[GRASS-SVN] r63807 - grass/trunk/scripts/d.vect.thematic
svn_grass at osgeo.org
Mon Dec 29 02:56:31 PST 2014
Author: martinl
Date: 2014-12-29 02:56:31 -0800 (Mon, 29 Dec 2014)
New Revision: 63807
grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
d.vect.thematic: rename color options (#2409)
Modified: grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py
--- grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py 2014-12-29 08:56:42 UTC (rev 63806)
+++ grass/trunk/scripts/d.vect.thematic/d.vect.thematic.py 2014-12-29 10:56:31 UTC (rev 63807)
@@ -106,7 +106,7 @@
#% guisection: Color
#%end
#% option
-#% key: pointcolor
+#% key: point_color
#% type: string
#% label: Color for graduated points map
#% description: GRASS named color or R:G:B triplet. Set color scheme to single color
@@ -115,7 +115,7 @@
#%end
#% option
-#% key: linecolor
+#% key: line_color
#% type: string
#% label: Color for graduated lines or point/area outlines
#% description: GRASS named color or R:G:B triplet. Set color scheme to single color.
@@ -124,7 +124,7 @@
#%end
#% option
-#% key: startcolor
+#% key: start_color
#% type: string
#% label: Beginning color for custom color gradient
#% description: Must be expressed as R:G:B triplet
@@ -133,7 +133,7 @@
#%end
#% option
-#% key: endcolor
+#% key: end_color
#% type: string
#% label: Ending color for custom color gradient
