[GRASS-SVN] r63729 - in grass/trunk/vector: v.overlay v.select
svn_grass at osgeo.org
Wed Dec 24 06:41:38 PST 2014
Author: martinl
Date: 2014-12-24 06:41:38 -0800 (Wed, 24 Dec 2014)
New Revision: 63729
grass/trunk/vector/v.overlay/main.c
grass/trunk/vector/v.overlay/v.overlay.html
grass/trunk/vector/v.select/args.c
v.overlay|v.select: fix bug introduced r63717
Modified: grass/trunk/vector/v.overlay/main.c
--- grass/trunk/vector/v.overlay/main.c 2014-12-24 14:27:04 UTC (rev 63728)
+++ grass/trunk/vector/v.overlay/main.c 2014-12-24 14:41:38 UTC (rev 63729)
@@ -70,7 +70,7 @@
field_opt[0] = G_define_standard_option(G_OPT_V_FIELD);
field_opt[0]->label = _("Layer number or name (vector map A)");
- field_opt[0]->key = "arc_layer";
+ field_opt[0]->key = "alayer";
type_opt[0] = G_define_standard_option(G_OPT_V_TYPE);
type_opt[0]->label = _("Feature type (vector map A)");
Modified: grass/trunk/vector/v.overlay/v.overlay.html
--- grass/trunk/vector/v.overlay/v.overlay.html 2014-12-24 14:27:04 UTC (rev 63728)
+++ grass/trunk/vector/v.overlay/v.overlay.html 2014-12-24 14:41:38 UTC (rev 63729)
@@ -37,7 +37,7 @@
<em>b_</em>) corresponding to <b>ainput</b> and <b>binput</b> map.
<p>
If the <i>second</i> number of the <b>olayer</b> option is greater than 0, then the
-categories of <b>ainput</b> in layer <b>arc_layer</b> are transferred to
+categories of <b>ainput</b> in layer <b>alayer</b> are transferred to
the output layer with the second number.
<p>
If the <i>third</i> number of the <b>olayer</b> option is greater than 0, then the
Modified: grass/trunk/vector/v.select/args.c
--- grass/trunk/vector/v.select/args.c 2014-12-24 14:27:04 UTC (rev 63728)
+++ grass/trunk/vector/v.select/args.c 2014-12-24 14:41:38 UTC (rev 63729)
@@ -14,7 +14,7 @@
parm->field[0] = G_define_standard_option(G_OPT_V_FIELD);
parm->field[0]->label = _("Layer number (vector map A)");
- parm->field[0]->key = "arc_layer";
+ parm->field[0]->key = "alayer";
parm->field[0]->guisection = _("Selection");
parm->type[0] = G_define_standard_option(G_OPT_V_TYPE);
