abcolumn:arc_backward_column
+# v.net.visibility
+v.net.visibility|coordinate|coordinates
+v.net.visibility|vis|visibility
# v.outlier
v.outlier|soe:ew_step
v.outlier|son:ns_step
Modified: grass/trunk/vector/v.net.visibility/main.c
--- grass/trunk/vector/v.net.visibility/main.c 2014-12-24 14:17:53 UTC (rev 63726)
+++ grass/trunk/vector/v.net.visibility/main.c 2014-12-24 14:24:37 UTC (rev 63727)
@@ -52,18 +52,12 @@
input = G_define_standard_option(G_OPT_V_INPUT);
output = G_define_standard_option(G_OPT_V_OUTPUT);
- coor = G_define_option();
- coor->key = "coordinate";
- coor->key_desc = "x,y";
- coor->type = TYPE_STRING;
- coor->required = NO;
- coor->multiple = YES;
- coor->description = _("One or more coordinates");
- ovis = G_define_option();
- ovis->key = "vis";
- ovis->type = TYPE_STRING;
+ coor = G_define_standard_option(G_OPT_M_COORDS);
+ ovis = G_define_standard_option(G_OPT_V_MAP);
+ ovis->key = "visibility";
ovis->required = NO;
+ ovis->label = _("Name of input vector map containing visable points");
ovis->description = _("Add points after computing the visibility graph");
/* options and flags parser */
Modified: grass/trunk/vector/v.net.visibility/v.net.visibility.html
--- grass/trunk/vector/v.net.visibility/v.net.visibility.html 2014-12-24 14:17:53 UTC (rev 63726)
+++ grass/trunk/vector/v.net.visibility/v.net.visibility.html 2014-12-24 14:24:37 UTC (rev 63727)
@@ -36,22 +36,22 @@
The resulting map containing the visibility graph is given in the output map.
<p>
If you need to add additional points to compute a shortest path
-between them afterwards you can use the <em>coordinate</em> parameter, e.g.:
+between them afterwards you can use the <em>coordinates</em> parameter, e.g.:
<div class="code"><pre>
-coordinate=25556200,6686400,25556400,6686600
+coordinates=25556200,6686400,25556400,6686600
</pre></div>
where 25556200,6686400 are the coordinate of the first point and
25556400,6686600 are the coordinates of the second point. Of course
you can give as many points as you need. They will be added to the
visibility graph and edges from them will be computed. You can
always add those points after computing the visibility graph. Simply
-use the <em>vis</em> parameter. The input will be the original
+use the <em>visibility</em> parameter. The input will be the original
vector map, the vis will be the computed visibility graph and the
output the new visibility graph which will be the vis + the new
points given with coordinate (edges will be computed as well).
-v.net.visibility input=map vis=vis_map output=new_vis_map \
- coordinate=25556200,6686400,25556400,6686600
+v.net.visibility input=map visibility=vis_map output=new_vis_map \
+ coordinates=25556200,6686400,25556400,6686600
</pre></div>
<h2>EXAMPLES</h2>
@@ -85,7 +85,7 @@
An example on how to use the coordinate parameter. This will compute the
visibility graph of the vector map lines with the point 2555678,6686343:
-v.net.visibility input=lines output=graph coordinate=2555678,6686343
+v.net.visibility input=lines output=graph coordinates=2555678,6686343
d.vect graph
d.vect lines col=red
</pre></div>
@@ -102,8 +102,8 @@
d.mon wx0
d.vect areas_7_11_25
v.net.visibility input=zipcodes_wake output=graph
-v.net.visibility input=zipcodes_wake vis=graph output=new_graph \
- coordinate=669547.97,208348.20
+v.net.visibility input=zipcodes_wake visibility=graph output=new_graph \
+ coordinates=669547.97,208348.20
d.erase
echo "symbol basic/star 20 669547.97 208348.20 black red" | d.graph -m
