[GRASS-SVN] r63761 - in grass/trunk/gui/wxpython: mapdisp mapwin
Thu Dec 25 08:32:43 PST 2014
Author: annakrat
Date: 2014-12-25 08:32:43 -0800 (Thu, 25 Dec 2014)
New Revision: 63761
   grass/trunk/gui/wxpython/mapdisp/frame.py
   grass/trunk/gui/wxpython/mapwin/decorations.py
wxGUI/legend: avoid opening legend window when entering command from gui command line and fix after renaming parameters
Modified: grass/trunk/gui/wxpython/mapdisp/frame.py
--- grass/trunk/gui/wxpython/mapdisp/frame.py	2014-12-25 15:57:13 UTC (rev 63760)
+++ grass/trunk/gui/wxpython/mapdisp/frame.py	2014-12-25 16:32:43 UTC (rev 63761)
@@ -1181,14 +1181,14 @@
                             continue
                         param, val = param_val
                         if param == 'raster':
-                            self.legend.cmd[idx] = 'rast={rast}'.format(rast=layer.maplayer.name)
+                            self.legend.cmd[idx] = 'raster={rast}'.format(rast=layer.maplayer.name)
                             isMap = True
                         elif param in ('use', 'range'):
                             # clear range or use to avoid problems
                             del self.legend.cmd[idx]
                     if not isMap:  # for the first time
-                        self.legend.cmd.append('rast=%s' % layer.maplayer.name)
+                        self.legend.cmd.append('raster=%s' % layer.maplayer.name)
                     break
         if not showDialog and self.legend.CmdIsValid():
Modified: grass/trunk/gui/wxpython/mapwin/decorations.py
--- grass/trunk/gui/wxpython/mapwin/decorations.py	2014-12-25 15:57:13 UTC (rev 63760)
+++ grass/trunk/gui/wxpython/mapwin/decorations.py	2014-12-25 16:32:43 UTC (rev 63761)
@@ -232,14 +232,17 @@
     def CmdIsValid(self):
         inputs = 0
-        for param in self._cmd:
+        for param in self._cmd[1:]:
             param = param.split('=')
-            if param[0] == 'raster' and len(param) == 2:
+            if len(param) == 1:
                 inputs += 1
-            elif param[0] == 'raster_3d' and len(param) == 2:
-                inputs += 1
-            if inputs == 1:
-                return True
+            else:
+                if param[0] == 'raster' and len(param) == 2:
+                    inputs += 1
+                elif param[0] == 'raster_3d' and len(param) == 2:
+                    inputs += 1
+        if inputs == 1:
+            return True
         return False
     def ResizeLegend(self, begin, end, screenSize):
