[GRASS-SVN] r63815 - in grass/branches/releasebranch_7_0: . display/d.path
svn_grass at osgeo.org
Mon Dec 29 04:51:03 PST 2014
Author: martinl
Date: 2014-12-29 04:51:03 -0800 (Mon, 29 Dec 2014)
New Revision: 63815
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/display/d.path/main.c
d.path: update name of parameters based on v.net modules (#2409)
(merge r63814 from trunk)
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
63076,63079,63081,63083,63085,63087,63089,63091,63093,63095,63098,63100,63102,63105,63107,63109,63111,63113-63114,63116,63119,63121,63123,63125,63130,63132-63133,63135,63137,63140,63143,63145,63147,63149,63151,63153-63154,63157,63160,63165,63170,63173,63175,63187,63192-63193,63196,63199-63200,63202,63209,63216,63220-63221,63224,63227,63240,63246,63250,63255,63259,63261,63275-63276,63279,63281,63283,63287,63290,63292,63297,63302,63304-63307,63315,63319,63327,63330,63332,63339,63342,63345,63361-63363,63367,63379,63389,63391,63393,63402,63408-63409,63416-63417,63425,63427,63429,63431,63433,63448,63451,63453,63457,63459,63464-63470,63473,63482,63497,63505,63508,63510,63515,63521-63524,63526,63536-63537,63551-63552,63554,63556,63558-63559,63562,63570,63576,63582,63589-63593,63602,63604,63608-63609,63616,63618,63624,63626,63628,63630,63634,63639,63642,63644,63650,63652,63656,63679,63685,63689,63691,63693,63695,63698,63700-63702,63704,63706-63707,63709,63711,63713,63715,63717-63718
,63721-63727,63731,63733,63740-63742,63744,63747-63749,63751-63752,63756,63758,63761,63767,63783,63787,63793,63797-63798,63801,63803,63807-63808,63812
+ /grass/trunk:60817,61096,61141,61994,62105,62179-62180,62182,62190,62403,62422,62424,62437,62466,62469,62487,62491,62494,62501,62506,62508-62509,62515,62518-62519,62521,62526,62533,62539,62541,62555,62562,62566,62570,62573,62575,62585,62588,62597,62603,62606,62608-62609,62614,62618,62628,62632,62638,62642,62648-62649,62652,62654-62657,62666,62691,62705,62709,62723,62730,62739,62741,62743,62746,62750-62752,62757,62762,62785,62798,62800-62801,62803,62805,62812,62822,62824,62828,62831,62838,62845,62847,62850,62856,62879,62881,62886,62904,62907-62908,62910,62912,62914,62916,62918,62920,62925,62932-62933,62935,62940,62942,62944-62946,62949,62955-62956,62958,62960,62962,62964,62966-62968,62970,62973,62975,62977,62981,62983,62985,62987,62989,62991,62993,62995,62997,62999-63000,63003,63005,63007,63009,63011,63013,63015,63017,63020,63022,63024,63026,63028-63031,63033,63035,63037,63040,63043-63044,63047,63049,63051,63053,63055,63057,63060,63062-63064,63066,63068,63070-63071,63074,
,63721-63727,63731,63733,63740-63742,63744,63747-63749,63751-63752,63756,63758,63761,63767,63783,63787,63793,63797-63798,63801,63803,63807-63808,63812,63814
Modified: grass/branches/releasebranch_7_0/display/d.path/main.c
--- grass/branches/releasebranch_7_0/display/d.path/main.c 2014-12-29 12:49:59 UTC (rev 63814)
+++ grass/branches/releasebranch_7_0/display/d.path/main.c 2014-12-29 12:51:03 UTC (rev 63815)
@@ -54,41 +54,40 @@
map = G_define_standard_option(G_OPT_V_MAP);
type_opt = G_define_standard_option(G_OPT_V_TYPE);
+ type_opt->key = "arc_type";
type_opt->options = "line,boundary";
type_opt->answer = "line,boundary";
type_opt->description = _("Arc type");
- coor_opt = G_define_option();
- coor_opt->key = "coordinates";
+ coor_opt = G_define_standard_option(G_OPT_M_COORDS);
coor_opt->key_desc = "x1,y1,x2,y2";
- coor_opt->type = TYPE_STRING;
coor_opt->required = YES;
coor_opt->description = _("Starting and ending coordinates");
afield_opt = G_define_standard_option(G_OPT_V_FIELD);
- afield_opt->key = "alayer";
+ afield_opt->key = "arc_layer";
afield_opt->answer = "1";
afield_opt->label = _("Arc layer");
nfield_opt = G_define_standard_option(G_OPT_V_FIELD);
- nfield_opt->key = "nlayer";
+ nfield_opt->key = "node_layer";
nfield_opt->answer = "2";
nfield_opt->label = _("Node layer");
afcol = G_define_option();
- afcol->key = "afcolumn";
+ afcol->key = "arc_column";
afcol->type = TYPE_STRING;
afcol->required = NO;
afcol->description = _("Arc forward/both direction(s) cost column (number)");
abcol = G_define_option();
- abcol->key = "abcolumn";
+ abcol->key = "arc_backward_column";
abcol->type = TYPE_STRING;
abcol->required = NO;
abcol->description = _("Arc backward direction cost column (number)");
ncol = G_define_option();
- ncol->key = "ncolumn";
+ ncol->key = "node_column";
ncol->type = TYPE_STRING;
ncol->required = NO;
ncol->description = _("Node cost column");
