[GRASS-SVN] r63753 - in grass/branches/releasebranch_7_0: .	lib/display lib/init
    svn_grass at osgeo.org
    Thu Dec 25 05:56:22 PST 2014
Author: martinl
Date: 2014-12-25 05:56:22 -0800 (Thu, 25 Dec 2014)
New Revision: 63753
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/lib/display/r_raster.c
   grass/branches/releasebranch_7_0/lib/init/variables.html
Check for either MONITOR or GRASS_RENDER_IMMEDIATE
(merge r63361,63742,63747-63748,63751-63752)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
 63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63275-63276,63279,63281,63283,63287,63290,63292,63297,63302,63304-63307,63315,63319,63327,63330,63332,63339,63342,63345,63362,63367,63379,63389,63391,63393,63402,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63604,63608-63609,63616,63618,63624,63626,63628,63630,63634,63639,63642,63644,63650,63652,63656,63679,63685,63689,63691,63693,63695,63698,63700-63702,63704,63706-63707,63709,63711,63713,63715,63717-63718,63721
 -63727,63731,63733,63749
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
 63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63275-63276,63279,63281,63283,63287,63290,63292,63297,63302,63304-63307,63315,63319,63327,63330,63332,63339,63342,63345,63361-63362,63367,63379,63389,63391,63393,63402,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63604,63608-63609,63616,63618,63624,63626,63628,63630,63634,63639,63642,63644,63650,63652,63656,63679,63685,63689,63691,63693,63695,63698,63700-63702,63704,63706-63707,63709,63711,63713,63715,63717-63718
 ,63721-63727,63731,63733,63742,63747-63749,63751-63752
Modified: grass/branches/releasebranch_7_0/lib/display/r_raster.c
--- grass/branches/releasebranch_7_0/lib/display/r_raster.c	2014-12-25 13:04:09 UTC (rev 63752)
+++ grass/branches/releasebranch_7_0/lib/display/r_raster.c	2014-12-25 13:56:22 UTC (rev 63753)
@@ -3,7 +3,7 @@
   \brief Display Library - Raster graphics subroutines
-  (C) 2001-2009, 2011 by the GRASS Development Team
+  (C) 2001-2014 by the GRASS Development Team
   This program is free software under the GNU General Public License
   (>=v2). Read the file COPYING that comes with GRASS for details.
@@ -71,6 +71,8 @@
     FILE *fd;
     char buf[1024];
     char **token;
+    G_debug(1, "read_env_file(): %s", path);
     fd = fopen(path, "r");
     if (!fd)
@@ -101,6 +103,7 @@
 int D_open_driver(void)
     const char *p, *m;
+    const struct driver *drv;
     G_debug(1, "D_open_driver():");
     p = getenv("GRASS_RENDER_IMMEDIATE");
@@ -109,7 +112,8 @@
     if (m && G_strncasecmp(m, "wx", 2) == 0) {
 	/* wx monitors always use GRASS_RENDER_IMMEDIATE. */
 	p = NULL; /* use default display driver */
-    } else if (m) {
+    else if (m) {
 	char *env;
 	const char *v;
 	char *u_m;
@@ -133,8 +137,14 @@
 	if (v)
 	    read_env_file(v);
+    else if (!p)
+	G_fatal_error(_("Neither %s (managed by d.mon command) nor %s (used for direct rendering) defined"),
+		      "MONITOR", "GRASS_RENDER_IMMEDIATE");
+    if (p && G_strcasecmp(p, "default") == 0)
+	p = NULL;
-    const struct driver *drv =
+    drv =
 	(p && G_strcasecmp(p, "png")   == 0) ? PNG_Driver() :
 	(p && G_strcasecmp(p, "ps")    == 0) ? PS_Driver() :
 	(p && G_strcasecmp(p, "html")  == 0) ? HTML_Driver() :
@@ -152,9 +162,6 @@
     init();
-    if (!getenv("GRASS_RENDER_IMMEDIATE") && !m)
-	return 1;
     return 0;
Modified: grass/branches/releasebranch_7_0/lib/init/variables.html
--- grass/branches/releasebranch_7_0/lib/init/variables.html	2014-12-25 13:04:09 UTC (rev 63752)
+++ grass/branches/releasebranch_7_0/lib/init/variables.html	2014-12-25 13:56:22 UTC (rev 63753)
@@ -329,15 +329,20 @@
 <h3>List of selected GRASS environment variables for rendering</h3>
 <blockquote>
-[ In addition to those which are understood by specific <em>GRASS display
- drivers</em>, the following variables affect rendering. ]
+[ In addition to those which are understood by
+ specific <em><a href="displaydrivers.html">GRASS display
+ drivers</a></em>, the following variables affect rendering. ]
 </blockquote>
 <dl>
   <dt>GRASS_RENDER_IMMEDIATE</dt>
   <dd>tells the display library which driver to use; possible
-  values: <em><a href="cairodriver.html">cairo</a></em>, <em><a href="pngdriver.html">png</a></em>, <em><a href="psdriver.html">ps</a></em>
-  or <em><a href="htmldriver.html">html</a></em></dd>
+  values: <em><a href="cairodriver.html">cairo</a></em>, <em><a href="pngdriver.html">png</a></em>, <em><a href="psdriver.html">ps</a></em>,
+    <em><a href="htmldriver.html">html</a></em>
+    or <em>default</em><br>Default display driver
+    is <em><a href="cairodriver.html">cairo</a></em> (if available)
+    otherwise <em><a href="pngdriver.html">png</a></em>.
+  </dd>
   <dt>GRASS_RENDER_WIDTH</dt>
   <dd>defines the width of output image (default is 640).</dd>
