[GRASS-SVN] r63803 - grass/trunk/scripts/d.vect.thematic
svn_grass at osgeo.org
Sun Dec 28 23:41:02 PST 2014
Author: neteler
Date: 2014-12-28 23:41:02 -0800 (Sun, 28 Dec 2014)
New Revision: 63803
grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
d.vect.thematic: fix db.execute call (trac #2517)
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py 2014-12-28 15:45:01 UTC (rev 63802)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py 2014-12-29 07:41:02 UTC (rev 63803)
@@ -7,7 +7,7 @@
# by Martin Landa, Jachym Cepicky, Daniel Calvelo Aros and Moritz Lennert
# PURPOSE: Displays thematic vector map with graduated colors
# or graduated points and line thickneses
-# COPYRIGHT: (C) 2006 by the GRASS Development Team
+# COPYRIGHT: (C) 2006-2014 by the GRASS Development Team
# This program is free software under the GNU General Public
# License (>=v2). Read the file COPYING that comes with GRASS
@@ -313,7 +313,7 @@
if 'grassrgb' not in s.splitlines():
msg(locals(), _("Creating column 'grassrgb' in table <$table>"))
sql = "ALTER TABLE %s ADD COLUMN grassrgb varchar(11)" % table
- grass.write_command('db.execute', database = database, driver = driver, stdin = sql)
+ grass.write_command('db.execute', database = database, driver = driver, input = '-', stdin = sql)
# Group name
if not group:
@@ -670,7 +670,7 @@
# update color to database?
if flag_u:
sql = subs(locals(), "UPDATE $table SET GRASSRGB = '$themecolor' WHERE $sqlwhere")
# Create group for GIS Manager
if flag_g:
@@ -986,7 +986,7 @@
if flag_u:
sql = subs(locals(), "UPDATE $table SET grassrgb = '$themecolor' WHERE $sqlwhere")
if flag_g:
