[GRASS-SVN] r63738 - grass/trunk/gui/wxpython/mapdisp
svn_grass at osgeo.org
Wed Dec 24 09:39:59 PST 2014
Author: martinl
Date: 2014-12-24 09:39:59 -0800 (Wed, 24 Dec 2014)
New Revision: 63738
grass/trunk/gui/wxpython/mapdisp/main.py
wxGUI: minor changes when starting standalone monitor (decorations)
Modified: grass/trunk/gui/wxpython/mapdisp/main.py
--- grass/trunk/gui/wxpython/mapdisp/main.py 2014-12-24 17:30:51 UTC (rev 63737)
+++ grass/trunk/gui/wxpython/mapdisp/main.py 2014-12-24 17:39:59 UTC (rev 63738)
@@ -392,27 +392,40 @@
self.cmdTimeStamp = os.path.getmtime(monFile['cmd'])
self.Map = DMonMap(giface=self._giface, cmdfile=monFile['cmd'],
mapfile = monFile['map'])
+ self.timer = wx.PyTimer(self.watcher)
+ #check each 0.5s
+ global mtime
+ mtime = 500
+ self.timer.Start(mtime)
else:
self.Map = None
+ return True
+ def CreateMapFrame(self, name, decorations=True):
+ if decorations:
+ toolbars = ['map']
+ statusbar = True
+ else:
+ toolbars = []
+ statusbar = False
self.mapFrm = DMonFrame(parent = None, id = wx.ID_ANY, Map = self.Map,
- giface = self._giface, size = monSize, toolbars = [], statusbar = False)
+ giface = self._giface, size = monSize,
+ toolbars = toolbars, statusbar = statusbar)
# FIXME: hack to solve dependency
self._giface._mapframe = self.mapFrm
- # self.SetTopWindow(Map)
self.mapFrm.GetMapWindow().SetAlwaysRenderEnabled(True)
self.Map.saveToFile.connect(lambda cmd: self.mapFrm.DOutFile(cmd))
self.Map.dToRast.connect(lambda cmd: self.mapFrm.DToRast(cmd))
- self.Map.query.connect(lambda ltype, maps: self.mapFrm.SetQueryLayersAndActivate(ltype=ltype, maps=maps))
- if __name__ == "__main__":
- self.timer = wx.PyTimer(self.watcher)
- #check each 0.5s
- global mtime
- mtime = 500
- self.timer.Start(mtime)
- return True
+ self.Map.query.connect(lambda ltype, maps: \
+ self.mapFrm.SetQueryLayersAndActivate(ltype=ltype, maps=maps))
+ return self.mapFrm
def OnExit(self):
@@ -492,11 +505,7 @@
start = time.time()
gmMap = MapApp(0)
- mapFrame = gmMap.GetMapFrame()
- mapFrame.SetTitle(monName)
- if monDecor:
- mapFrame._giface.ShowAllToolbars(monDecor)
- mapFrame._giface.ShowStatusbar(monDecor)
+ mapFrame = gmMap.CreateMapFrame(monName, monDecor)
mapFrame.Show()
Debug.msg(1, "WxMonitor started in %.6f sec" % \
(time.time() - start))
