[GRASS-SVN] r63809 - in grass/branches/releasebranch_7_0: . temporal temporal/t.vect.observe.strds temporal/t.vect.what.strds
Mon Dec 29 03:54:28 PST 2014
Author: lucadelu
Date: 2014-12-29 03:54:28 -0800 (Mon, 29 Dec 2014)
New Revision: 63809
   grass/branches/releasebranch_7_0/
   grass/branches/releasebranch_7_0/temporal/
   grass/branches/releasebranch_7_0/temporal/t.vect.observe.strds/t.vect.observe.strds.html
   grass/branches/releasebranch_7_0/temporal/t.vect.what.strds/t.vect.what.strds.html
temporal documentation: added t.vect.what.strds manual, fix typo in t.vect.observe.strds manual, #2259
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
   - /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
 63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63275-63276,63279,63281,63283,63287,63290,63292,63297,63302,63304-63307,63315,63319,63327,63330,63332,63339,63342,63345,63361-63363,63367,63379,63389,63391,63393,63402,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63604,63608-63609,63616,63618,63624,63626,63628,63630,63634,63639,63642,63644,63650,63652,63656,63679,63685,63689,63691,63693,63695,63698,63700-63702,63704,63706-63707,63709,63711,63713,63715,63717-63718
 ,63721-63727,63731,63733,63740-63742,63744,63747-63749,63751-63752,63756,63758,63761,63767,63783,63787,63793,63798,63801,63803
   + /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
 ,63721-63727,63731,63733,63740-63742,63744,63747-63749,63751-63752,63756,63758,63761,63767,63783,63787,63793,63798,63801,63803,63808
Property changes on: grass/branches/releasebranch_7_0/temporal
   - /grass/trunk:62868,62873
/grass/trunk/temporal:59684,59915-59916,60017-60018,60024,60026,60173-60174,60213,60547-60548,60732-60733,60817,61031,61066,61071-61072,61083,61096,61141,61157-61158,61179-61180,61186,61191-61194,61215,61239-61243,61274-61275,61282-61288,61301,61429-61433,61455,61457,61732,61734,61759-61762,61806-61807,61848,61885,61955-61957,61983-61985,61997-62000,62016,62021-62022,62025,62111-62113,62120-62121,62179-62180,62182,62343,62361,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62594-62597,62603,62606,62608-62609,62613-62614,62616,62618,62625-62628,62631-62632,62635-62638,62640-62642,62644,62646-62649,62652,62654-62657,62666,62691,62703-62705,62709-62712,62723,62730,62739,62741,62743,62746,62750,62752,62757,62762,62775,62785,62798,62800-62801,62803,62805,62812,62814-62815,62822,62824,62831,62838,62847,62856,62868,62871,62873,62875,62904,63035,63085,63087,63
 089,63091,63093,63170,63327,63345,63363,63391,63393,63554,63556,63590,63616,63628,63644,63650,63656,63704,63783
   + /grass/trunk:62868,62873
 089,63091,63093,63170,63327,63345,63363,63391,63393,63554,63556,63590,63616,63628,63644,63650,63656,63704,63783,63808
Modified: grass/branches/releasebranch_7_0/temporal/t.vect.observe.strds/t.vect.observe.strds.html
--- grass/branches/releasebranch_7_0/temporal/t.vect.observe.strds/t.vect.observe.strds.html	2014-12-29 11:53:29 UTC (rev 63808)
+++ grass/branches/releasebranch_7_0/temporal/t.vect.observe.strds/t.vect.observe.strds.html	2014-12-29 11:54:28 UTC (rev 63809)
@@ -6,8 +6,8 @@
 <h2>EXAMPLE</h2>
-The example how to create a space time vector dataset and a vector layer
-starting from a point vector and a space time raster dataset:
+The example show how to create a space time vector dataset and a vector
+layer starting from a point vector and a space time raster dataset:
 <div class="code"><pre>
 t.vect.observe.strds in=precip_30ynormals_3d strds=tempmean_monthly \
Modified: grass/branches/releasebranch_7_0/temporal/t.vect.what.strds/t.vect.what.strds.html
--- grass/branches/releasebranch_7_0/temporal/t.vect.what.strds/t.vect.what.strds.html	2014-12-29 11:53:29 UTC (rev 63808)
+++ grass/branches/releasebranch_7_0/temporal/t.vect.what.strds/t.vect.what.strds.html	2014-12-29 11:54:28 UTC (rev 63809)
@@ -6,19 +6,24 @@
 <h2>EXAMPLE</h2>
-The example is based on the XXX sample dataset:
+The example is based on the space time vector dataset "precip_stations at climate_2009_2012"
+created in the <a href="t.vect.observe.strds.html">t.vect.observe.strds</a> example.
+In below example the command fills the new column "new_temp" with values
+extracted from the "tempmean_monthly" space time raster dataset:
-TBD
+t.vect.what.strds in=precip_stations at climate_2009_2012 \
+                  strds=tempmean_monthly at climate_2009_2012 \
+                  column=new_temp method=average
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
-<a href="r.univar.html">r.univar</a>,
+<a href="r.univar.html">r.univar</a>,
 <a href="v.univar.html">v.univar</a>,
 <a href="v.what.rast.html">v.what.rast</a>,
-<a href="v.what.rast3.html">v.what.rast3</a>,
+<a href="v.what.rast3.html">v.what.rast3</a>,
 <a href="v.what.vect.html">v.what.vect</a>,
 <a href="t.create.html">t.create</a>,
 <a href="t.info.html">t.info</a>
